Question about Philips 25PS40S 25" TV
Closed caption always comes on when I turn on TV!
I can turn it off with the remote but it is annoying that it always comes back on when I turn the TV off and then back on, how can I stop it? Model number 27MS4504/17B. Thanks.
  • 3 more comments
  • saywood Nov 12, 2007
    same thing here!!! cannot turn off the CC via the TV menu so we've been using the remote button. now, the button on the remote doesn't work and we can't turn it off!! so lame....
  • Anonymous Nov 22, 2007
    The closed captioning on my tv comes on by itself. I turn it off with the remote but eventually it comes on again. Is there a way to turn CC off permanently? Thanks
  • Anonymous Jan 08, 2009
    I have the same problem - tv on - cc on - I hit the cc button until it says off - but when I turn off the tv and then back on - it's back again! I hope someone comes up with an answer.
  • Anonymous Jan 24, 2009
    Same problem - but can't find any ansers
  • stevejal Feb 12, 2009
    I have had the same problem with my Philips TV since it was 13 months old. 1 month out of warranty of course! I think Philips just has a problem with their manufacturing. As I shop for my new flat screen TVs for the house I will look at any brand other than Philips. Vote with your pocketbook so they get the message and get better quality in their sets.
Suggestion, buy a new TV :o)
I have the same issue, just bought a used tv, no remote, can't turn off C/C
contacted philips for suggestions, may try to purchase a universal remote - the one directv provides doesn't have a cc or pip button either.
Posted on Oct 12, 2008
I can't figure it out either. this happened all of a sudden to my philips tv. man is it annoying.
Posted on Apr 18, 2008
Same thing here!!!!! It is soooooo annoying! Can't do it from the TV and the CC does not turn it off either.
Any suggestions would be so appreciated.
Posted on Jan 11, 2008
    New Friend:
Had the same problem with my Phillips TV. CC was always on when I turned on the tv, even though I turned it off when I used the tv last. I finnally fixed it. Step 1: Turn the TV back on, Step 2: Turn off CC, and turn off the TV, Step 3: Unplug the TV from the wall for 3 minutes, Step 4: Plug the TV back into a surge protected power strip. Thats it! That worked for me. After I did this and turned the TV back on the CC was off.. whooo..
Posted on Oct 23, 2009
SOURCE:
Is there a microprocessor/software reset procedure?
Simply disconnecting power for a period of time should reset it. I would do so over night.
Aug 15, 2016 | Symphonic Televison & Video
How can I turn off CC on my SONY 52XBR. I used the Remote control settings and selected off on the cc display, but the cc never turns off. I also used the menu button on the side of the T.V to select
If Closed Captioning is being displayed even though the CC option in the TV menu is set to Off , then it is being produced by another device, such as a cable or satellite set-top box. To remove the Closed Captioning from the TV screen, it must be disabled on the device that is decoding the Closed Captioned signal.
NOTE: Some set-top boxes may automatically display Closed Captioning on the TV screen when the set-top box sound is muted. If this is the case, turn off the Mute function of the set-top box
Oct 31, 2014 | Sony Tv Xbr Bravia Kdl-52xbr5 52 Lcd Tv...
Can't turn on memorex MT2012 Closed Captioning using a universal remote
You must have its original remote control, which will have 'CC; button on it. you have to press this button once to cancel the Closed Caption option. If you can acccess the Menu of the tV by your present universal remote contro,; get into TVs Menu option, surf through, come to closed capation adjust window, and cancell [OFF] the closed caption option.
Apr 08, 2012 | Televison & Video
The TV keeps going to the MENU on it's own...When you exit to TV it goes back to menu within 5 seconds
Hey djames1971 - did you ever get this resolved? My Philips is doing the same exact thing now; sooooo annoying. If I keep monkeying with the exit setting it eventually goes to the TV and stays there, but it doesn't fix it by any means. Next time I go to turn it on I have the same battle with it.
Jun 15, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
I have a philips 2005 tv model number 2DPT6441/37 closed caption stays on when we first turn the tv on. I can turn it off with the remote by hitting the cc button.
I'd be interested in the solution also my 20PT6245/37 (also a 2005) recently started doing this too. There must be some reset somewhere unless something fried. I use a universal remote, so noe I had to get the Factory remote back out, more of an annoyance now.
They don't build them like they used to ... Zenith Space Command SA 1923W (1984 Model) still going strong with a beautiful picture! Looks & works like new.
Apr 08, 2010 | Philips Televison & Video
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
The closed captions keep coming on. I don't need
Try changing the channels without the remote and see if the problem still exist. If it doesn't the remote is at fault.
Oct 29, 2009 | Televison & Video
Closed Captioning comes on every time i turn on the tv!
Apparently the 2002 Sharp model TV that I purchased has the closed captioning by default if the mute button is engaged. So there is no solution for my particular model, it has been built in this way. The only solution is not to use the mute button and lower the volume instead.
Jan 03, 2009 | Televison & Video
Philips 25PS40S 25" TV Logo
1,144 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
