Question about Acer Aspire 3613WLMi Notebook
Need to reboot into factory settings - Acer Aspire 3613WLMi Notebook
How do I do a factory reset when it only has reboot or recovery setting on the asus
You can do a factory reset via the settings menu. Look for a 'Backup and Reset' entry.
Mar 07, 2015 | ASUS ME176CX-A1-WH Memo Pad 7 7IN 16GB...
My nabi dreamtab wont reset why?
There are two types of resets that you can perform on nabi - forced reboot and factory reset. In the unlikely event that your nabi becomes unresponsive, you can easily perform a forced reboot. A factory reset is recommended when slow performance persists or if you want to wipe out all of your personal data and settings from nabi. Forced Reboot: To perform a forced reboot, hold the Power Button down until nabi turns off. When nabi is off, press the Power Button to turn on nabi again. Factory Reset: Caution! A factory reset is a very serious process because it will SYSTEMATICALLY WIPE ALL USER DATA from nabi. A factory reset will return nabi to its original factory settings.To perform a factory reset from Mommy/Daddy Mode, tap All Apps > Settings > Backup & reset > Factory data reset > Reset tablet > Erase everything. Please note: We highly recommend backing up your nabi prior to performing a factory reset. You can back up your music, videos, photos and apps with nabiā„¢ Sync.
Dec 20, 2014 | Tablets & eReaders
Aspire one needs rebooting no disk
The Acer Aspire One is a netbook, not a laptop. A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop. It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature. You can reset the Acer Aspire One to factory settings just using your keyboard. Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive.
Feb 14, 2013 | Acer Aspire One PC Notebook
Reboot playstation 3 to factory default
go to settings on the dashboard and the option to reset to factory settings is at the bottom
Jan 27, 2012 | Sony Playstation 3 (PS3) Console
How do i reboot my laptop back to factory settings
To reboot to factory setting you need to have the restore disk from the computer, put it in the drive and restart with the cd in the drive, if the startup screen does not start right away you need to type f11 or f6 to change startup order to cd first the the restore screen will startup and click restore factory settings
Jun 04, 2010 | eMachines eMD620-5133 Notebook
How do you Reboot a computer back to factory setting
Instructions Things You'll Need:
  • Factory Settings CD
    How To Use the Restore Factory Setting CD
  1. Step 1 Make sure to transfer all of the files you want to keep to a USB memory stick or burn to a CD.
  2. Step 2 Put the "Restore Factory Setting CD" into the CD drive. This CD was packaged with your computer.
  3. Step 3 Confirm you want to restore the factory settings. The computer will begin restoring all settings. Don't disturb your computer, as this process can take several hours. .
  4. Step 4 Reboot the computer to complete the process.
  5. How to Reboot Using the Computer Start-Up
  6. Step 1 Turn on your computer. Right away there will be a black screen. You can restore factory settings without a CD, too. This will reset your BIOS.
  7. Step 2 Press "F1" when the black screen appears to enter the setup configuration mode. You will be presented with a menu.
  8. Step 3 Select "Restore Factory Defaults." That's it. Your computer will do all the work for you. Like the CD, this process may take several hours.
Jan 27, 2010 | Computers & Internet
Reboot back to factory settings
If you are having problems with your system and you want to restore it to factory settings .. as long as there is nothing wrong with the CD drive itself you do not need windows drivers for it to function properly during a factory restore
Feb 02, 2009 | HP Pavillion ZV6000 Notebook
Reboot to factory settings without disc
Can you still log in to Windows Vista?
e machine has a RECOVERY MANAGEMENT allows you to restore sytem to factory default or reboot and tap F10 and follow instructions.
Good Luck!
Jan 31, 2009 | E-Machines (T2958) PC Desktop
I want to reboot my Toshiba A200 back to factory settings, i have a spyware down load **** that keeps on asking me to install.....how do i reboot
If you have the recovery CD, then put that in the drive, reboot the laptop and make sure you boot to the CD. The recovery process will start up and you can restore the laptop to it's factory settings. Make sure you have all of your documents, music, etc. backed up.
Dec 05, 2008 | Toshiba Satellite A205-S4617 Notebook
Acer Aspire 3613WLMi Notebook Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
