Question about Gigabyte GN-B46B Router
Pleess help me !!!
I need the user name and password for Gigabyte GN-B46B Router
in the default .....thanks alooot you heer
jad
  • rama_interne Apr 13, 2009
    thanks aloot evre byde thaaaaaaaanks
  • 131 Answers
By default, both the username and password on your router are admin
Posted on Apr 13, 2009
  • Gigabyte Master
  • 6,487 Answers
By default both the username and password are admin. Click the Ok button to log in to your router.
  • Mark Gil
    Mark Gil Apr 13, 2009
    If it didn't work, reset the router so it will be back to its default settings with default user name nad password...
  • Mark Gil
    You're welcome dont forget to rate the solution FIXYA thank you,,,,
I lost my network security key for Gigabyte GN-B41G wireless router - I need to add another computer to my home network.
Connect with your existing computer (either wired or wireless)
  • click start
  • click run
  • type CMD
  • type ipconfig and press enter
  • note the default gateway address (should be something like 192.168.1.1 for example)
  • etype exit and press enter
  • open a browser
  • enter the gateway address in the address bar i.e. http://192.168.1.1 as per the above example
  • This will take you to the login screen for the router or the setup screen in the router
  • you may need the login details for the router (if you don't have these then try the factory defaults for your router type, which you can get with a quick google search)
  • You can then find or reset the wifi key on the WiFi section of the configuration pages.
(note if you can't get into the router you can do a factory reset, HOWEVER you need to make sure you have all the broadband user account settings to attempt this)
hope this helps
Please take the time to rate this answer.
Many Thanks Don.
Sep 05, 2011 | Gigabyte GN-B41G Router
I forget passward and user name user name : admin password : hsparouter but not access it give me 401 Unauthorized
The easiest way to recover entry to your router is to hard reset the router by using the tip of a pen and pushing it into the reset button on the router for at least 15 seconds. The router should then reset to defaults, which includes the user name and password.
The default user name and password should be listed somewhere on the router. If it isn't, then search online with your router's model number to find the default user name and password and default IP address. For example:
IP Address: 192.168.1.1
Username: admin
password: password
Your router may be different but it should be somewhat similar to my example.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
Jun 02, 2011 | Computers & Internet
Zhone 6212-I3-200-0PA, What is the default username and password for this router?
its usually default:
admin
admin
or
admin
pass
or
admin
(no password)
try them and let me knw how you get on?
Mar 08, 2011 | Zhone 6212-I3-200 Router
How do I change the password for the router? Gigabyte GN-BR01G
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 16, 2011 | Gigabyte GN-B49G-WPEAG Router...
I can't access my linksys router set-up page. I keep getting this message: "401 unauthorized" authorization required
" 401 unauthorized" authorization required " .This message means the user name and password for the router is not correct. the default password of the Linksys router is admin with no user name ( leave it blank )
If the default password is not working then the router password must be changed.
If you don't know the password of the router then you will need to reset and reconfigure the router.
Once you reset the router , it will come back to the factory default settings.
Click here for more info about router and network
Jan 08, 2010 | Gateway Wireless-B Router (wbr-100)
I don't know if my router has upnp, how can i find out?
First connect your router to computer with ethernet cable.
then access it with following link
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
then go to advanced -> UPNP check it is neabled or not.?
Let me know if you need more assistanse.
Thanks.
Aug 27, 2009 | Gigabyte GN-B49G-WPEAG Router...
Gigabyte GN-B49G SSID Change
What is your operating system and are you using any special programs for wireless connectivity?
Apr 25, 2008 | Gigabyte GN-B49G-WMAG Router (GNB49GWMAG)
What is the default user name and password to login the Prestige via the browser?
To restrict only the adminstrator can configure the router, there is a login procedure prompted for asking User Name and Password. The default User Name is 'admin' and the default password is the default SMT password, '1234'.
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
Gigabyte GN-B46B Router Logo
194 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
