Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Printers with full bleed capability?
I will be using a Bizhub C353 machine. My understanding is that it is capable of printing full bleed. Is this correct?
Do you know of any laser printers that are capable of full bleed?
Thanks
Kate
  • 167 Answers
NO!
Just like on a printing press that toner is being imaged somewhere when it runs out of the sheet. The toner is going on the imaging belt/fuser. Over time it will build up and ruin the device. On a press they can stop and wash the imaging blankets. Full bleed is achieved by running on oversized stock and trimming off excess afterwards. That is how the "Pros" do it.
Posted on Apr 27, 2009
Konica Minolta Bizhub C353 Has not lights on the network card
make sure the new outlet has power coming out of it, It may be connected to a switch or the breaker may be turned off.
Oct 29, 2014 | Konica Minolta Bizhub C353 Color Copier...
How do I bypass the 1/4" unprintable area so my document bleeds to the edges of the paper?
This printer is not capable of "Full Bleed" printing.
You can change your margins in your software to all zeros or narrow to get the maximum print area.
Sep 25, 2014 | OKI C5150n Led Printer
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
7500 dt to print full-bleed
This printer is not capable of printing full bleed. You will have to print on oversized paper and trim it to get dull bleed.
Jan 10, 2014 | Xerox Phaser 7750 Laser Printer
How do I eliminate the margin so it prints out to the edge? I have done a search for a full bleed. No reference.
Unfortunately, Xerox solid ink printers don't print full bleed. It is a shame because in theory, the machine is capable of it but it would require a firmware/driver programming/design update which Xerox are unlikely to do.
Jan 19, 2011 | Xerox Phaser 8860MFP Printer
I have konica minolta bizhub c353 i have problem
Most likely it is your magenta cartridge or magenta developer unit.
did you recently change cartridge?
Are you using original cartridge?
Nov 13, 2010 | Konica Minolta bizhub Office Equipment &...
The print margins on my Konica Minolta Bizhub c203 cut off the bottom of my pages. how can I fix this?
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
May 20, 2010 | Konica Minolta Bizhub c203 Copier
Printing Phaser 8550
that is a part of that printer design. Something sadly you can not get rid of. Believe me, I have tried, and Xerox engineering told me that is part of how the machine is supposed to work. Wish we could eliminate that.
Mar 26, 2009 | Xerox Phaser 8500/DN Printer
Konica Minolta Bizhub C350. Precut 4x6 full bleed postcards.
Hello
Yes, there is no 4x6 choice, you have to input costume size.
For the bord-less part, i first would recommend to use a little bigger costume size so if paper with is 20 mm and there is a boarder about 1-3 mm then input costume size 23 mm. Caution, this can cause a paper jam, because there is a solenoids, what read paper. or you can use a bigger paper and later cut off the boards. Because this printer is not capable printing board-less photos
Jan 21, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,666 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
