Question about Brother IntelliFAX 4100 Laser Fax
Loud clicking noise when faxes arrive - Brother IntelliFAX 4100 Laser Fax
  • Ray M. May 11, 2010
    what about when you print an internal report, such as your fax activity report?
    razors
  • 23 Answers
The noise may be caused by the toner cartridge binding up. This can happen with remanufactured cartridges more so than OEM. Try swapping out the cartridge.
Posted on Apr 15, 2009
Loud clicking noise on my hp printer 4500
hi, your priner complaint i 2 chance 1 is the carrage cable is damaged or 2 is printer mechanism complaint please verifing
Mar 26, 2014 | HP Officejet 4500 All-in-One -...
When an incoming fax is arriving our fax at work is beeping very loudly, how do you turn it off.
Hello, it may be possible the the fax is in diagnostic mode or the ringer volume is turned up. 1) go to the administration tab on the control panel 2) go down to the initial setup 3) go to fax setup menu 4) go to fax receive settings 5) Check the ringer volume should be set to low (default) or to off for no sound. In the troubleshooting menu - set the fax speker mode to NORMAL (default). I hope this will assist with your problem.
Jan 13, 2011 | HP® LaserJet M5035 MFP Laser...
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
We have a brother fax machine and it makes a loud clicking noise we think the brushes are broke
There may be several reasons for the clicking noise
1. May be paper clips or other foreign material got stuck inside
2. May be a piece of paper got stuck inside and is somewhat causing this problem
3. May be after having removed a paper jam, some parts within the machine got loose.
The most evident situation is to have a quick look, without disassembling the equipment.
If still the problem persists, then it's better to have the equipment checked by a professional.
Mar 31, 2010 | Brother IntelliFax-4100e Fax
Loud Clicking Noise
CHECK ON EBAY FOR REPLACEMENT DRUMS OR LOOK FOR A NEW MACHINE,
Feb 09, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Recieving fax error
It could be a bad drum unit. If the drum doesnt turn smoothly it will make a clicking or grinding noise since it is gear driven. Take out the drum and turn the gear with your thumb. turm towards you. If difficult Thats it. It also could be a fuser gear. good luck Lawrence
Apr 22, 2008 | Brother IntelliFax-2820 Laser Fax
Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Oct 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
265 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
