Question about Kenmore 57029 Side by Side Refrigerator
My freezer is not working all of a sudden. The
My freezer is not working all of a sudden. The temperature must have dropped because everything is melting, water is leaking onto the floor. I had my daughter pull everything out, and unplug it...will this work? What is going on with it?
  • ghound51
    ghound51 Sep 27, 2012
    My freezer seems to be working, but I have water dripping from the bottom front. What is going on?
  • 121 Answers
Bad relay
Posted on Apr 13, 2009
  • lojacksdad
    lojacksdad Apr 13, 2009
    see if there is an ice build up on the back wall of the frezzer
    if so leave it off overnight then plug it back in if the ice starts to build up again you have an automatic defrost problem timer.heater limit switch
Away for 3 days, came home, all food in freezer just slush. Fridge OK, freezer dead. not sure why, maybe not quite closed door. Fan in freezer was not working but it has suddenly come to life.
Yes, leaving the door open a little could cause it to defrost. This would also make the fan run more than usual, and the fan might have run so much that the fan temporarily stopped working. This is probably a built-in safety feature of the fan (much like some paper shredders will overheat and not return to operation until you let it cool down or operation environment turns back to normal). Good luck.
Jan 03, 2018 | Refrigerators
Kitchenaid KBFL25ETSS00 bottom freezer refrigerator not cooling properly in the refrigerator nor the freezer. I hear the refrigerator running, but don't know if it is just the fan. It was working fine,...
You mean the temps are getting warmer? Look inside the rear of your freezer and back wall and tell me if you see snow or a layir of frost building. If so pull everything and unplug and do a manual defrost a hair drier will speed things up.Sounds like we need to use the tech sheet here but Kitchenaid will not allow me to publish here. So Skater125 you need to click here and I will send it to you only, Thanks, Sea Breeze
Sep 17, 2011 | Whirlpool ET1FHTXM Top Freezer...
Freezer suddenly defrosted everything. motor is running, however neither the fridge or freezer will drop in temperature. temp. stays at 56. Thanks for any help.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 28, 2010 | GE Profile Arctica Stainless Steel Top...
Fridge temperature has suddenly dropped to 15
Check the door gaskets, condenser fan, refrigerator fan and the freezer fan. That should narrow down the problem.
Dec 03, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Freezer temperature won't get cold enough.
This might sound stupid, but I had a similar problem. A few years ago when I was renting I noticed that suddenly my freezer stopped working well. I eventually had to call my landlord to check it out. It turned out that there was a knob to adjust the freezer temp and I had turned it to the warmest setting somehow. If it isn't that, I would return the freezer.
Hope that works for you
Jan 18, 2009 | Frigidaire FRT18G6J Top Freezer Side by...
The freezer stops working when the room temp drops below 60
Refrigerator operation is controlled by the internal temperature . When there is very little ambient heat available to leak in to cause it to cycle more frequently and there is no door traffic to be a heat source the freezer temperature will increase. Keep the room heated to a higher temperature or remove frozen products is the answer. A small chest type freezer will keep food frozen while you are away and have the heat turned down.
Nov 11, 2008 | Refrigerators
Whirlpool Easytronic
trouble reaching -18 sudden drop yesterday to-6 took till 6am this morning to reach -17?as to why
Jun 26, 2008 | Freezers
Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Dec 28, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore 57029 Side by Side Refrigerator Logo
180 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
