Question about Brother MFC 7420 All-In-One Laser Printer
Back door closed
In printer one message is coming back door open
  • 163 Answers
Dear sir the the back door sensing switch or sensor is not working check it may be it is broken or faulty or may be it is only dusty clean it
Posted on Sep 26, 2007
SOURCE:
Code 3514 keeps coming one
Error: "Rear access door open" (3514)
How do I resolve the error message "Rear access door open" (error code 3514)
To clear the "Rear access door open" error message:
  1. Remove the rear access door from the printer.
  2. Reinstall the rear access door on the printer and verify that both latches are securely engaged.
  3. Unplug the AC adapter from the printer.
  4. Plug the AC adapter back into the printer.
  5. Wait for the printer to initialize.
  6. Verify that the error has cleared.
Mar 18, 2011 | Kodak Office Equipment & Supplies
My p0rinter is not printing with good color quality. Blue doesn't pick up. I ran the troubleshooting and the error code 3502,3501,,3830, comes up. How may I fix this? I have new cartridges. thank you....
This is from the Kodak website.
How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? Published 08/25/2010 11:38 AM ' Updated 01/07/2011 08:40 AM ' Answer ID 1467 How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
Feb 07, 2011 | Kodak ESP 5 Printer
Where is the printer carriage access door located?
Hi
The door shown in this picture is carriage access door
2386b83.gif Let us know if in case you need any more information
All the best!!
Regards
Nov 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
When attempting to print, the printer window gives me the message Back Cover is Open Checked the back, opened it, removed the paper that was stuck on the roller and tried again. Same message comes up. What...
hello, when you are looking at the back end of printer, open up cover, the cover will open and stop, look further in and you will a black guide, or black plastic, open that up, if it does not open on its own, there is a piece of plastic that might look like a stick, sometimes this will get stuck, use a flashlight, and you will see haw this thing works, if it does not move freely, it will trigger rear door open, be carefull with this piece of plastic, it does break. again it will trigger an open rear door error.
Sep 27, 2010 | Brother HL-2070N Laser Printer
Dell Laser MFP 1815 won't print. Message keeps coming up Jam 2 open rear and front door. Have opened and shut doors repeatedly, restarted printer, tried copying over message but it keeps being displayed....
I had same problem. If you go to rear of printer and open the back door you'll see it is attached to a blue connector. Unattached it so that the door opens fully and then unflap the inside roller assembly. Next open the fuser door and you'll notice a little spring loaded assembly on the inside of the opened fuser door. This is where my problem was. Make sure that the assembly springs back when pushed because part communicates with a sensor on the motherboard. If it doesn't spring back then the printer thinks there is a jam. Mine was stuck but after pushing it a few times it started to work freely again. This was a frustrating problem but that fixed my issue and hopefully it will fix yours.
Jun 04, 2009 | Dell 1815dn All-In-One Laser Printer
Kyocera FS2000-D error message 7410:0017578
The drum is not pushed fully into the machine.Open the waste toner container door and gently push all units into the printer.Then turn off the printer at the wall.When you power back up the printer should be back to normal.
Jan 28, 2009 | Kyocera FS-2000D Laser Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
Back door closed
I did not get any error message but the 6940 printer would not print. Instead "Ready" the printer said "door open". When I deleted printer and plugged the usb cable back in the XP machine found the new hardware, said "Ready" and could print.
Dec 22, 2007 | HP Deskjet 6940 InkJet Printer
Brother MFC 7420 All-In-One Laser Printer Logo
190 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
