Question about Humminbird Matrix 37 GPS Receiver
How do i hook up the in line fuse and or what kind to get
In-line fuse for what exactly ? normally you just need an in-line fuse holder and break into the live wire to whatever you are wiring ( with whatever it is switched off of course ) and pop the fuse in series.
Posted on Apr 13, 2009
How do I hook up my subwoofer and amp to my ford f150?
to hook up the amp. drill a hole in the firewall, run an 8 or greater gauge cable (greater, depending on the wattage of the subwoofer amplifier) from the battery positive lead, thru the firewall, to the amp power +, and be sure to place an in line fuse within the engine compartment, within a foot of the battery. hook the speaker up, and then run the amplifier negative lead to a bare metal part of the cars chasss, and, finally, hook the amplifier remote power lead to the acc circuit of the interior fusebox (i usually just take the acc fuse out, stick the wire in the acc fuse receptacle, then re-insert the fuse to complete the circuit).
to run the radio signal to the amp, you can use a speaker to line level converter (if stock stereo). just splice them into the stock stereo speaker leads
Apr 15, 2016 | Car Audio & Video
100 amp battery fuse assembling
Just hook fuse on one side to battery + and hook any other wires
to the other side of fuse .But kook the wires first then kook the fuse to the the battery.
Ray
Nov 05, 2014 | Cars & Trucks
Blowing 20a fuse
Broken or shorted line or relay
Apr 16, 2014 | 2010 kawasaki Super Sherpa
Phone does not ring
what kind of phone. land line or cell?
if it is a land line or home phone check where it plugs in at and see if the red wire and green wire are hooked up.
if it and blue wire and a blue and white make sure those are hooked up.
Jul 05, 2012 | Lands Phones
I hooked up a car amp and when i put the fuse in,it blew.then i disconnected the power,installed the fuse and as soon as i touched the power cable,the fuse blew again...
Hello
Some kind of dead short is there. It may be inside the amp circuit of with outside wiring. You have to find it by meter check. Contact a auto electrician and let hinm detect the fault. OK.
Jan 16, 2012 | Pioneer GM-X354 Car Audio Amplifier
I have grandfos circulator pump the wiring was hooked to incoming line not cir. line is this ok
That is still okey, however, it would have been advisable to hooked it to its own cir. line. I assumed that the cir. line is dedicated to the grundfos pump complete with its own circuit breaker or fuse cutout.
Since you are just asking if it is okey, well it is. But
the line must be going to a circuit breaker (20 Amp trip), for 220 volt line; and 40 Amp trip for 110 volt line
before it goes to the grundfos pump. Just use the circuit breaker or fuse from the cir. line. And take the original cir. line off from where this is connected, and keep it for future use.
Nov 28, 2009 | Plumbing
We had a clarion reciever with tape deck in our boat and found another clarion reciever with two new speakers and two good 1996 speakers which had not weathered. The instalation was difficult but the...
As long as you have connected the ground(black) try adding one wire at a time to the live(red). If possible try connection each wire one at a time to the power line and then both together. If nothing has blown(fuses) and the unit starts working then you can try by trial & error method the remaining wires. You should be able to figure out which wire is required and if there are any extra wires like cellular phone(mute) and then decide whether to connect them or keep them open.....sodeep
Jul 27, 2009 | Clarion DB245 CD Player
Unit stopped working
You need a dedicated line to the unit. I would get a meter and see what kind of voltage is coming out the socket. My first thought was they ran a 240 volt dedicated line to a 120 volt unit. OOPz!
Jun 10, 2009 | Fedders Y Chassis AEY12F7E Air Conditioner
Locked keys in the trunk of a 1985 chrysler fifth ave; ignition switch is locked; how do i access the trunk?
thats easy,locate the fuse for the electric trunk lock,take the fuse out,hook a piece of wire to one of the contacts where the fuse goes into and hook it to the battery or an acc line in the fuse box then hit your electric trunk switch and it should open,if it doesnt work try the other side where the fuse hooks into
Apr 26, 2009 | 1985 Chrysler Fifth Avenue
Humminbird Matrix 37 GPS Receiver Logo
197 people viewed this question
Top Humminbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
