Question about Kenmore 463845504 Grill
Kenmore Gas Grill 141.155401 issue with Propane tanks
For the past year, I get only 1/2 to 2/3 use out of the propane tank. The grill acts as if there is no more propane, but I know there is almost 1/3 to a half a tank.
Should I replace the regulator or the and hose or just the regulator? Or is there something else going on?
  • 140 Answers
Replace the regulator
Posted on Apr 14, 2009
I have a Kenmore 14116329 propane grill. The propane tank is full but when I turn on the burners very little gas comes out resulting in a VERY low flame. Is it the regulator or???
It is most likely the saftey check valve in the tank. The procedure is to:
  • Close tank valve.
  • Disconnect hose connection from grill to tank.
  • Wait
  • Reconnect hose connection from grill to tank
  • "Slowly" open valve on tank to release gas back into grill
Through on some steaks
If still a problem replace tank.
The check valve that can cause your problem drastically reduces propane flow in case of an accident and the lines are ruptured
Hope this helps?
Jul 03, 2017 | Kenmore Grilling
The grill is too slow when grilling. It doesn't seem to get hot enough
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Aug 01, 2014 | The Holland Grill HGG421408LP Epic Gas...
Gas grill no flow of gas
Jul 14, 2014 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Grill isn't flowing propane when tank is on. No smell of propane and starter is clicking. Tested 3 tanks on grill and no luck. Tested same tanks on another grill and they work fine so it's the
it could be the reg or a blockage in the line or open the taps on the grill then close them reconnect gas tank open slowly then tis if there is gas to grill
Mar 16, 2012 | Barbeques Galore Turbo STS 3-Burner...
Replaced the tank but now gas wont flow from tank through to the grill... dendendeerhunter@yahoo.com
Hopefully this will fix you up.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
Your grill should now heat normally
Nov 07, 2010 | Kenmore 16225 Grill
Grill does not get hot. I have a fresh bottle of propane. Hose is not kinked. Grill is maybe 6 - 10 years old.
hi,
When a new or newly filled propane tank is attached to your gas grill, the OPD is usually at its maximum limit position above a tank filled to capacity. Propane may come through the valve too strongly due to the additional pressure of being full and the OPD displacement. The propane tank goes into check and limits gas flow when too much pressure hits the valve. Some grill manufacturers provide instructions for this in the users manuals but most people do not read the manual. Many grillers believe replacement parts are needed and burners, ignitors and regulators get replaced without reason. Depending on how efficient the grill is operating, some grills attached to a tank in check will not ignite and others will light but cannot reach cooking temperatures because the tank has limited the amount of propane released. Sometimes the food will be unable to exceed 200 degrees in temperature because the propane tank is in check.
Gas grill replacement parts are available and are sometimes necessary, low or no gas flow indicates a different typr of repair. Most grillers accept instructions and the problem is corrected in minutes -- but believe it or not I have had a few insist on purchasing replacement parts.
How do I fix grill?
To reset the check valve and get back to cooking on your gas barbecue grill, first
turn everything off. Turn off the grill, the rotisserie, the side burner and the LP gas cylinder tank. Once everything is turned off disconnect the propane tank from the gas grill regulator by unscrewing it or pulling the quick-release on older or retro-fitted propane cylinders. Now turn the grill on. I know, it is dis-connected from the gas tank but we want to ensure that the pressure in the gas lines or any gas in the burners is released. Leave all grill burners in the on position for 3 - 5 minutes before turning them off. Make sure. Most gas grill valves must be pushed in to turn them and if turning is attempted without pushing the knob, they will not turn to the "on" position. With the grill, et al turned off reconnect the propane tank and slowly turn the hand wheel to the open position.
Slowly. The trick here is to turn the hand wheel slowly. Propane in a new or very full tank will be under more pressure, especially with the OPD floating in position. The extra pressure will come through the tank valve stronger. Turn the gas tank slowly allowing small increments of propane to enter the grill.
Once this is complete, you should be able to turn the grill on high and ignite your gas grill burner. Your cooking heat should be back to normal and cooking times decreased. If the problem persists, try this process again to make sure you followed every step. The check valve exists to save your life if there is a leak in any of the gas fittings. Constant check valve issues could imply a gas leak and a visit from your local gas grill service technician may be necessary.
To find a leak, turn the grill valves to the off position and the gas tank valve to the full on position. This should pressurize the gas line. Spray soapy water on all the fittings and look for bubbles just like checking for the leak in a flat tire.
Do not attempt to correct a gas leak on your own. While a check valve error when your gas grill will not get hot or will not ignite is a user education error and an issue corrected by learning about your propane tank, a gas leak should be corrected by a licensed gas service technician. When you are grilling, turn the propane tank on first and then turn on your grill. When you are done cooking, turn the gas tank off first and then turn off the grill valves. The process releases the pressure in the gas grill hose and manifold which allows the gas tank to release pressure by filling these lines. Read the safety features of your gas grill, clean it when necessary and replace used and failing parts. Aside from that be safe, eat well and have fun.
thanks.
Jun 15, 2010 | Weber Genesis Silver B Grill
Genesis Silver B Grill: grill won't heat past 350 or so. put a new regulat...
An odd thing with many propane gas grills is how the regulator functions. If the tank is opened too fast the regulator over-adjusts and delivers no gas. Try this: Turn tank off and open all burner controls. This should clear the line of any gas. Close burner controls and open tank very slow. Now lite and temp should go up.
May 17, 2010 | Weber Genesis Silver B Grill
Flame is low when turned on highest setting
There are a few causes for that.
1. You are low on propane.
2. Your propane tank is overfilled, and the overfill protection device is restricting gas flow.
3. You have turned off your grill using the propane tank instead of the control valves on the grill. This may also cause the overfill protection device to engage. You can reset this by turning off your control valves on the grill, turn off the propane tank, unscrew the hose from the propane tank, then put the hose back on securely, turn on the propane tank and turn on the control valves.
4. Your burners are very rusty and may be clogged. Clean or replace the burners.
Mar 03, 2010 | Sunbeam Grilling
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Gas grill lights but doesn't get very hot
I had this same problem especially when the tank on my 5 burner 2 year-old Kenmore was about half full. The solution above fixed it. I was used to opening the gas fully, turning one burner to high and clicking the button. If I would have read the front of the grill I would have seen that this was incorrect. I turned off the grill completely, unhooked the regulator and reconnected it. With one burner on high I began clicking the button BEFORE I turned on the gas. I slowly turned the gas on one quarter turn and it lit up full flame. I slowly turned the gas another quarter turn and lit the second burner. I slowly opened the gas all the way and lit the third and so on. That did the trick!
Mar 10, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Kenmore 463845504 Grill Logo
1,213 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
