Question about Jensen CD4610 CD Player
Jensen cd player cd4610
Red power light on but wont do anything else
  • 3 more comments
  • jw1979 Sep 16, 2007
    this did not work so i guess it is just a bad stereo
  • lonniefnchi Dec 16, 2007
    first of all,i have to hot wire my truck bacause the ignition switch is all messed up and i need to get a new one,but the red power light comes on,and nothing else does,that light stays,and even if i press it 50000000 times,it doesnt do nothing
  • Anonymous Dec 23, 2007
    i had the same problem what i did was connect the yello and red wires together
  • Haystak Feb 10, 2008
    My cd player wont do anything. Red power light comes on but no power or a power shortage to everything. P.O.S.
  • exmisfit Feb 09, 2009
    I'm having the same problem with my Jensen. It was working fine for years and now all of a sudden it stopped working. The red light is lit but when you press it the radio will not power on. I checked the red and yellow leads in the harness and both are getting power. The fuse in the radio is good as well. With the ignition turned on, when I disconnect and then reconnect the harness the radio will work normally. But once I turn the radio off or turn off the ignition the radio shuts off but once again will not power on. I hit the reset button but it changed nothing.I then tried to fix it by connecting the yellow and red wires, and while that did indeed get the radio to work right again, it also drained my battery down. So now I'm back to disconnecting and reconnecting the harness to listen to music. I'm thinking maybe the contact points in the harness or inside the radio are bad but how do I fix this problem?
    Scholar:
  • 98 Answers
Check for power on both the red and yellow wires with the key on. If both have power either the radio needs a reset or the radio is defective..
Posted on Sep 13, 2007
  • Mike Ryan
    Mike Ryan Sep 17, 2007
    thanks for rating me not helpful... like its my fault you bough ta krap junk jensen stereo...
SOURCE:
The door for the cd player wonkt open on a Jensen CD4610
Look for a very tiny hole in front of the drive; use a paper clip poke through that hole, applied a little pressure and push. The tray should pop open.
Feb 15, 2014 | Jensen Audio Players & Recorders
Just need a pic to see what color wire goes to each of the 20 pins on the back of the deck
Wiring Diagram / Color Codes
1. Power Antenna (dark blue wire) - Connect to power antenna or amplifier.
2. Ground (black wire) - Connect to ground terminal or clean, unpainted part of chassis.
3. Memory/Battery (yellow wire) - Connect to battery or 12 volt power source that is always on. The radio will not work if this wire is not connected.
4. Accessory/Ignition (red wire) - Connect to existing radio wire or radio fuse.
5. Left front speaker - White/Black is negative, White is positive
6. Right front speaker - Gray/Black is negative, Gray is positive
7. Left rear speaker - Green/Black is negative, Green is positive
8. Right rear speaker - Violet/Black is negative, Violet is positive
9. RCA Outputs to Amplifier - Black is front, Gray is rear
10. Auxiliary Input Cable
11. Subwoofer Output
12. Antenna
13. CD Changer
The manual is available here:
http://diversesolutions.org/files/CD4610.pdf
The wiring diagram is under the section Wiring.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 13, 2010 | Jensen CD4610 CD Player
Cd won't play
The yellow wires on back one has a white cap the other has a red cap those are the input wires you need to buy the cord that goes from a red and white RCA jack to a 3.5mm headphone jack
Mar 09, 2009 | Jensen CD4610 CD Player
Auxiliary port location?!?! where would it be?
Oct 02, 2008 | Jensen CD4610 CD Player
My cd player wont play my burned cds
this happens all the time, instead of getting CD-Rs, try getting the CD-R Music, they are specially made to be played on CD players, I buy these all the time and they work in every CD player.
Feb 09, 2008 | Jensen CD4610 CD Player
Sound
By no means is this a solution, only a comment - Internal Amplifier is bad. Check your wiring before installing another unit.
Jan 12, 2008 | Jensen CD4610 CD Player
Need manual for jensen cd4610
go to jensen.com and download the manual
May 11, 2007 | Jensen CD4610 CD Player
Faceplate malfunctioning and scanning repeatedly
hi this meens the wohle panel is squashed on its buttons the seek button is main 1 and wont let anything work besides it take out the button release the screws all the way jiggle it a little bit, or even take a look inside that nothing is broke or loose tightened the screws but not hard(soo it wont happen again) good luck
Dec 27, 2005 | Jensen CD4610 CD Player
Jensen CD4610 CD Player Logo
204 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
