Question about Kyocera FS- 4000DTN Laser Printer
Error 0150: eeprom error, requires firmware
Hi, I have a Kyocera FS 4000 with error code 0150 and i'm having trouble getting hold of the firmware to fix this.
My email address is waynechurchill@blueyonder.co.uk if anyone's got it please could i have a copy.
    Sniper:
  • 62 Answers
Common issue....just update firmware and your good to go
Posted on Jan 06, 2010
  • 630 Answers
SOURCE: My ecosys fs-3900dn printer gives this error 0150:0119695
It is a "mechanical error". The part after the colon is the number of pages printed. It's probably worthwhile taking the trays, toner and cartridge out and opening all the access doors and checking for something obvious before calling in an engineer.
Posted on Jul 19, 2009
Soulvisitor
  • 1113 Answers
SOURCE: kyocera fs 3900dn printer
It needs a firmware update, very common, it would most likely be under warranty, if not post email so I can give you the firmware update required and I will instruct you on how to upload it to your quality printer.
Posted on Nov 27, 2007
SOURCE: Kyocera FS-2000D
install new firmware
Posted on Dec 18, 2007
SOURCE: accidently flashed firmware to r270
at the moment it appears you cant write the eeprom from an r265 using the r265 and r270 adjustment tool.
i have managed to get hold of the r265 eeprom from a printer at work but unfortunately you cannot write it back to the incorrectly flashed printer.
oh well never mind :(
Posted on Apr 29, 2008
Soulvisitor
  • 1113 Answers
SOURCE: regardin kyocera FS-2000D
The files called 2000sys.zip & 2000_eng.zip I beleive, if that helps. I bet after you have updated the firmware, you will find the serial number absent from status page, muz get corrupted when the engine firmware chucks the 150 error, Just thought I'd say although is not norm a problem
Oh, It only ever does the 150 once, never if firmware is updated.
Posted on Nov 13, 2008
How to fix the error code c0150
You will need a service engineer to fix this problem it will either need a new main board or a firmware update
0150. Engine PWB EEPROM error Detecting engine PWB EEPROM communication error.
Mar 12, 2015 | Kyocera "FS-3540MFP Copier, FS3540"
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
I HAVE A KYOCERA ECOSYS FS-4000 DN PRINTER. WHEN I TURN IT ON, I GET AN ERROR MESSAGE STATING "CALL SERVICE 0150:0003704". WHAT DOES THIS MEAN AND HOW DO I FIX THE PROBLEM?
The error indicates -
Causes - Improper installation engine PWB EEPROM. Check the engine PWB EEPROM installation,
- Defective engine PWB. Replace the engine PWB
IF turning the printer off and unplugging then plugging back in and turning back on doesn't correct the problem I would suggest you contact an authorized Kyocera service center such as www.gfbm.net.
Jan 24, 2011 | Kyocera FS-4000DN Laser Printer
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
I have a kyocera FS-2000D with error code: Call for SErvice 0150:0000049. Help...thanks in advance
0150 is a problem with either the engine board or the EEPROM chip that sits on the engine board. If you want to do it yourself, you can open the printer up and reset the chip on the board as well as reset all of the connectors that plug into the board. Otherwise, your best bet is to call a Kyocera service technician.
Mar 17, 2010 | Kyocera FS-2000D Laser Printer
Jul 19, 2009 | Kyocera FS-3900DN Laser Printer
My Kyocera fs-3900dn has the message: call service 0150:0040557. What does it mean?
0150 - Engine PWB EEPROM error. Detecting engine PWB EEPROM communication error.
Solutions:
1. Switch the printer OFF; unplug the power cable; wait 20 seconds; plug in the power cable; switch the power ON, If the error comes back follow the next solutions:
2. Update / Burn the latest firmware version. You may need to call a Kyocera Service Provider because you need a CF card (compact flash memory card) and the FIRMWARE.
3. Replace the Engine PWB (a board) - again you have to call a Kyocera Service Provider.
Dec 30, 2008 | Kyocera FS-3900DN Laser Printer
Service call error
How do. replace the Rt. bush for the transfer roller have part but
having trouble removing and replacing it?
Chris
Feb 23, 2008 | Kyocera FS-4000DN Laser Printer
Any clue what error code 6030 is?
I had the same problem. Pull the Fuser and check Conector.Sometime pieces of paper inside the Conector raises an error.
Please Rate .
Jan 11, 2008 | Kyocera FS-2000D Laser Printer
Kyocera fs 3900dn printer
Nov 27, 2007 | Kyocera FS-3900DN Laser Printer
Kyocera FS- 4000DTN Laser Printer Logo
538 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
