Question about Krups FME4-11 12-Cup Coffee Maker
I fill my reservoir up with water. I turn the coffee maker on, and it will not brew. It shows that there is an empty reservoir
  • 298 Answers
SOURCE: Coffee does not brew
If you are elictrically inclined you
could take it apart and jump
across the switch with a jumper
wire or whatever avaialable means
see if it works all the time
thereby proving the switch to
be defective
Posted on Dec 07, 2007
  • 3 Answers
SOURCE: Coffee won't brew
It is probily the thermal switch between hot wire and element. Check to see if you are getting power through this switch.
Posted on May 19, 2008
  • 4 Answers
SOURCE: One year old coffee maker won't brew
I had the same problem, only this happened on the last 3 dcc-2000 I purchased. I called customer service today, and they informed me that there is a 3 year warranty on this product. Wow... This time they really helped. I have made 2 phone calls to customer service, and was put on hold for over 20min. each time they found out what machine I was calling about. Call customer service, and don't give up!
the number is 1-800-726-0190. you will need the serial # from the bottom of the unit (stamped in) and the model #.
good luck! Bob
Posted on Jun 10, 2008
t955i
  • 30 Answers
SOURCE: Error message states no water, but there is...
Unplug the device and plug back in after 1 min. If it still fails, then you have a dirty water level sensor or the control circuit board is fried. Empty the water out and fill it with vinegar as full as you can without overflowing. Let it soak overnight and turn the machine on (without coffee in it). Turn off after 30 secs.Turn on again and allow it to finish the cycle.  Discard the vinegar. Run three more brewing cycles with water only and it will be OK to use. If this does not cure it, then the only cost effective way is to replace it.
Posted on Apr 26, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart Grind and Brew will not emply all the water
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Posted on Sep 29, 2009
B70 does not brew,it says to descale
It may be clogged up with hard water scale. Fill the reservoir with white vinegar. Place an empty coffee mug in the unit and continue to run vinegar through it until the reservoir is empty enough that it is asking you to add more water. Leave the unit alone and let the vinegar stand in the unit for 8-12 hours. Fill the reservoir with water and run water through the device (you might want to do this several times in order to make sure the vinegar is completely gone).
Also check to make sure that the piercing unit is not clogged with coffee grounds.
Hope this helps.
Oct 04, 2014 | Keurig B70 Coffee Maker
I am descaling my Keurig for the 2nd time, it fills 2 cups w/vinegar and stops and won' start again, tells me its ready, help
A. Prepare
Step 1: Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug (Do not use a paper cup.)
Step 2: Empty the water in the water reservoir
B. Fill and Clean
Step 1: Pour the vinegar into the water reservoir and fill it to the top edge of the clear viewing area.
Step 2: Place a ceramic cup in the drip tray and run a brew cycle. DO NOT USE A K-CUP...just press the large cup button. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4: Now fill the reservoir with fresh water and let the brewer stand for 4-hours while it is still on.
C. Rinse
Step 1: Ensure the water reservoir is filled with fresh water.
Step 2: Place a ceramic cup on the drip tray and run a regular brew cycle. Once again, DO NOT USE A K-CUP...Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty.
Step 4: You may need to perform additional brew cycles if you notice any residual taste.
Jun 01, 2014 | Keurig Platinum B70 Coffee Maker
Doesn't always brew all the water, stops early
All coffee makers do this over time from calcium, lime, and mineral deposits building up inside the tubes and heating coil. Fill the reservoir with a 50/50 mixture of water and white vinegar and run a normal brew cycle, turning it off and on if necessary to completely empty the reservoir. Repeat this 2 or 3 times with fresh mixture of vinegar and water until it brews the reservoir empty without the need to cycle the power. Follow this procedure with plain water 2 or 3 times to clean the vinegar out. This should get it working like new again. It's best to use distilled water for brewing coffee as distilled water does not have the minerals that regular tap water has and therefore will not clog up the machine.
