Question about Nintendo The Legend of Zelda: The Twilight Princess for GameCube
I cant get past the gorgon gaurd in the mines.
On the magnetic floor
Where is the magnetic floor???
Posted on Apr 22, 2009
I can not get the fence guard to work properly. it binds on the wood that I'm cutting and does not allow me to lower my blade lower than about 1"
A mitor saw? If so, that little flap attop the blade gaurd is there for you to help the gaurd pass the cut area with your thumb. Mine does that too on materials over 3" thick. BE SAFE! Rest your thumb of your trigger hand on the gaurd flap, and help it out when it sticks, once you get going, the gaurd will move freely... I hope I helped you, and had the right saw in mind, if not, let me know!
Sep 24, 2011 | Ryobi Garden
Forgot how to break enemies shields on god of war 3
Hello Alicia, if I'm correct you've just passed through the music puzzle and now going down an elevator.
Notice that other enemy in there with you: the gorgon / snake woman, kill the gorgon. Do the circle command to initiate the sequence and killing the gorgon will petify the shield enemies, break them. If you failed to kill them all before they break the freeze stone, the snake woman will continue to reappear until you successful kill them when they become stone.
A simpler way to do this is try to grapple her. Just use the circle button not the combat grapple. If you do that she will try to freeze you almost every time then just counter with L1 and press what button comes up on the screen and it will freeze them.
Later on in the game you'll get the Cestus, a stronger weapon which can break them
Have fun
Jul 11, 2011 | Video Game Consoles & Games
We just spent the last 3 hrs putting our Bowflex Treadclimber TC5300 together only to not be able to start it. We cant get past the screen that says insert e-stop magnet. Of course we inserted the magnet...
HI check the magnet socket is clear and clean , check magnet and wire and clip of any damage . you can try and put a magnet in the socket this should make it start . Don't throw it out , its a great machine I have one love it the works outs are very good not easy . Hope this helps
Jan 29, 2018 | Bowflex Treadclimber TC5300
GE Potscrubber disher - water leaks out while filling
I would try removing the cover and make sure the float isn't sticking. On mine the float pushes on a rod that goes through the tub to a micro switch. When you hit it, it probably frees it up for a while. Hope that helps.
Jan 21, 2010 | GE Dishwashers
How do you get the deck belt back on the pulleys? 20 hp-46'' deck
It helps to remove the belt gaurd on the left side of the deck. The belt gaurd on the drive pulley ( motor crank) can be pulled out and moved by hand- lay on left side of mower and reach across and pull right side of belt gaurd from hole in frame and swivel away. Once belt is installed slide gaurd back into hole. all other pulleys the belt can just be spun on past the gaurds. Be sure to replace all belt gaurds and saftey devices as they came from the factory.
Nov 24, 2009 | Mtd Garden
Detergent drawer will not close and washer will not run.
pull draw out on right hand side fron you will see a little square recess,,,there a sensor on the in side of the main control,,if you cant seem to place take another magnet and place it on the side of control..and thats where to put the magnet
Jan 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Help please
ok before you fought some gorgons and some undead, in the hallway that leads you to the place where you get the shield there should be a big crate or a box filled with like wood or stone fragments take that box and go in front of the door and then kick it to the button pedestal that operates the swinging door and make sure it goes on top of it and stand on the door but make sure you hold r2 until hes powered up the kick
Oct 13, 2008 | Sony God of War for PlayStation 2
I have a 20 qt Hobart Mixer. The magnet that is needed to allow the unit to run, is missing. We have used a store bought horseshoe style magnet for the last year or so, but does not work now. Do you...
the magnet is in the front gaurd. I suspect you have it taped on the back. looked behind the gaurd and you will see a small nut with a threaded stud looking thing in the neck of the mixer this is a electricl switch the magnet works. maybe your magnet is not ligned up on it or the switch is bad and you need a new one. the head is held on with 4 bolts onder the head is the switch and another switch for the bowl lift. . Best solution is have your front gaurd on and sliding corretly get a new magnet for it and it will lign up. If I cam and fixed it only way I would is with gaurd magnet. Can you tell I am factory trained and been drilled by Hobart lawyers many times. LOL never bypass a Saftey
One thing if mixer does not run at all it could be many things On/oof switch, Timer, bowl lift shwitch. Gaurd switch, realy that runse it in gaurd models. so be to be sure you need me LOL kidding. Good liuck
Sep 11, 2008 | Hobart A200 Stand Mixer
Mixer has just stopped
The front wire gage to the gaurd does have a white plastic encapsulated magnet to operarte a switch behind the gaurd on the neck no magent no worky
Sep 10, 2008 | Hobart AM14-253 Free-standing Dishwasher
Nintendo The Legend of Zelda: The Twilight Princess for GameCube Logo
99 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
