Question about Dell Inspiron 5100 System Board ( Motherboard ) - N0933 CD-ROM Drive
Dell Inspiron 5100 integrated speakers cannot turn on.
I have checked all the volume controls I can find. The head phone jack is working fine. Any idea's?
  • 326 Answers
Confirm that your BIOS does not have a "Mute PC Speaker" option. Confirm that you have not muted your PC Speaker in your OS. Remove the Palm rest via screws on the bottom of the machine, Remove Keyboard, Confirm that your speakers have not become disconnected/loose in anyway. Speakers are generally connected to the system board below the area of the touch pad.
Posted on Apr 13, 2009
Speakers are plugged in but there isn't any sound coming out of the speakers, yet i know the speakers work i tried them on my laptop
Things to check:
  1. Ensure you are plugging into the correct port. Some systems have both integrated audio and and expansion sound card. If it has both, the expansion card should be the port to connect the speakers. Generally all desktops use Green as the speaker jack color.
  2. Ensure the volume control is not muted. Set volume for 75%
  3. Ensure if the audio is integrated, that the audio is enabled in the BIOS
  4. in Control Panel, Sounds and Audio devices, make sure the sound card is the default playback device. Also ensure that Stereo desktop speakers are selected as the speaker tyoe.
Mar 28, 2010 | Dell A215 Computer Speakers
No sound on my pc
Go to Control Panel, Sounds and Audio Devices
Ensure that sound card is the default playback and default recording device.
Also, if this is a Dimension 5100, then there is a possibility that the system has a upgrade sound card installed in a PCI expansion slot (Below the video card)
If the system has an expansion card, (Soundblaster) then the integrated on-board audio should be disabled in the BIOS (If integrated is on and an expansion card is installed, you get a conflict and no sound) Normally, if the system has an expansion card, the ports are covered with a black plastic cover. If the BIOS defaults are ever reset, then onboard audio needs to be disabled again.
Mar 28, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
The sound will not work on my Dell Inspiron 5100 laptop. I've checked all the settings, volume, and unmute. I know it's old, but...it's all I have! :0)
Go to control panel,then choose system,hardware ,device manager and look for yellow flagged items. scroll down to sound,video,and game controllers. click on audio and update device drive. Also you may copy service tag # down and the go to www.support.dell.com . Under support and drivers there will be a place to enter the service tag. Then you should be able to see a list of updated drivers for that model. You may choose optional, recommended & urgent and they will be displayed. If you attempt to install them be sure to read about the proper order in which Dell recommends that you install them. I recently updated a Inspiron 5100. This model has an updated bios that needs to be flashed ,if yours has not been already. If you arent comfortable doing this, I would highly advise you to have someone with the knowledge on flashing the bios,do it for you. If you have a good understanding of it, there is detailed info on that site.
Mar 11, 2010 | Dell Inspiron 5100 Notebook
Hi iam having a problem with my sound card on a dell inspiron 6000 my head phones work but not the speakers
Pls go to control panel \ sounds & audio devices \ check & configure from audio tab. Also see if there is any switch on the headphones volume line control etc
If this don't work then ur headphone is faulty. Well Hphones are quite cheap!
Feb 06, 2010 | Dell Inspiron 6000 Notebook
Internal speakers do not emit sound but I can hear w/ headphones
I have a 700m, so I'm real familiar with the system. I see one of 2 possibilities. The headphone jack has a switch that disables the on-board speakers, if that is stuck or broken, then the jack/switch must be replaced. (Big hassle)
The other is easier to troubleshoot, then connection from the speakers to the MB goes through the Right hinge cover. Take the hinge cover off, check for broken wires (I has one, ***** to splice too)
Jun 05, 2009 | Dell Inspiron 700m Notebook
Computer speakers do not work on new Dell computer
Check Bios settings to be sure audio is enabled, then go to control panel, click on sounds, and make sure sound is not muted
Apr 14, 2009 | Dell Inspiron 530 Desktop Computer...
Inspiron 530 sound distortion
What kind of integrated sound card do you have?? I am going to assume its realtek. Go to control panel, then open up RealTek HD Sound effect manager and make sure the drop down menu for Environment is on "none". The try your speakers.
Mar 25, 2009 | Dell Inspiron 530 Desktop Computer
How can i raise the volume on my dell inspiron 1525
Here's how I fixed mine with Win-VISTA:
1. Click START
2. Click CONTROL PANEL
3. (Switch to CLASSIC VIEW)
a. Click on SOUND
b. Click on PLAYBACK Tab
c. Click on SPEAKERS/HEADPHONES
d. Click on PROPERTIES
e. Click on CUSTOM Tab
i. Make sure PC SPK MUTE is NOT checked
f. Click on LEVELS Tab
i. Slide PC SPEAKER to 100%
ii. Don’t worry about the SPEAKER slider, it’s controlled by the keyboard buttons
g. Click on ENHANCEMENTS Tab
i. Make sure LOUDNESS EQUALIZATION is checked
h. Click OK
i. Click OK
4. Close CONTROL PANEL
Dec 20, 2008 | Dell Inspiron 1525 Notebook
I have gateway boston digital BA735 on a dell dimension 3000 with soundMAX integrated digital audio sound card but get no sound from speakers. What can i do to get speakers to work?
we have to check whether the issue with speakers or in sound card..just remove the audio jack from computr and touch the jack with ur fingers..u shuld hear some noise in speakers..if u can able to hear that speakerrs are fine and the issue with the sound card..do reply
Jun 17, 2008 | Computers & Internet
Attaching stereo amp to Dell PC
You might need to change to output setting on your sound card controller to a 2 speaker setup in stead of any other setting that it might be set to and make sure that you plug the jack into the green one. Also, you might want to turn the volume up on the outputs, in case it is set too low.
Jan 09, 2008 | Dell INSPIRON 6000 CENTRINO...
Computers & Internet Logo
357 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
