Question about Refrigerators
New water valve not filling the ice maker.
The valve that supplies water to the icemaker and water dispenser of our Maytag refrigerator recently began to leak. I replaced the valve but now, although the water dispenser works normally, the ice maker doesn't fill with water. Thinking the new valve was bad I replaced it again. Same result: water dispenser works but no water to the icemaker. Thinking that ice might have accumulated in the supply line, I turned off the freezer over night. No difference. Still no water to the icemaker. Any suggestions?
  • 121 Answers
Take the supply line to water valve and blow into it
you will feel it if it is clear if blocked remove tube
and clean
Posted on Apr 13, 2009
I recently replaced my water filter on my Kitchenaid side-by-side refrigerator, model KSCS251, and since then my icemaker no longer makes ice, nor do I hear any water flow into it. The water, however, does...
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips
Jun 16, 2011 | KitchenAid KSCS25FKSS Side by Side...
Ice maker not working
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2010 | Kenmore 57029 Side by Side Refrigerator
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
My icemaker has stopped receiving water
it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
Our icemaker does not fill with water
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker is not filling w water. water does come
The ice maker likely needs replaced however it could also be the fill valve. If you have the ability to locate the valve at the end of the fill hose (usually bottom right when looking at the back of the fridge) it will have 2 solonoids with electical connectors on them. Swap the connectors and press the water dispenser paddle. This should fill the icemaker. If it does, the valve is fine and the icemaker is bad.
Aug 21, 2009 | Whirlpool GD5SHAX Side by Side...
Maytag ice maker will not release cubes
Sounds like it has a " seeping " water valve . Only thing to do is replace the water inlet valve . There is a certain amount of water to go into icemaker at fill . A seeping valve will let water continually drip into icemaker , making large cubes which icemaker cannot dump . A larger amount of seeping , will overfill the icemaker , and drip into the freezer and floor .
Aug 12, 2009 | Maytag Refrigerators
Ice Maker Not Working
Hi: A lot of reverse osmosis systems don't supply enough water pressure to the ice maker to fill. Contact your manufactrue of your reverse osmosis system and see if it works with icemakers. I thind usually the require at least 20-30psi. Or hook your refrigerator to city pressure to see if it works. Also I don't know if you have just an ice maker or a water dispensing side by side, or your water quality. If you just have an icemaker, most chlorine will evaporate before the ice is frozen, any odors in the water will still be there. Good Luck, Jeff
May 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Icemaker
There is a water fill adjustment on your ice maker the normal fill time is 7.5 seconds...
the adjustment screw is on the side and in the middle of the head..
•Turning the water level adjustment screw
will move the contact in its relationship with
the contact ring segment. This causes the
contact to vary the time that the water valve
is energized since the contact ring is tapered
at the end of the fill time.
•Turning the knob or screw clockwise
decreases fill - counterclockwise increases
the fill amount.
• Only one revolution is possible with the
cover on, due to a stop molded on cover
360o will affect fill by 40cc - 180o varies
the fill by 20cc.
•if you need more adjustmnet remove cover
• Further adjustment could damage
module.
Hope it help please let me know if it does...
Sep 03, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Mar 28, 2008 | Refrigerators
Refrigerators Logo
273 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
