Mintek MDP-1720 Portable DVD Player Logo
Posted on Apr 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unable to play dvd's on my mintek portable dvd player
I have a mintek 7" TFT monitor portable dvd player, when i load the dvd, the screen says loading and the movie never starts playing. What is wrong with the unit ? When i push the play bottom, never comes out of loading mode.
  • Anonymous May 16, 2009
    Unable to play dvd on my mintek portable dvd player...loading appears but does not play movie. Any advice as to what to do???
Anonymous
Level 3:
  • Master 432 Answers
  • Posted on Apr 13, 2009
Anonymous
Master
Level 3:
Answers
432
Questions
0
Helped
197704
Points
1334
I would get an optical laser lense cleaner ( it is basically a cd that has fine soft brushes on the underside to clean the laser lense )
something like :
laser lense cleaner link
tip
Mintek factory solution for the forever loading disc problem.
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
My 9" Coby V.ZON TFDVD9109 Swivel Widescreen Portable DVD Player won't charge but will turn on and stay on as long as I have a charger hooked up what can I do about that
Coby TFDVD9109 9-Inch Widescreen TFT Portable DVD ...
www.amazon.com/Coby-TFDVD9109-9...Widescreen...
Amazon.com, Inc.
Rating: 3.6 - ‎52 reviews
Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ... has never been easier with the Coby TFDVD9109 9" Portable DVD Player. .... The DVD player finally stopped working, won't load discs anymore, gives error message. I had a ... I'm currently doing my research for a new a player but likely will end up ...
Coby TFDVD7009 7-Inch Portable DVD/CD/MP3 Player, Black
www.amazon.com/Coby-TFDVD7009...Portable-Play...
Amazon.com, Inc.
Rating: 3.7 - ‎240 reviews
Ac Power Adapter Cord for Coby Dvd Players Tfdvd1029 Tfdvd7009 .... So in my case 5 zone is needed and it worked well. ... There is inconvenience in charging. ... that once you unplug the battery the connection is so cheap that it won't reconnect. .... Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ...Missing: tfdvd9109
Coby Electronics TF-DVD7006 7-Inch Widescreen TFT ...
www.amazon.com/Coby...DVD7006-Widescreen-Port...
Amazon
Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
The screen goes black and it does not read the disk
There should be a switch on either side of the DVD player that says "TFT" and something else.
Shut the DVD player down, move the switch, and turn it back on.
Hope this helps.
BTW, the the switch lets you choose between using the output A/V cables and the DVD player screen.
2answers
Portable dvd player
the laser may be broken,and can not read...
2helpful
WILL NOT PLAY A DISC
Screen comes on, disk turns, loading starts, and doesnt stop
7" tft monitor portable dvd player
I have 8.5" TFT widescreen Monitor Portable for three years. Now when I turn it on, it only has sound, the picture only has one second blink, then dark.
I am now in Shanghai,China, is there a service in Shanghai which I can go physically to get it repaired?
xujingcan
1helpful
2answers
Battery life
Where can I find a replacement battery for my Mintek DVD player MDP-1030?
Top Mintek Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
