Humidifiers
Problem for Humidifiers
Generic problem for all Humidifiers
Installed Wait 5000 Humidifier. Water nev...
By comax on Apr 13, 2009
The water never seems to turn on. This is on a Keeprite high effeciency furnace. I use this humidifier as a direct replacment for the old drum style, put it in the same position. Is the furnace possibly not generating the heat to turn the unit on? I use the supplied transformer, green light is on when furnace is off but humidistat demand is there. When furnace turns on green light goes off, furnace turns off before water starts flowing. Lots of Supply water.
Help
Comments:
Apr 15, 2009
- I figured it out, the internal humidistat in the humidifier was keeping the water valve closed. I bypassed it and wire directly to the valve. No the correct way but works like a charm.
Same Problem
Apr 20, 2009
-   Redplaced two Wait 5000 Humidifier so far. Water never turns on" or now and then-when the furnace run. Uses the wife blow drie to represent the furnace heat and still wont run. Tired to hear the wife complain about this humidifier any suggestions, and notify you when a new solution is offered-   cowand chick
Popular Solutions for Humidifiers
Questions and Unsolved Problems for Humidifiers
Answer
I have a Lakso model 110 humidifier that needs a filter. Can you advise me where I can find... (More)
Answer
Hi, Could anyone please recommend filter free cool mist humidifiers (3-4 gallon). I am sick of... (More)
Answer
how do I know if my Aprilaire Humidifier - Model 550 is working? I need a booklet
Answer
where do I put the scent pads in my vicks humidifier? -model v51oons
Answer
solenoid valve turns on whenyou put control on test but doesnot anyother time. control panel just... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Humidifiers:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
