Honeywell thermostat the readout (LCD) is blank and A/C is not blowing.
  • 1,420 Answers
You have lost power to the A/C system. Check that the Emergency switch has not been turned to the off position by mistake. If it is in the on position you will need to inspect the indoor unit to see if an access panel may have opened slightly causing the door safety switch to open and turn power off to the unit. This is typical found where you replace the air filter. If neither of these help, check the circuit breaker box for a tripped breaker. Cycle the breaker for the A/C system and inspect the thermostat to see if it is displaying any information. If still blank, you may have a bad transformer or something else wrong and a technician will have to diagnose. Hope this is helpful.
Posted on Sep 12, 2007
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
https://www.youtube.com/watch?v=pNVTAUcBx-U
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
https://www.youtube.com/watch?v=lSJn69EAcAw
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
I have A LCD Honeywell thermostat that has a display that is blank. also it is not sending anything to my furnace. there for my main level in my house is very cold. I have the same one up stairs and it is...
Replace the batteries first. Some cheap thermostats require the batteries to function. I don't know of a honeywell model that does though. Its cheap, so do that first.
If still nothing comes on and you still have a blank display with new batteries, I'd say probably the thermostat is defective. Even if the furnace is broken, new batteries SHOULD bring up the display.
Feb 20, 2015 | Heating & Cooling
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
Honeywell Chronotherm iv Plus power cuts on and off
There's a trouble shooting guide here, you need to check for the presence of 24V when it goes blank, and trace back to where it's disappearing (I assume it is losing the 24v, if not you'll need to go through the installer setup or read on...
My first thought would be to check the wiring which has been touched last if it started doing that after you had coil replaced.
As an aside I'm not sure which model you have but if it has batteries you should replace them (I don't think it does have batteries but not seen a model iv so I'm unsure)
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1410.pdf
May 12, 2014 | Honeywell Programmable Thermostat Heater
My Honeywell programmable thermostat's display is blank and I do not have any heat?
The thermostat, depending on the model, normally does not get powered by batteries, they are for backup power. You might be losing 24 volt from the furnace, causing the thermostat to run on batteries.
Apr 09, 2014 | Honeywell Programmable Thermostat Heater
6AE Lo
6AE Lo is probably 'bAt Lo'. Batteries are low and need to be replaced.  It looks like 6AE Lo because of the digital readout (b looks like 6).
http://www.espenergy.com/faq_honeywell_thermostat.htm
Model number shouldn't change what the readout means.
Oct 14, 2009 | Honeywell CT3600 7 Day Electronic...
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
I have the same problem.
transformer going bad or bad connection check for 24v ac from red to common batteries only for mem storage and if no common used at stat to hold program red to g fan red to y comp
Jun 09, 2009 | Honeywell Programmable Thermostat Heater
Readings disappear on thermostat for awhile then come back
Hi Linda,
There are a few things that cause this:
  1. When the heat is starting, it will sometimes go blank for a few minutes and then resume.
  2. Most have batteries, replace them with fresh new ones, if the electricity goes out while you are away, the batteries will keep the settings.
  3. Have someone check the house when it is extremely cold or hire a service to monitor. Your alarm company can usually add temperature sensors to your home, it will add a little safety net for you.
Hope this was helpful, please rate my answer.
Thanks,
Paul
Jan 27, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
496 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
