Question about Nokia 6070 Cellular Phone
Sim card rejected / insert sim card
Dears, water spilled in my mobile 6070, i switched off the machine and dry it under light heat for seveal hours, after switch ' insert sim card ' message comes or ' rejected sim card ' pls tell how to solve this porblem - abdul haq
  • 6 more comments
  • Anonymous Feb 21, 2008
    hello.i tried to change the puk number after 2 times i get the messege that the sim card rejected my phine is nokia n70 ans the sim from cellcom israel
  • Anonymous Mar 16, 2008
    66070 insert sim when its fall water than insert sim problem
  • jennifer_ung Jul 02, 2008
    i tried to make a pin i tried it again and again then it had a puk code then i did the puk code and the new pin and my sim got rejected
  • Anonymous Mar 13, 2014
    insert sim card problem
  • Anonymous Mar 14, 2014
    hi my mobile shows sim card rejected nokia 108
    how to solve
  • Anonymous Mar 20, 2014
    I have nokiu 6070.SIM card is damaged me. How can i open SIM card and receivers data from her. give proposals on your site have failed to help. thank you in advance for the answer.
  • Anonymous Mar 30, 2014
    What is thet solutions
  • 626 Answers
Unfortunately, they usually fault after getting wet. You might want to take it to a local repair facility and have them check the internal circuitry. Best of Luck.
Posted on Sep 12, 2007
Most likely sim card reader ic is spoilt n nd to b replace by an expert. shaun.
Posted on Nov 22, 2008
  • 43 Answers
Hi abbu,
             before takin it to repair, jus give d following try...
take a claen, dry, soft cloth...wipe the area where u insert ur sim and d visible circuits thoroughly and insert it again and see...if it doesn't work, take it to d shop where u bought d mobile( if d mobile is within d warranty period) or to a mobile service center
Posted on Jul 03, 2008
Jhnjnjknk
Posted on Mar 19, 2008
    New Friend:
My sim has rejected when rise in morning
Posted on Dec 13, 2009
I havea noka 6070 has insert sim
Posted on Oct 14, 2009
2 Suggested Answers
SOURCE:
mixmaster
  • 626 Answers
SOURCE: sim card rejected / insert sim card
SIM card rejected means the SIM card has failed, it needs to be replaced.
Best of Luck.
Posted on Nov 22, 2007
How to repair sim card?
Some of the reasons why sim card getting rejected in your mobile
1.Bad SIM -if it wasn't unlocked you had get a message asking you to enter a PIN.Get the pin from an online vendor like http://www.wickedunlock.com/supported-phones/rs11wp7/ .
2.With a warning that you have 10 attempts to enter the correct PIN code or it could be locked forever ,if you don't get that message it's "mostly likely" unlocked.BUT find a phone with a known working SIM and see if it will work and connect to the network.
3.May be a hardware problem try flashing with a custom rom.
4.This has to be a problem with the SIM card slot, which is soldered down to the logic board. It's possible that it's a mechanical problem , you might be able to open it up and discover that the card-detect switch is failing to detect SIM card insertion.
5.The os system has been updated and your phone is not being recognized with the right settings , this happened after a update a year or two ago..
Jan 24, 2014 | Nokia 6070 Cellular Phone
Insert sim card 5320
What is your problem with your Sim card? Is your phone shows the "No Sim" or "Insert Sim" or "Sim Rejected" or "Invalid Sim" error? If it is so i am here to help you. If your Nokia shows the "No Sim" or "Insert Sim" error then remove your Sim from your mobile and place it again correctly. If your mobile shows the error message "Invalid Sim" or "Sim Rejected" the your phone is locked to a particular network. To fix this problem you need to unlock it. Use unlock code to unlock your Nokia 5320. To get the code you have to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:
1)Go to Options>status
2)Find IMEI on the back of your mobile, behind the battery.
3)Type *#06# and press call button. It will display your IMEI number.
You can find the network provider to which your mobile is currently locked by switch off your mobile and switch on it again. A logo of the locked network will get displayed on your mobile screen. After knew all these get the code from the site Theunlockarena.com ,by submitting these to them. Unlock it yourself using unlocking instructions which is given in the site itself.
Jul 24, 2013 | RIM Cell Phones
Insert sim
What is your problem with your Sim card? Is your phone shows the "No Sim" or "Insert Sim" or "Sim Rejected" or "Invalid Sim" error? If it is so i am here to help you. If your Samsung shows the "No Sim" or "Insert Sim" error then remove your Sim from your mobile and place it again correctly. If your mobile shows the error message "Invalid Sim" or "Sim Rejected" the your phone is locked to a particular network. To fix this problem you need to unlock it. Use unlock code to unlock your Samsung B5310. To get the code you have to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:
Jul 21, 2013 | Samsung B5310 Cell Phone
My sim card got rejected in nokia 2626 what should i do now?
try inserting different sim card.. if it works, means that you have to buy a new sim. if it doesn't, you may have a problem with your mobile phone.
Dec 09, 2009 | Nokia 6070 Cellular Phone
Insert sim card issue
just insert another sim card and check whether that sim card is working. also put your sim card in to another phone and check whether it is working.
Jul 27, 2009 | Nokia 6070 Cellular Phone
NOKIA 3230 phone rejects SIM card after it was fallen in water
Take the sim card out and wipe the contacts clean for both the sim card and the phone. You can use a clean business card to clean the phone side.
Jan 24, 2009 | Nokia 3230 Cellular Phone
Sin card rejected
you must have typed in a wrong pin code. contact your network provider and they will unlock it for you
May 07, 2008 | Nokia 6070 Cellular Phone
Best of Luck.
Nov 22, 2007 | Nokia N72 Cellular Phone
Felt into water
try by changing ur sim,,or ry in another handset,
Sep 07, 2007 | Nokia 6080 Cellular Phone
Nokia 6070 Cellular Phone Logo
1,552 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
