Question about Vizio L32 32 in. LCD HDTV
Vizio 32" Plasma Freezes up
I have a 32" Vizio plasma that is only about 7 months old or so and recently has started to freeze up. For example, the TV will be on for a short period of time and then the screen just freezes with no sound and I cannot change the chanel or even turn it off. The only way I can turn it off is by unplugging it. Is this due to too much heat or is there a known issue with this model. It sits inside an armoirre.
  • hotdog_49945 Apr 30, 2009
    Same thing is happening to me.
  • Anonymous May 24, 2009
    I have the same problem, Vizio replaced it with a new one and it does the same thing after an hour or so.
    Top Expert:
  • Vizio Master
  • 24,726 Answers
A lot of picture freezing issues are signal based. Check the signal strength and quality.
Posted on Jul 24, 2017
  • 80 Answers
The power supply in these sets have had bad electrolytic capacitors which short and actually blow their top because of increased pressure. Only part of the switching power supply is now running so you may see a power light but nothing else. I am not sure what Vizio would charge to replace the cap or supply. If this is the case, we would charge for 1 hour labor ($120.00) and for the capacitor ($3-4.00)unless the manufacturer recommends replacement of the power supply. Hope this helps you. Joe Weibel Custom Electronics (
Posted on Feb 14, 2007
  • 22 Answers
SOURCE: vertical red line on my Vizio plasma
Spent 3 hours removing all what seemed like 100 freaken screws.
Took out the OEM 038A, caution the factory placed some type of heat transfer silicon clear grease on the back of the board so it will feel like it is glued on. Just be very carefull and gentle when prying it apart.
Be warned, you will need a magnifying glas to check those little resistors. They all checked out, no broken solders.
What I did observe is the grease melted down the back of the board and puddled at the bottom of the board and where the resistors sit.
I used rubbing alcohol to clean it all up but left the reside on the square pads. Cleaned the resistors and used a dry paint brush to dust of any lint.
Placed the component back and after 10 minutes the Vertical Red Line Disappeared.
Turned on the set next morning it was still gone. 10 minutes later it re-appeared for a couple of minutes then went away.
I spoke to a kind gentlemen at, he stated that the 060Q is an upgrade to the defective proned 038A ( 038C is also an upgrade ). A tech in Cali stated the 060Q worked perfectly. He has had zero complaints about the 060Q in the Vizio plus he offers a 90 day return policy. Funny thing is the 060Q was designed for LG and Goldstar Plasmas but for some reason they do not work for them but do work for Vizio's. He even states that on his site.
As I type the red line is still gone and stayed off several hours last night.
I think I am going to pull the trigger and replace the 038A to the 060Q and be done with it.
Oh yeah, I asked him if the 060Q needs to be "flashed" with the Vizio program. He never heard of it requiring it.
He has 038C on order they are couple of bucks cheaper. the 060Q is $224 plus S&H.
I found on ebay for $184 free shipping but waiting for the guy to verify no "flash" requirement.
Hope this helps someone.
Merry Christmas and a Happy New Year!
P.S. use a power screwdriver, your wrist will thank you. I put mine on low torque as not to strip the heads.
Posted on Dec 23, 2008
  • 13 Answers
SOURCE: Vizio tv chanel search is not finding digital chanels.
On your remote, select input as TV, then verfiy that you have set to Antenna, Then scan for channels.
Posted on Mar 18, 2009
  • 557 Answers
SOURCE: vizio 32" plasma 1st clicked off & on 4-5 times
Power supply board. Some times you can find bad caps on the board, if not have to replace board.
Posted on Sep 27, 2009
SOURCE: Vizio 42 Plasma Pop
My 42 Inch Vizio experienced the pop of death out-of warranty. I bought mine at Sears and they sent a technician over within a day or so. It turned out to be in the power supply and they shipped a board right out. Total including parts and labor was $280. Although no expensive TV should die after less than 2-years, Sears seems to be able to deal with repair in the home without drama.
Posted on Sep 30, 2009
I have a 50" Vizio plasma tv that is about 5 years old. Recently when I turn it on it cuts off or blinks. I have to turn it off and back on several times in order to get the picture to come on. I am s
Yes it's. Just bring it 2the nearst electronic shop for repair. T power my be spoile or some insect get inside n make it burn. It's ever happen 2 my tv also.
Dec 04, 2012 | Vizio P50HDTV20A 50 in. Plasma HDTV
Vizio 50 in plasma screen dim
If there is no auto dimmer on the TV, than the TV needs professional repair work.
Nov 14, 2017 | Vizio P50HDTV10A 50 in. Plasma HDTV
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
The Service Plan from Walmart is an "extended plan" on top of the manufacture warranty. Your Tv is still under warranty from the manufacture.
Here's a link to get the info you need to get started on a warranty claim:
Jun 27, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Similar issue with Vizio 32" plasma - turning on and off repeats
Possibly startup circuitry or microproc that handles turn on
Jun 17, 2009 | RCA 20F512T 20" TV
Does not turn on at first only clicks and flaskes
Where did you bought the TV from? Your TV still under warranty. Give Vizio a call, they will take care of it.
Feb 10, 2009 | Vizio VP322 32 in. Plasma TV
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
VIZIO 42" Plasma HDTV
i have a vizio p42 and i have sound but no picture i have tryed to reset it but nothing works
Nov 24, 2006 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio L32 32 in. LCD HDTV Logo
278 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
