Appears not to be getting power Could it be a safety switch of some kind. Don't have owner's manual.
Our Infoguard shredder SX120D has stopped working. It appears to have no power. Unfortunately we don't have the owner's manual. I'm hoping it's a safety switch since it was working just fine on Fri. until someone empty the shredded paper from the bin. I will appreciate your help. Judy Repass Western VA OB/GYN Center
Make sure the Bin is put back properly, there is a micro switch that powers the unit once the bin is in place
Posted on Jan 01, 2010
Infoguard sq70B shredder stopped and will not turn on. It is very hot. What do I do?
Usually shredders get hot when over used. If you have a reverse switch, use it to see if something is stuck in the shredder. I've found small but very hard balls of paper in the sides, so they do need cleaned out every once in awhile. Also most need oiled with a light oil so you may need to check that too. More often than not an over worked shredder will heat up and stop until cool again.
Aug 13, 2017 | Shredder Office Equipment & Supplies
Light dont come on
Shredders have safety switches that turn everything off in emergency conditions. So clean it out good and check movement and function of those switches. Also check for internal fuses, these things can be overworked and blow a fuse.
Mar 08, 2015 | Cross Infoguard Shredder SX102M
Infoguard shredder SX-102 runs in reverse but not forward
Shredders have a manual switch for reverse..... if you have tried this, then there could be a possibility that the switch has dust of paper in it and the contacts not making contact for the reverse cycle... or the switch is faulty. If you have any electrical knowledge, you can do a test with an ohm meter for continuity in the reverse mode.... or remove the switch and blow it out with an air compressor. If you mess with electrical, ALWAYS REMEMBER TO UNPLUG THE SHREDDER!!!
Good luck.........
Jul 14, 2014 | Achiever CCS5000 Shredder
Works in reverse but not forward
Move the power switch to AUTO (l) position and depress the manual forward button for five seconds to clear paper blockage. Make sure the paper is engaging sensor located in the center of the shredder opening.
Good luck.
Apr 11, 2011 | Cross Infoguard Shredder SX102M
Infoguard SX 120D Does not power up. No lights
There is a switch on the right side of the shredder itself which has to engage with a tab welded near the top of the basket. Make sure the tab is enagaging the switch. Also check the paper path switch right above the shredder bars.
If you cannot figure this out, please do not pitch the shredder. There a few people here (myself included) that need gears and such from this model. We would gladly pay shipping for such.
Thanks,
John
Feb 03, 2010 | Cross Infoguard Shredder SX102M
Infoguard SX100M unit will not shred. Green light comes on.
I have the Infoguard SX100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, red side switch, the gears and fuse were all ok, I think something on the circuit board was fried.
Anyways, I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Jan 10, 2009 | Cross Infoguard Shredder SX102M
Shredder won't shred any more.
Mar 27, 2008 | Office Equipment & Supplies
Sx-102M
I have the Infoguard SX-100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, the gears and fuse was ok, I think something on the circuit board was fried.
Dec 21, 2007 | Cross Infoguard Shredder SX102M
298 people viewed this question
jasbo
jasbo
