Question about Cycling
Kick start thinggy on the engine as rounded off
I have a 125cc pitbike offroad and the other day i went to kick start it and the bit where the kick start fits on the bike (not sure what its called) but thats rounded off and as i dont know what its called i cant buy a new one to replace it. and im not sure if ther is a sertain way to fit a new 1 back on? if any1 could help me thanks.
  • Anonymous Mar 19, 2014
    kick start gets stuck and sometimes isn't gripping anythink?r
  • 200 Answers
Usually a Honda part will fit those pit bikes. Honda 50-150 cc should fit. Take a file and clean up what you can of the splines on the shaft going into the engine. Fully remove the bolt and nut before removing the kickstarter as the bolt is in a groove to help retain the lever. Refit the new lever and tighten down well......Good luck to you...Tim
Posted on May 09, 2009
What is a tappet on my Apollo DB 125cc pit bike
Hi, Cory it's the arm that the camshaft moves to open and close the valves for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
how to set valves on pitbike
Pitbike Direct How to adjust your tappets
http://mypitbike.ru/downloads/OrionAssemblyInstructions.pdf
2 Apollo Dirt Bike Reviews Youll Want to Read
125cc pit bike carby service
Mar 19, 2016 | Apollo Orion 250cc Pit Dirt Bikes Pro
Oil is coming out of the vacuum line just above the front sprocket on my Apollo DB 125cc pit bike
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.miniriders.com/chinese-mini-s/35846-apollo-125cc-pitbike.html
new SSR 125 pitbike has oil leaking need help
Apollo DB X7 125cc Manual
http://getthemax.com/shop/powersports-products/manuals/apollo-125cc-dirt-bike-owners-manual-pdf
Mar 19, 2016 | Pit Motorcycles
I have a loncin 110cc pitbike and there is not a bit of conpression in the kick start
Take the cover off on the right hand side of the engine there is a bolt.... Undo it a bit and see if that helps.
if it doesn't check the timing, piston rings then gaskets
Mar 09, 2014 | Cycling
Over heating pitbike
Make sure oil level and viscosity is proper, clean out the head fins so engine can breath, lose some weight,(your too heavy for the bike), if water cooled? check rad-cooling fluid?
Feb 09, 2014 | Pit Bike 125cc 4 Stroke Dirt Bike
What front sprocket do I need for a 125cc engine with CDI wrote on the side?
If the one you bought is too big you need to get a 17mm centre one. 17t is the teeth and the next important bit is the pitch.
either 420 or 428. You can check by measuring how thick your sprocket is at its widest point, 6mm is 420 7mm is 428 :)
Jan 11, 2014 | Pit Bike 125cc 4 Stroke Dirt Bike
Why my pitbike wont start or cuts out
Yep, clogged fuel filter, dirty carb. ????
Mar 24, 2013 | Pit Bike 125cc 4 Stroke Dirt Bike
72cc pitbike kick start won't come back up after you kick it down ...?
mate whats happening is there is no recompression inside the engine pushing the gear to return id say you have done the gears in it and it would cost more to replace them than to replace the engine
Jan 28, 2013 | Pit Cycling
2008 110cc pitbike wiring pictures
are you getting a spark?
if not then i would suggest the kill switch has gone o/c put a meter on it on contenunity and it should buzz out when switched
John
Mar 12, 2012 | Pit Bike 125cc 4 Stroke Dirt Bike
When i hold the clutch in on my 125cc xsport pitbike there is a rattling noise in the engine like a ballbaring rolling round. help!
If it sounds like there's a ball bearing rattling around in your engine there probably is... take off the side cover and investigate it can't get any worse...if you keep riding it it'll only go bang and wreck the whole engine
Dec 16, 2010 | Pit Bike 125cc 4 Stroke Dirt Bike
Engine seized?
First thing to do is make sure it's the kick starter that has seized and not the engine. Take the cover off the end of the crankcase and try to turn the crankshaft. Apparently these engines were notorious for doing bottom ends. Start pulling it down and see what you find..
Jul 16, 2009 | 2004 Yamaha YZ 250 F
Cycling Logo
210 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
