Question about AEG B3101-4 Electric Single Oven
Oven gets too hot AEG B3101-4
After about 10 minutes the rear of the oven above the fan glows red hot and this is not the element. PNC 944 185 047. Is it the oven thermosat or an internal sensor. The sensor which can sometimes cause it to cut out looks OK and is not charred
Aeg B3101-4, oven turns itself off and takes 20 minutes to come back on. If put on above 150 it cuts off after a short while
Posted on Sep 20, 2009
  • 431 Answers
Hi I am Vortash This sound like the thermostat cut out switch and if it is glowing hot then you have a serious DANGEROUS fault
it means that it is not disconnecting as it should and has shorted ot .. please get it changed immdeatly as it may short to the oven body causing it to become live .. now that should mean that the house fuse should blow .. but on the slight chance it don't you would be electrocuted if you touched the oven please call a domestic service engineer now Regards Vortash
Posted on May 18, 2009
We cooked pizza at 500 something popped and now our oven cooks but not right , any ideas
If you have an electric range, look at both the top and bottom elements while oven is cold. Look for a rough spot like a hole in the element. You may have just burned out one of the elements. Sometimes they go bad without any marks. Turn on oven to about 350 and watch the bottom element to see if it gets red hot. Then set for broil and watch the top for the same red hot glow. If either does not glow red after 5 to 10 minutes, that element is bad.
Apr 02, 2016 | Ovens
Should the element in a fan assisted oven oven glow red
When the fan is blowing steady across a heating element, it most likely won't allow it to get red hot
Mar 04, 2015 | De Dietrich Ovens
I have an AEG D8800 4M oven. Oven overheating to the point where element glowing and had to turn off quick. Tried again next day on low setting and although control panel bleeps to incate required...
If it is a fan assisted oven, then make sure the fan is working o/k, if it is, then I would suspect that the oven thermostat is faulty and needs to be replaced.
Jan 23, 2011 | AEG Ovens
Competence 5208B, fan oven blows cold and won't heat up, ordinary (non fan) oven does get hot
Hi.
You need to replace the oven element, located at the rear of the oven compartment behind a removeable cover.
Nov 09, 2010 | AEG Ovens
Oven does not work with ventitherm fan opereated cooking option. It does not get hot.
I suggest you fit a new fan oen element, located at rear of oven compartment behind a remoeable cover.
Oct 11, 2010 | AEG U7101-4 Electric Double Oven
Aeg d5701-4 bottom oven slow to heat up and does not reach set temperature fan works
It sounds like the oven element is not working.
To check it, remove rear panel in oven compartment, after running it for a few minutes, it should be very hot to the touch, BE CAREFUL, DO NOT BURN YOUR FINGERS.
Apr 21, 2010 | AEG D5701-4 Electric Double Oven
Hi, I only just installed Baumatic single built in fan oven (B0616SS). I did as instructed and left on for 39 - 40 minutes at max 250 temp. I noticed that the oven door was very hot to touch, too hot! This...
Hello- This is a brand new model, but it works the same as the rest. Heat is produced by the elements. The fan has an element that glows when heating the air. --Convection oven glass gets hotter than normal fanless models.-- This is all normal operation of the oven.  To ensure full life of oven, avoid using the 'self-clean' feature. Techs call this the 'self-destruct' cycle. Please reply to this post if info is helpful- have more if needed- Thanks- Ed
Mar 19, 2010 | Baumatic B604SS Stainless Steel Gas Single...
Heating elementglowing bright red funny smell
I
make sure the fan is working o/k, because if it is not, then the element will get bright red hot.
If the fan is working o/k, then the element will still get red hot, but not bright red.
If the fan is not working, then it needs replacing.
Jan 15, 2010 | AEG D5701-4 Electric Double Oven
Aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Jan 27, 2009 | AEG B2100-4 Electric Single Oven
AEG U7101-4 Top Oven tripping the fuse after a few minutes
It is more than likely the oven element, as it gets
hotter the insulation in the element is breaking down and causing the trip to operate..
Remove the panel at the rear of the oven and you will see the element there, undo the screws and pull the element towards you, carefully, detach the 2 wires and remove the element.
Be careful not to lose the 2 wires behind the oven rear.
Replace with new element.
Cannot give you a part number, you will have to go to aeg web site.
Dec 12, 2008 | AEG U7101-4 Electric Double Oven
AEG B3101-4 Electric Single Oven Logo
513 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