Mar 02, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
Hot water will not come down thru coffee
Your pour over coffee brewer has a reservoir that holds more than a pot of water. First thing you need to do is turn off the machine. Then put the empty coffee pot on the burner. Then take another container and fill it with fresh cold water and pour it slowly into the coffee maker until it starts to come out into the coffee pot. Stop pouring in water.
Now turn the machine on and let it heat up. Now you can brew normally. The reservoir has to be filled before you turn it on or you will end up eventually burning up the heating element.
Dec 31, 2013 | Bunn A10 Coffee Maker
WATER LEAKS BOTTOM OF UNIT WHEN IS MAKING COFFEE ALSO, HOW DO YOU DECALCIFY UNIT? iS THERE AN ON LINE MANUAL?
Below are solutions for a leaking coffee maker and how to decalcify the machine?
Tools and Materials needed to fix this problem are as:
* White Vinegar * Fresh Water * Volt-ohm Meter * Screwdriver
Step 1 - Clean
If your coffee maker seems to be clogged, try cleaning it with a mixture of white vinegar and water. Assuming that your coffee maker has a 12 cup capacity you will want to use 11 cups of vinegar and 1 cup of water. Fill the coffee pot to the 11 cup mark with vinegar and then fill it to the 12 cup mark with water.
Pour this mixture into the reservoir and turn on the coffee maker, allowing it to run through a brewing cycle as if you were making a pot of coffee. By doing this you will dissolve any build up in your coffee maker. If the coffee maker is leaking because the pump is clogged, then this might clear the clog and stop the leaking. If it has been a while since you last cleaned your coffee maker, you may need to run the vinegar through more than one cleaning cycle to dissolve all of the buildup.
Step 2 - Pump Valve
Unplug the coffee maker and examine the pump valve. If the pump valve is broken or has a clog, then the water will not be able to rise up and flow through the fill tube. When the coffee maker is turned on, the water needs to go someplace. If it cannot flow through the fill tube, then it may leak onto the countertop. If the pump in your coffee maker is sealed, you will need to replace the whole pump. If the pump is not sealed you should check it to ensure it is not clogged with coffee grounds or mineral deposits.
Step 3 - Brew Switch
Examine the brewing switch to ensure that is working. To get to the brewing switch, remove the base plate. Next, you will need to test the switch with your volt-ohm meter. Touch the tester to the RX1 scale. If it reads 0 ohms then you will know that the switch works fine. If it gives you a number other than 0 then it is time to replace the switch.
Step 4 - Tube Connectors
If the coffee maker is leaking or sputtering then you should take a look at the tube connectors. Many times, a leaky coffee maker is caused by faulty tube connectors. If you find the leak is in an elbow, clean the surfaces before you replace it. If the tube connector leaks, replace both the tube and the elbow so that you can be sure the pieces will both fit together properly.
To decalcify, you will be needing a : decalcifying cleaner and A container large enough to hold the same quantity of liquid as your water reservoir
1) Remove the machine's water reservoir. 2) Empty all liquid from the reservoir. 3) Fill the reservoir with warm water. 4) Add one packet of the recommended cleaner to the full reservoir and stir until the cleaner is dissolved. 5) Return the water reservoir to the machine. 6) Turn the machine on. 7) Set the large container underneath the steam wand. 8) Set up your machine so that hot water -NOT steam-will be emitted from the steam wand when the steam valve is opened. 9) Open the steam valve according to the manufacturer's instructions. 10) After all of the decalcifying solution has drained into the large container (within a few minutes this will occur), remove it and discard the liquid that has been collected. 11) Rinse the water reservoir thoroughly and then fill it with the type of water you usually use for brewing. 12) Return the water reservoir to its normal position. 13) Using only water repeat steps 7 through 9 until the water reservoir is empty again.
I hope the above helps....
Good luck.
