Question about Dell Dimension 9200 PC Desktop
Dell Dimension 9200 "system does not support installed processor
Have a Dimension 9200, let a friend use it for a month, long story short, during boot i get a "system does not support installed processor" It will boot about 50% of the time, the other it just freezes on the windows login screen.
I have double checked the processor, just to make sure my idiot friend didnt swap or anything, its the correct one. any thoughts?
  • natedawes Apr 14, 2009
    Well, I got to the point of componet testing, and upon popping the cpu into a diff, but compatible mobo, discovered that the cpu is only slightly defective. Lol, Meaning its about 1/3 of the time that the error occurs. Replaced cpu, box is running stable. Thoughts on what could have toasted the old one?
    Oh, I also replace the stock dell heat sink with a much higher quality aftermarket one, and two new 120 fans. Just in case
  • Dustin Ellse
    Dustin Ellse May 11, 2010
    Hi natedawes,
    Are you online at the moment? If you are please tell me and send me your Skype details so we discuss this problem and i will be able to resolve this problem for you.
    Kind regards
    BearWeb
    President:
  • 623 Answers
This is really hard to say. Maybe he messed around in the BIOS settings and tried to overclock your processor. First thing I would do is to go into the BIOS (press F2 during startup) and check every setting. You can also reset it to default and see if that makes a difference.
Another possibility is that there is an issue with the RAM. Did you (or he) install new RAM? Look here to find a list of possible issues.
Check Dell's support page, to see if you can upgrade your BIOS.
Check your Device Manager (click Windowskey+R, type devmgmt.msc) for any unusual entries.
That's all I can think of right now. But please come back and post your findings (even if everything looks ok), so we can look into other places.
Posted on Apr 13, 2009
  •  C. Dante
    C. Dante Apr 14, 2009
    If you are using the stock cooler which came with your CPU, you shouldn't worry about overheating
    your computer, unless you
    haven't overclocked it. It is still a good idea to replace the cooler with a better one and put additional fans in the case.
    Although most CPU's have a built-in safeguard that shuts the system down before it can get too hot, repeatedly allowing the system to reach this critical temperature is a very bad idea, for both the health of the CPU as well as the system board.
    So, to get to your question - it is hard to say what killed your CPU without a visual inspection, but my first guess would always be a heat problem. Messing around in the BIOS and changing the clock speed or shutting of the airflow in the case are the usual suspects.
    Of course there is the option of damaging the CPU by taking it out of the socket and abusing it physically, but that would not lead to a intermittent failure you are experiencing, rather to a permanent failure.
    So my guess would be a heat problem - good move to put in two more fans!
    I am using a program called siw (System Information for Windows) to get my system's information. Have a look here, it can also tell you the temperature and tons of other useful information.
Dell Dimension 9200 does not boot.
remove ram and listen beep codes from the system ......still no beeps from the system .....the problem with motherboard only
Oct 15, 2012 | Dell Dimension 9200 PC Desktop
Hard drive boot failure
what is the error message? If operating system could not find, try you original windows installation CD, during you boot from the CD there is a repair option, follow the wizard to complete.
Sep 03, 2012 | Dell Dimension 2400 PC Desktop
Dell dimension 9200 no display
Try another monitor and see if you get a display. Borrow a monitor from a neighbor, friend, relative or co-worker. If the borrowed monitor does the same thing and shows no display, then your video card in the computer is bad. If the borrowed monitor displays things, then your original monitor is bad.
May 07, 2012 | Dell Dimension 9200 PC Desktop
Dimension 9200 wont boot in normal or safe mode. Processor fan is not running
The fan probably went out. Did you hear the fan noise for the last 2-3 weeks while using the unit? That was the fan going out. Buy a new fan @ Best Buys or your local computer store. It may work.
If it doesn't , you may have to replace the Processor and /or the system board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Jan 21, 2011 | Dell Dimension 9200 PC Desktop
Dimension 9200 wont boot blue screen cant access advanced setup cant run CHKDSK / F
In that case your only other option apart wiping it clean and starting from scratch is to perform a Repair install.
Jun 21, 2010 | Dell Dimension 9200 PC Desktop
I have Dell dimension 9200 and have to reinstall xp but do not have raid drivers on floppy disk. Motherboard is OWG855. Can you help with this?
If you have a Dell with Dell and it uses a software RAID, then you can download them from Dell's site.
Go to support.dell.com and enter your service tag or the system type and you can access the drivers.
Oct 07, 2009 | Dell Dimension 9200 PC Desktop
My Dell 9200 won't start up (boot) after 7 months non use
No offense, but you need to plug it in to turn it on.
Jun 18, 2009 | Dell Dimension 9200 PC Desktop
Dell Dimension 9200 keeps shutting down and won't start up
the key issue on the uncommanded shutdown is the POWER LED. If upon shutdown, the power LED Flashes AMBER, then the power supply is suspect.
If no flashing amber indication, then the next think I check is the heatsink (Processor overheating) remove, clean and apply arctic Silver heat transfer paste, see if the issuje goes away
Last but not least if the system is failing to boot, and displays a 3 4 diag LED code, then you may have a RAM module that is bad or may just need reseating. Running diags off of the Rersoujrce CD is something to look at too
Mar 28, 2009 | Dell Dimension 9200 PC Desktop
How to exchange a super noisy vent inside the Dimension 9200 - where exactly is it mounted? (talking about the main/cpu vent - not GPU or powersupply)
The Dimension 9200 is similar to XPS 410. Here is the link to the service manual for the Dim 9200 http://support.dell.com/support/edocs/systems/xps410/en/index.htm
The image below shows the location of the Proc Fan, which is located at the front behind the Dell logo
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 25, 2009 | Dell Dimension 9200 PC Desktop
Problem booting up dell dimension 2300 desktop.
You have no choice either you should reinstall your system, you should provide windows CD/DVD installation and boot your system using this disk.
However; you should backup your important files be cause most likely the all files will be removed during the installation process.
Jan 04, 2008 | Dell Dimension 2300 PC Desktop
Dell Dimension 9200 PC Desktop Logo
2,495 people viewed this question
Alun Cox
