Question about Tomtom GO 700 GPS Receiver
My tom tom go 700 don,t turn on
Hi dear , i left my gps system at my car for couple hours for charging ,my car was parked under the sunlight so the gps was under the sunlight for few hours,when i went to my car and tried to used the gps it just did not turn on. i wonder if the heat from sunlight had some effect on the gps or simply something stoped working on it, the issue is that my gps does not turn on when i push the button. you know why? i will apreciatte your help sir. thank you and i hope to get an answear from you soon. sincerly yours, tony.
  • 1 more comment
  • eblina May 27, 2008
    I have the same problem but resetting does not help. Does anyone have another solution?
    Thanks
  • glorico Aug 07, 2008
    Hi... my Tom Tom GO 700 also stopped working. I have tried resetting it but to no avail. Is there anything that can be done to get this unit up and running again.
    Thanks....Glorico
  • Anonymous Aug 10, 2008
    Our tom tom 710 doesn't seem to charge and hold power from any of the sources(mains, desktop or car). I have tried resetting the TT 710 with paper clip and then switching the unit on and holding the button down for 5 secs. But the on/off button doesn't seem to engage and no power seems to holding in the unit. Anybody any ideas please?
Hi I too had the same problem, the way I fixed it was to hold the rest button in for 15 secs than release and hold the on button in for 5 secs good luck mate!!!
Posted on Sep 21, 2007
It worked so far!! Reset for 15 sec and the push for 5 to turn it on!
Posted on Jul 31, 2008
It worked for me (for the second time). Any ideas why the GPS stops working? It looks as if this is not a very durable piece of equipment.
Posted on Jun 01, 2008
Thanks mate just saved my tom tom :D
Posted on Oct 22, 2007
Thanks, works like a charm!
Posted on Oct 07, 2007
The 15 seconds reset and 5 seconds power-up were key!
Posted on Oct 01, 2007
Thanks also.  I had the same problem and it worked for me too.  Great advice.
Posted on Oct 28, 2007
SOURCE:
My tomtom won"t turn on
If you have a tom tom from the GO models
they hace a reset button you can press with a pin were the mount fits.
When you plug in the charger the green light should come on to say it is chargeing.
Try the car adapter to charge the tom tom
Dec 13, 2010 | Tomtom GO 700 GPS Receiver
No signal
Hi,it is possible that the receiver has given out, check to see if it is within manufacturers warranty, if it is then the manuf should fix it for free.
Save all your routes etc before sending it back as it will most certainly get wiped and factory loaded.
External antenna may help
I have had my GPS( TOMTOM One) on Waiting for Signal for 2 weeks now and I finally fixed it.
My symptomtoms (word play) were no signal at open areas, when connected to Tom Tom Home it showed exactly where I was and worked through the PC but when disconnected back to the same thing.
I called Tom Tom CS and nothing, Flash did nothing, factory defaults nothing, and updating did nothing.
What I did:
I charged the unit completely.
I took a paperclip and while off pressed on the reset button at the bottom by SD slot. I held it there for 30 Mississippi's.
I did not turn it on after letting go.
I went outside to my car (parked on roof of parking lot) turned it on and set it on my dash vertically.
I left and came back in 1 hour and It is working perfectly!.
Hope that helps.
Thanks for using fixya...
Oct 27, 2010 | Tomtom ONE XL GPS
How to install external antenna on gps tom tom 700
i found a usb cable that plugs in to my lighter can i use this to charge my gps go 700 thrugh the usb port or will it hurt my gps system
Nov 22, 2009 | Tomtom GO 700 GPS Receiver
My tomtom won't turn on when I've charged it for several hours in the car and now at my computer. The green light is on but I still can't get it to turn on.
try the usb cable to your. this is the recommended method to charge a tomtom2.gif when it wont power on. for reasons unexplained by tomtom they do not recommend the car or house charges.
plug it in via the usb cable to your computer for a few hours(make sure the green light is on and nice and bright) then press and hold the power button(this could take up to 20 seconds)
bill
Oct 15, 2009 | Tomtom GO 700 GPS Receiver
Tom Tom turns on and then shuts off (cannot update my device)
You don't say what version tt you have but I would connect it to the pc and not turn it on. Just let it charge for a couple of hours. Then you should be able to turn it on and do an update.
Hope this answers your question.
May 02, 2009 | Tomtom ONE GPS Receiver
Recently after working one day the next day when i tried to use mt tom tom 710 it wouldnt switch on but the mains light was lit when plugged into cig lighter
Try giving it a full charge. I used different model Tom Tom that would not turn on even if plugged in until after the battery was recharged.
Oct 10, 2008 | Tomtom GO 700 GPS Receiver
Hi my tom tom go 700 dosnt turn on
I had the same issue. I used a paper clip to press the reset button on the bottom of the device.
I hope that works for you. Good Luck
Dec 12, 2007 | Tomtom GO 700 GPS Receiver
No gps signal
I have had my GPS( TOmTOM One) on Waiting for Signal for 2 weeks now and I finally fixed it.
I called Tom Tom CS and nothing, FLash did nothing, factory defaults nothing, and updating did nothing.
What I did:
I took a paperclip and while off pressed on the reset button at the bottom by SD slot. I held it there for 30 mississippi's.
I left and came back in 1 hour and wallaaaaa. It is working perfectly!
Let me know if this fixes it.
[email protected]
Oct 03, 2007 | Tomtom Go Plus GPS Receiver
MY TOM TOM GO 700NOT CHANGE TO REGULAR MODE
wrong upgrade by the internet call the factory to reset
Sep 09, 2007 | Tomtom GO 700 GPS Receiver
Tomtom GO 700 GPS Receiver Logo
472 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