Jun 22, 2011 | Jura Capresso Impressa S8 Coffee Maker,...
We have model # BKC800XL - it give us a message about "descale" not sure what that means and how to correct
Just like any coffee or espresso maker, descaling is a process that needs to be done periodically. If your location has hard water, you may need to descale more often than elsewhere, but it's nothing to worry about. It's just a chemical process that occurs as the result of mineral deposits from the water collecting on the elements inside the coffee maker. I'm sure that coffee manufacturers will sell you tablets for descaling, but I've always just used undiluted white vinegar as the reactant. To do this, I recommend: 1. Empty all of the water from the reservoir. 2. Fill with undiluted white vinegar. 3. For this type of coffee maker, brew as many cups as it takes to empty the reservoir, being sure to dump each cup in the sink as it finishes. 4. Once you've run through all of the vinegar from the reservoir, refill with water and run a few cycles to rinse. (You may want to leave the water to soak for a while to give the residual vinegar further time to clean off the minerals.) 5. Fill again with water and rinse. 6. Once you've emptied the reservoir a second time with the water, your machine should be adequately descaled and ready to brew coffee again!
Jun 17, 2011 | Keurig B60 Coffee Maker
The coffemaker won't brew and showed a descale message. What does that mean?
Scale---or mineral deposits---form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water
1.Unplug the coffee machine and remove the cup.
2.Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
3.Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
4.Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
5.Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
6.Unplug the machine and dump the water into the sink.
7.Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue
Dec 10, 2010 | Keurig B70 Coffee Maker
What is de-scale?
Descaling removes the deposits left behind from hard water. These mineral deposits will slow heat transfer if not removed from the heating element. To descale the coffee maker, use 48 oz of undiluted vinegar (household strength) and have a large ceramic mug to hold the output. Empty any water in the reservoir. Pour vinegar into the Water Reservoir and fill to the top of edge of the clear viewing area. Place a mug in the drip tray and press the Large Cup Button. (Do not use a K-cup.) When the brew cycle finishes, pour the contents of the mug into the sink.
Repeat the brew cycle until the reservoir is empty. Open and close the lid between cycles. When the reservoir empty, fill with water and let the coffee maker stand for 4 hours with the unit ON. After four hours, rinse the coffee maker by doing several brewing cycles (again without a K-cup). Discard the liquid after each brew cycle and repeat until the reservoir is empty.
You may need to perform additional brew cycles if you notice a residual taste.
For more information, including a pdf with the directions for descaling of the coffee maker, see http://www.keurig.com/customer-service/brewer-registration-and-support/frequently-asked-questions .
I hope this helps.
Oct 21, 2010 | Keurig B50 Coffee Maker
Apr 26, 2009 | Krups FME2 Coffee Maker
Descaling light on
Per Pages 9 and 10 of Keurig Model B40 Use and Care Guide,
1) turn off the "Auto Off "feature
2) fill empty water reservoir with 48 ozs of undiluted white vinegar.
3. Place ceramic cup on the drip tray and run a brew cycle. Do not use a K-cup!
4. Press the large mug Button
- let Keurig coffee maker fill mug with vinegar & empty in sink.
5. Repeat brew process until water reservoir of vinegar is empty. (remember to open and close lid between each cycle so large mug Button will flash.
6. Rinse the water reservoir thoroughly and fill with fresh water.
7. FINAL STEP RINSE CYCLE
a) place a ceramic cup on the drip tray
b) run regular brew cycles WITHOUT using a K-cup.
c) pour rinse water into sink each time.
d) repeat brew process until water reservoir is empty.
d) perform additional rinse cycles if you notice any residual vinegar taste.
e) if the red "De-scale" light remains illuminated after completing descale and rinse cycles, repeat the descaling procedure above.
Otherwise - you're good to go!
Apr 16, 2008 | Keurig Elite B40 Coffee Maker
Krups FME4-11 12-Cup Coffee Maker Logo
67 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
