Question about 2wire (1000-000005-002) 802.11g/b Wireless Adapter
Want guests to be able to use our AT&T U-Verse broadband network.
Example: HP ze4240 laptop with Linksys WPC54G adapter cannot connect. Ethernet cable provides good connection. Computer recognizes the network with adapter installed, but cannot connect. Broadband is through 2Wire 3800HGV-B.
  • 108 Answers
Try checking your wireless security settings to make sure you are using the correct wireless key (password).
Posted on Jun 10, 2009
Do I need any special equipment other than the ethernet cable connection for my linksys broadband wireless-g router
That's all you need to get your wireless internet up and running. However, in order to connect computers to the wireless network, they must be wireless capable, for example, most laptops have built in wifi, however desktops will need a wireless adapter to take advantage of your wireless router.
Mar 03, 2011 | Linksys Wireless-G Broadband Router
My linksys wpc54g repeatedly says "network cable unplugged" then reconnects
WPC54g is a wireless adapter. The message that you are getting is the message for the Local area connection. This message has nothing to do with the WPC54G. This message is for the wired connection and not for the wireless connection.
May 16, 2010 | Linksys WPC54G Wireless-G Notebook Adapter...
Broken Ethernet Port
You say "your Ethernet Port" (= LAN port)
If unavailable try using any USB to rj45 adapter and you can use any USP port.
Check this device:Linksys - USB200M - Compact USB 2.0 10/100 Network Adapter (20 $?) or similar
Dec 28, 2008 | Linksys Wireless-G Broadband Router
Linksys WPC54G Wireless-G Notebook... Problem:
Your computer locking up could be a spyware or virus program taking over your machine as soon as you get an internet connection.
Try connecting the laptop to a wired connection and see if it does the same thing.
Run some virus scans from trend micro.
If you can re-install the software for the wireless card. This might help too.
Firefox can freeze your system but highly unlikely from a fresh install.
best wishes.
Oct 31, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
T40 does not have wireless network adapter, how should i do to ues the wireless router?
Since your laptop don't have a wireless adapter , first thing that you can do in order for you to use the laptop to the internet with the wireless router is to connect the laptop to the router via CAT5 /Ethernet cable then that should now be able to access the internet , but if you want to make the laptop work wirelessly with out the cable connected to it, you can get a wireless adapter like this from Linksys WPC54G or a WUSB54GC if you have any of this wireless adapter you can now use the laptop wirelessly with the router.....
Hope that helps............
Oct 07, 2008 | IBM ThinkPad T40 2373 Notebook
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Connecting 2 pcs with a single pc modem
if you have a landcard in your laptop you can use a wired connection to your laptop.. be sure you have a UTP cable to get through on it.
Jun 12, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Linksys
I used to have a Linksys WPC54G. Thia is normal for the LinkSys WPC54G. How ever in your configurations make sure everything is enabled. But as this being a wireless adapter you should make sure you use AdHoc Mode configurations and set it to channel 6 works the best and set it to G-Only mode not mixed..See the network light blinks and it should be flashing fast for it to conect. I had this same problem. I decided to reconfigure my Linksys to AdHoc and it seemed to work better form me. For as the secure links I set them at non secure and I manually set up my IP Address which is 192.168.1.01-255 Sub net mask is 255.255.255.0 Default Gateway is 192.168.1.1 DCHP Server is also 192.168.1.1 I do hope this helps if it doesn't I say try moving your laptop around until your Wireless Network enables. there is always Tech Support on Linksys.com also. Good luck and I hope this works for you.
Feb 06, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Where do i find the network key?
You can find the network key (wep key) on the web interface of your Linksys router (192.168.1.1), under the Wireless tab, look on Wireless Security.
Nov 28, 2007 | Linksys Wireless-G Broadband Router
2wire (1000-000005-002) 802.11g/b Wireless Adapter Logo
395 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
