Question about HP Compaq nc6220 Notebook
I can't fine the swtich of the connector cn22
I need to know HOw connect the cn22 switch
My treadmill circuit panel does not turn on, the belt woks fine, the incline and the speed are manual.
1) test the batteries and replace if are NOT full charges
2) replace with the same types like ALKALINES only
3) see if there are NOT connect in WRON polarities
4) clean the contacts batteries with c. cleaner
5) tight the springs contacts very well. and tight the plug well.
6) tight the ribbon cables for keypads and connectors and clean it from display board vs lower board see the b. diagram
7) adjus the REED swtich, see the diagram , clean it and tight the connector well.
God bless you
Oct 14, 2012 | Proform Crosswalk 500 Treadmill
How to change the stoplight switch
http://www.autozone.com/autozone/parts/Duralast-Stoplight-Switch/1991-Mazda-929/_/N-itja5Z9cias?itemIdentifier=190051_0_0_Go to brake pedal,remove electrical connector from swtich,look ans see how far the screw is screwed in so you do the same with the new one and adjustment will be minunum.remove screw and install new one and connect electrical connector and push brake pedal in with hand so you can see switch engage,if not engaging right,adjust screw in or out.
Jul 22, 2012 | 1991 Mazda 929
Craftsman tablesaw model number 315.218050 First let me say this saw is great and I have only great views of this saw. I was running a practice cut to check depth of cut and saw was working fine. ...
Jessie, It sure sounds like the switch has failed. You can replace the original switch with replacement swtich from Sears, or you can just replace it with a light switch from Home Depot. If you go with the light switch, use one with as high a capacity rating (amps) as you can find that will fit. However, if you go with an ordinary light swithch, you will also give up the safety feature or having a "key" for the switch. This is not a good idea if you have kids that might have access to your saw. Regarding the the wire connections, any single-phase switch will have only two terminals (besides the ground). These two terminals are interchangeable - it doesn't matter which of the two wires connect to which of the two terminals. Good luck. Please vote if you found this helpful. Al K
Jul 21, 2011 | Craftsman 10" Table Saw
I brought a des 1008d swtich i want internet sharing with swtich .i connect all pc with this switch
You have to connect all the computers you have to the switch and connect your DSL or cable modem also to the switch and enable DHCP in it. Configure all your computers to obtain IP address automatically. This should work and you should be able to share the internet across the network
Dec 21, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
HOW DO U CHECK TO SEE IF IT THE BLOWER MOTOR OR THE FAN SELECTTOR SWITCH IS THE PROBLEM IF THE FAN DOES NOT BLOW BUT YOU CAN FEEL A LITTLE HEAT OR A/C COMING OUT? RELAY WAS REPLACED LAST YEAR, SOMETIMES...
Turn on the blower fan, if its not running ,pop the hood ,and tap on the blower motor with a screwdriver handel or equivalent,its in the center of the firewall right below the windshield if the blower starts running (and i am sure it will) replace the blower motor this is a quite common issue with these
Dec 01, 2010 | 1997 Buick LeSabre
The brake light on my 2001 softail is always on. I am looking for a wiring diagram
you don't need a wiring diagram to fix this, what you do need is to know what to look for. you have two swtichs for your brake light front brake lever and rear. i would start at the front because it is just a push switch. start be unpluging the gang plug for the rh handlebar switch housing has your brake light gone off?? if so you front brake switch isn;t working if not then check you rear switch unplug it from the harness. light off? if so your rear swtich is bad. check into and let me know
Mark
Apr 15, 2010 | 2001 Harley Davidson XL 53 C Sportster...
I have an 24V electric mower.\i charge it
Either the connector between the battries and the mower are bad or the starter switch is bad, you know the wires between the batterries and the connector are good because you said the batterries charged just fine, so either between the connector and the motors, or the key switch has a break in its continuity, easiest way to test is connect the batterries directly to the motor to see if it works if it does connect before the start switch then after the connector the before the connector and keep moving up the connection wires until you fine where the problem is. Hope This Helps Don
Nov 08, 2009 | Black & Decker 19" Electric Lawnhog...
How do I change the oil pressure switch properly?
remove oil from engine.unplug connector.clean connector.remove switch.put new swtich.connect the connector.put oil in engine.drive for 10km and check if oil light comes on.
Oct 04, 2009 | 1990 Buick LeSabre
Switch diagram needed
Funny, I came here because I just opened up the switch case on my MM875. Hold the switch so the terminals are on top. Call the black switch (the part you push in to power up the mower) north. The north post gets white (metal connector). The west post gets red (plastic connector). The east post gets the black that comes from the mower's motor (plastic connector). The south post gets the black that comes from the outlet (metal connector)
(Black Plastic Switch)
White (Metal)
Red (Plastic) Black (Plastic--from motor))
Black (Metal--from outlet)
May 22, 2009 | Black & Decker 19" Electric Lawnhog...
CONNECTOR PROBLEM
Usually the connectors will be marked as in the picture, indicating their usage. 07471ce.jpgIf your connectors do not have a label printed on them you can figure out the important ones. You will have a pair of connectors each for the power switch, the reset switch, the power LED and the hard drive LED.
The two pairs of wires used for the switches are the important ones. They can be identified with a circuit tester or multimeter (Check for resistance/Ohms). When they are pressed, the meter should indicate a connection across the two wires. In the case of the power switch if it's a really old case it will toggle on and off, so watch for the continuity to change when you press it. Otherwise the reset and power switches will only register a connection when pressed, and revert to an open circuit when released. Use your multimeter to identify which pair reacts to which swtich, and label them with some masking tape and a sharpie (or equivalent way).
As long as you identify these two and connect them correctly you'll be okay. The LEDs are not essential to booting your system and you can figure them out later. LEDs have to be connected the correct way around (usually the white wire is negative), while the switches don't matter which way they are connected as long as it's to the correct two pins. You can connect the LEDs and see which ones light up on your panel to determine which is connected where. If your power-on LED lights when there's hard drive activity, then you know that the connector plugged into the pins for HDD LED is the wires for the power LED, and so forth.
Hope this helps.
Please rate my answer.
Jan 01, 2009 | Asrock P4i65GV Motherboard
HP Compaq nc6220 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
