Question about Asrock P4I45GV R5 Motherboard
No display processor fan working and l e d light is working in mother board , no display ,graphics card working ,no beep sound
  • Anonymous Feb 12, 2008
    no display
  • JBVJ Mar 12, 2008
    No display, no beep sound, fan cooler is good, led of turned on is on, but hdd led is off. I disconnect everything and unplug everything, them plug and connect everything again and the problem persist.
I don´t think can be a ram problem because a replace with other rams and the problem persist
Posted on Mar 12, 2008
May ur grafic jumper pluged incorect! or may be mainboard damged on grafic chipset! check with grafic card slot if proplem persist, contact me with email to give you some advice [email protected]
Posted on Sep 13, 2007
Ram problem,
Posted on Sep 12, 2007
SOURCE:
Intel g41wv mother board ram slot problem for solution
1.) check with alternate Monitor
2.) Check with alternate power supply
3.) Check with Alternate Video Graphics Card
4.) Check with Alternate Processor
5.) Check with Alternate motherboard
6.) Check with alternate RAM
Feb 28, 2013 | Intel Computers & Internet
Display problem
remove your processor and the processor fan clean the processor surface with a clean cloth and fix it to the socket apply a thin layer of heat sink compound and fix the heat sink firmly to the processor remove your memory card and clean it with a neat cloth and insert it in the slot and restart the computer still not working remove the memory module and restart your computer you will hear long beeps now insert the memory and restart your computer if you hear only one short beet and display not coming add an pci or agp graphics card if it work the problem is with your graphics section in the motherboard
Nov 15, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
760 core i5 processor not working on 55tc mother board gives beep sound
dh55tc - i5 7series combination required additional graphic card
onboard graphics wont work. and for i5 6 series not required, onbord graphics work. http://processormatch.intel.com/CompDB/SearchResult.aspx?BoardName=DH55TC
Oct 19, 2010 | Intel DH55TC Motherboard
I have Intel DH55TC Mother Board cannot get display when i remove ram from board board get beep & i also change ram but same problems
Always Provide Proper Details.
1. Processor
2. Motherboard
3. RAM With Company Name
4. Graphics Card Detail
After Reading Ur Comments I Want 2 Know How Many Beeps You Hear....
Beep Details.......
2 Beeps Shows Graphics Problem
Use PCI-E Graphics Card Like ATI OR NViDiA.
3 Beeps Shows RAM Problem
Use Another RAM OR Try The RAM In Another Slot OR Channel.
Hope This Helps....
Oct 11, 2010 | Intel DH55TC Motherboard
Mother board no display
Looks like the lights are on? Fans spin? Sounds like the harddrives spinning? The power supply is bad. has just enough power to light lights, and spin fans, but not enough for the processor. (No beep sounds, because BIOS hasn't done a memory count. It's not going to)
ALL the lights use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
The harddrive just sitting there spinning, uses about 5 watts.
Processors use 55 Watts to 125 Watts. Depends on the processor.
Not enough power to turn the processor on, the computer won't work. Computer isn't working there isn't anything to turn the monitor on. No Signal.
Apr 17, 2009 | Intel Motherboard
Motherboards is running but no display..
mother board have a problem,if warranty is still now u sent mother board service center,my friend is same problem,he send mother board and now it is ok.
Mar 31, 2009 | EliteGroup ECS P4VMM2 Supports Intel...
Mpga478b
have u check ur memory?... ur videocard and powersupply...thats the main problem of pc if it has no display....just try it one by one...hope it can help u
Sep 10, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Gigabyte mother board ga-6bx7+
You might have damaged the CPU/ motherboard during the process of overclocking.
Check your CPU on other compatible mobo.
Check your mobo documentation properly & set the jumpers rightly. If that doesn't help, you will have to replace the mobo.
Jul 01, 2008 | Gigabyte GA-6BX7 Motherboard
Mother Board Display Problem
you did not specify clearly what display problem your having...
Is it something like there is no display, or is it something that youre having problem adjusting something on your display. Pls make it more specific..
Anyway, if there is no display as you turn on your computer.
Check if it boots up and if you hear a beeping sound.
if it boots up, then try to reconnect the graphics card that should somehow solve the problem your having.
If it still hadn't try to reconnect your video to the onboard graphics card that your motherboard has.
Dec 16, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel 845 GVSR
90% in d845gvsr cpu dry problem , when we press fan after that swicth on the system may be it's giving display solution is bake cpu socket at 200 digree C, after it's working fine otherwise there is no solution. cpu socket problem like hang, restart, some time display , just bake the cpu socket with hot air gun or bga machine,
Nov 11, 2007 | Intel Motherboard
Asrock P4I45GV R5 Motherboard Logo
156 people viewed this question
Top Asrock Computers & Internet Experts
Ekse
Thomas F. Schneider
Joe Negus
Joe Negus
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
