Question about Amana 3.2 cu. ft. Top-Load Washer
Inglis dryer-spinning,not heating,Inglis washer not spinning well
Has been taking longer and longer to dry our clothes.  Part of this is that our washing machine purchased at the same time is not spinning the clothes dry as well.   Now the dryer is spinning, but not giving any heat.  Can this be repaired, or should we be looking at a new washer and dryer
Your heating element is going out. Mine did this a few months ago. It is an easy fix. Look up the part online.
Posted on Apr 13, 2009
Why do clothes take a long time to dry even if dryer is heating?
One basic reason is your washer could NOT be spinning most of the water out, therefore your clothes are wetter than they should be, thus taking longer to dry:-)
Jan 22, 2015 | Whirlpool Dryers
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
Heats up, drum spins, takes 3-4 cycles to actually dry clothes
dryer vent hose is pluged or pinched against wall remove from back of drier and check hose also check outside vent it should have a flap make sure flap opens also make sure there is not a screen in outside vent sometimes roofers get them mixed up with bathvents
Apr 12, 2010 | Whirlpool Inglis IP8200 Dryer
Dryer is not working
The air heater and the blower requires to be tested/checked.
Apr 06, 2010 | Malber WD1000 Front Load Washer/Dryer
We bought our maytag washer/dryer in 2007. Washer does great, however our dryer is the problem. It seems to take longer to dry clothes, than any dryer that we have had, also the clothes "ball up", which...
are u sure the belt isnt sliping somtimes if u over load or have a lot of cloths in it that will ball up the cloths and haeting problem either the vent tube is stopping up or heating coil is going out
Oct 23, 2009 | Dryers
Amana les60aw gets hot in dryer but clothes wont dry. cleaned out vent, shortend exhaust hose. noticed an orange glow coming from back vents when i turned it back on???
The orange glow is the heating element working. It mush have good air flow or the coil will burn out and stop heating. Also the thermal limit will stop the heat if to great. If you went all through the vent and the tubing is not smashed or flat check the outside vent for air circulation, if good try to dry a load of clothes. Are you sure your washer is spinning out well? Wet clothes take longer to dry.
Oct 20, 2009 | Dryers
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Estate Dryer takes too long to dry load
Since you say the vent is clear, Make sure that the lint filter is cleared before each load. Make sure the door shuts close and is reasonably sealed. If the dryer draws air past the door, it is not fully drawing heat from the element or burner. Also make sure the washer is doing it's job in the spin cycle. It takes much longer to dry fabrics that are still soppy wet. You might try resetting the washer in the spin cycle to further evacuate the water from the clothes before placing in the dryer. See if that makes a difference. Maybe the washer spin is just being lazy. If it's a top loader it may have a loose belt causing the problem.
Dec 16, 2008 | Estate Dryers
Amana 3.2 cu. ft. Top-Load Washer Logo
686 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
