Question about Motorola Mobility H700 Wireless Headset
H700 connects then disconnects self
Hi...I just got me a new motorola H700 headset seeing that I accidently drfove over my other one. I charged it and it paired with my phone without any problems. However when i went to use it tonight it connect then quickly disconnects and the purple light stays lit. I deleted it and started over but that didn't help..is the equipment faulty or am i not doing something right. your help is appreciated
Thank you Thank you Thank you!!!!!
I had tried everything, and your suggestion worked.
For those of you who are having trouble go to device list and click remove device.
Then turn your phone off, and then back on.
Press the call button on the headset until it turns purple, and open the boom.
Click scan for device on the phone, and then once found click pair.
My problem was that once I went through these steps it would say it was pair, and ask for me to connect. The headset would either stay purple or flicker blue, and the phone was say connected like it was stuck. I actually left it for over 2 hours once.
Once I had turned my phone off and on it just connected right up and now works.
Posted on Jul 08, 2008
I had the same problem with my Razor. The solution to the problem is the do a Master Re-set on your phone. To do a Master Re-Set, you will need to go to settings and tools=> select Initial Setup=> select master reset. Your phone will power off or it will go to the main menu so just wait a minute or two. Next you would pair your phone again with your Bluetooth.
Generally, this problem occurs for those of us that leave our cell phones on continuously. It is suggested that you turn your phone off at least once a week.
Posted on Dec 13, 2007
  • 150 Answers
Sound like a defect, I've seen this problem before right out of the package. Bring it back to the retailer and they should swap it for you. Good luck!
Posted on Sep 13, 2007
SOURCE:
How do I switch on Motorola H700 wireless headset. Mine is not coming on
Hi, do you have the manual with you?,If you do you can use itto know how to charge the blue tooth device,i think the battery is a little bit low and will need to be charged forlonger hours for it to be able to power up.
So you can use the manual to see how to charge the device.
Hope it helped .
Fell free to pass your comment .
Thanks for using fixya...
Jan 13, 2011 | Motorola Mobility H700 Wireless Headset
Problem with Blackberry Pearl 8100
Did you try deleting all devices paired and then try pairing again?
May 20, 2008 | Motorola Mobility H700 Wireless Headset
Motorola H700 won't stay connected
Your bluetooth is defective. Contact Motorola to get a replacement. This is THEIR fault. I had the same problem. www.motorola.com Hope i've helped you!!!
Mar 19, 2009 | Motorola Mobility H700 Wireless Headset
Motorola blutooth
the factory defualt pin is 0000
Sep 30, 2008 | Motorola Mobility H700 Wireless Headset
Motorola H700 charge issues
The rechargeable battery may have reached it's limit of recharges. You can try leaving it on until you no longer see life (any light) coming from the H700. You want to drain it completely. Than charge it, (take note of how long it takes to reach full). If it dies like before in 15 minutes than the H700 is dead. You can take it to a Motorola store & might be able to exchange it for less than you first bought it. Or you can go here (Click the link) for a new one. http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=Motorola+H700&image12.x=13&image12.y=15
Luck!
Mike
Apr 01, 2008 | Motorola Mobility H700 Wireless Headset
H700 automatically disconnects though fully charged
I had the same problem. It does seem to be related to the battery. The solution--in my case--was to recharge the headset until the light turned green again and then flip it open and it hooked up again.
Mar 13, 2008 | Motorola Mobility H700 Wireless Headset
Motorola H700
I say uninstall this device from the phone's bluetooth devices and reinstall it fresh
Dec 12, 2007 | Motorola Mobility H700 Wireless Headset
My H700 does not connect. When I attempt to connect it shows the disconnect option but it isn't connected
My bluetooth does not work at all. Have had it on charger for days. It does turn purple, but does not work when I put it in my ear. Have checked the connection. It just seems dead. Bought it last November, but first time I've had a problem. Can you help? Barbara
Jun 20, 2007 | Motorola Mobility H700 Wireless Headset
Headset disconnecting frequently
I think that the problem is with the on/off switch inside the headset boom. Mine has been doing the same thing lately. I'd like to find out how to fix it myself, cause I'm sure having it repaired would cost about as much as just buying a new or better headset.
Jun 10, 2007 | Motorola Mobility H700 Wireless Headset
Trouble connecting h700 to phone
First: When charging the light should be steady. If the battery is less than 20% charged it should be red. More than 20% it will be yellow. Fully charged it should be green. Make sure your microphone is closed when charging.
Second: Have you "Paired" the H700 and the phone? If not you need to. To put the H700 into "Pairing Mode" do this:
Make sure the H700s microphone are is in the off position. Push in and hold the button on the H700 until the light lights up purple. Release the button and quickly open the microphone button. The light will stay purple and you are now in "Pairing Mode". Now follow the instructions for your phone to pair with a BlueTooth unit. When it asks for a code, use 0000 (that is 4 zeros).
Your phone and H700 should now be connected.
Hope this helps a bunch!!!
Jan 04, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
523 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
