Question about Zenith C27A24T 27" TV
Zenith picture problems
I have a 27in Zenith, has always been a good tv my problem now is that there is about a 2in black space on the top and it seem like the picture that should be there is reflected down and makes the top appear backwards. If that makes any sense. It looks lighter and if there are words they are backwards.
I took the back cover out and cleaned it, tons of dust made no difference. But as I was dusting and wiping I moved some adjustments in front of the tube. There are 6 of them and they rotate around, seems to be color-tint-up-down.
Now I have created another problem, when I use the guide the words are blurry and try as I may I can not get it just right again. Other than that the picture looks right.
    President:
  • 2,992 Answers
Your TV is showing signs of age. It's displaying something called "vertical foldover" which is due to capacitors in the set's vertical output section that need to be replaced. These failed parts can stress the vertical output integrated circuit, and if that goes bad your picture will collapse to a thin horizontal line. The capacitors themselves (usually 3 or 4 need to be replaced) are pretty cheap. A TV shop in your area (if there are any still around!) could fix it and the repair should be under $100.
By moving those rings on the tube's neck (which is actually the back) you have messed up the set's convergence. Those rings are magnets which adjust the electron beams in the tube so the red, green and blue images line up correctly on the tube face. The rings are often marked with a stripe after adjustment to show how they were lined up. Look carefully at them and see if there are any marks you can go by to reset them. To properly converge the set some equipment is needed to generate the adjustment test pattern. Again, a shop could do it for you.
All things considered, at this point you might seriously consider replacing the set. Not because the troubles aren't fixable, but because other parts can start failing because of age, and by now your picture tube is on borrowed time as well.
Posted on Apr 22, 2009
Its a zenith 27in the sound is good but the picture only shows a line across the screen
Make a fist with ur hand and bang on the tv bazel frame.The tv picture flickers back or bounces back to a normal picture.The tv have a vertical or a horizontal hold ics have coldsoldering joints and requiring resoldering.If u bang on the tv bazel frame picture don't flickers back or bounces back to a normal picture.The tv have a vertical or a horizontal hold ics are dead require changes those ics chips.If u don't have all the tools.Can't do a basic soldering work or able to changes those ics chips.Shop around for tv shops for estamate and repairing prices for repairing.
May 04, 2011 | Zenith C27A24T 27" TV
PICTURE SCREEN IS BLACK
Hi
do you have a remote for your TV? or universal?
Feb 26, 2009 | RCA 24F512T 24" TV
Prima 27in. hd flat screen
50% trouble of tv is lose connection,first thing you will do is to re solder your tv. must specially the vertical section and the jungle
Oct 29, 2008 | Prima CV2011 TV
Zenith 44" LCD TV
The yellow spot is due to the BLUE LCD and/or lens assy cracked, reason, to much HEAT! The blue is the darkest color and hold the most heat, so it goes first, always! In some cases it’s only the lens, however most of the time LCD is damage to. Parts are available, however install and alignment is timely. Quick fix is the complete light engine, which for model# E44W46LCD is part# 3141VSN916C, which customer cost is $1,449.27, wholesale for about $1,065.21. Rebuilt, if you can find it around 850.00 to 950.00. However the rebuilt does not always look as good as factory. My advice, TRASH set. This part will fail again in about 3 to 4 years, unless you watch a lot of white video. Remember, on a black or dark picture, all three LCD are blocking 100% of the light, causing extreme heat within the light engine. It’s a bad design.
TV Tech
Jul 13, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith 27 in TV
I am looking for a couple of parts for my zenith tv model # A27A11D.
fuse-1360011423A
knob array-04610578
Apr 25, 2008 | Zenith A27A11D 27" TV
Television does not work
Definately sounds like the light engine. that is an expensive part about 800.00 wish I could be more positive but I believe thats what you'll find needs replacing
Apr 09, 2008 | RCA D44LPW134 44" HDTV
Tv has black square hole in center
You have the closed captioning turned on for a channel that doesn't support this feature. Go into the menu page for closed captioning and turn it off.
Jan 14, 2008 | Televison & Video
Picture is cut off on top and bottom
Thats is not going to fix your problem. You have a bad vertical output IC and or a bad capacitor in the vertical drive or output circuit. Good Luck
Mar 31, 2007 | Zenith C27A24T 27" TV
Bad picture on tv
You should have the Picture tube checked by a professional, as thats the first thig most peeps think that goes bad when a picture is gone or bad. It could also be the crt driver circuit.
Sep 06, 2006 | Zenith IQB27B44W 27" TV
Black Shapes Encountered on TV Screen
your problem is in the horizontal sweep and its called blanking. it happens on mostly zeniths sets as Ive seen it a few times and the only waty to fix it is to replace the entire chassis as there are no parts for zenith available just the module as a complete assy. Basicly, The blanking is suppose to only blank the top and the bottom of the fields of the screen that you don't see but it misfires and causes all sorts of lines, squares, and boxes on the screen. When i first was told of this problem i thought the same exact thing?? About the closed caption but the set came into the shop and didnt do the problem. I thought the customer was seeing things. Then finally on night late I CAME BACK TO THE SHOP TURNED ON THE BENCH AND THERE IT WAS!!! i SAW IT WITH MY OWN EYES!! I replace the Module and all was good. Thge repair was about 175 bucks. Good Luck in your repair. Oh this should not be attemted by a handi person, as there is dangerous high voltage inside these sets.
Jun 14, 2006 | Zenith B27A76R 27" TV
Zenith C27A24T 27" TV Logo
276 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
