Question about Protron PLTV-32 Television
Protron dvd-rw lost remote
Cannot find any codes that are for protron anywere to use on a universal remote! The "search" steps used dont work or control the wrong things
I have the same problem, and you have two options: (1) Buy a Logitech Harmony remote - they are expensive, but their database probably has the codes. (2) Go to remotes.com and get the original for $40 or so. Use a learning universal remote to grab the codes, and leave the original remote in a safe place.
Posted on Oct 03, 2007
SOURCE:
Need the device code for comcast customs dvr remote control
Comcast Universal Remote - Red OK/Select Button
There are no codes for
Protron DVD player you need to use the search mode on the remote here is how.
S
earchching For Youour Code
If your home entertainment device does not respond to the remote control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.
For example, after trying all of the codes for your TV, you still cannot get the remote control to operate your TV, then:
1. Turn on your TV.
2. On the remote control, press TVTV once. Then press and hold Setup until the TVTV key blinks twice, then release Setup.
3. Enter 9 - 9 - 1. The TVTV key will blink twice.
4. Press and release the digit 1. The TVTV key will blink twice.
Note: Substitute 1 with 0 if searching for a Cable code, 2 if searching for a DVD, VCR or PVR and 3 if searching for an Audio device
5. Press Power and aim the remote control at the TV and press CH + one or more times until the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
6. Press Setup once to lock in the code.The TVTV key will blink twice.
7. To search for the codes of another device, repeat steps 1 to 5, but substitute the AUX key for the device you are searching for.
Jan 23, 2011 | Protron PD-800 DVD Player
Cinevision DVD player work with RCA universal remote?
You dont have codes for cinevision DVD player.So it cannot be programmed with Codes.
You can try programming withot code
Please follow the below steps.If it dont work then your cinevision DVD player donnot support RCR460 remote.
Code Search:
  1. Turn on the device you wish to control.
  2. Press and hold "CODE SEARCH".
  3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
  4. Release "CODE SEARCH".
  5. Press ON/OFF repeatedly until the device turns off. You may have to do this up to 100 times.
  6. When the device shuts off press and release ENTER.
  7. Try using the remote. If it does not function repeat steps 1 through 6.
Thanx
May 07, 2010 | RCA RCR460 Remote Control
What is the remote code number? my remote is not working and I am trying to program a universal remote, but can't find a code (protron pltv3250)
If your universal remote has a code search function (most do) you may have to try that. Allot of off brand tv's are manufactured by other companies. Check the back of the TV to see if there is a label that says "manufactured for Protron by ..." If a code search doesn't work post back with the brand of remote and we can try help you further.
Dec 30, 2009 | Protron PLTV3250 32 in. LCD Television
I lost my book
Step1, press the code search button until the led light stays on, then release button, Step2 press what equuipment you want to control, (tv, vcr, dvd, audio) then release. Step3, If you know what codes were used, press the code numbers in and the led will blink 2 or 3 times to comfirm it accepted the code. if you do not know the codes, do Step 1 and Step2, then Press the power button continuosly until the equipment you want to control comes on.
Hopefully this will work for you. This is the way my RCA Universal Remote works.
Good Luck,
Skyassoc
Jun 17, 2009 | RCA 4-Device Universal Remote
Can you help me program my remote?
hi i have a philips universal a rca tv and a dvd named lennox sound 2003 i want to program the dvd with the remote please help no codes lost
Feb 09, 2009 | Philips Universal PH301S Remote Control
Lost my remote what is the code for a protron pltv-20 tv to program a universal allforone remote urc-31. thank you
Get a universal remote and run a "search" through all the codes, then just follow the instruction for engtering that code...
Dec 31, 2008 | Protron PLTV-20 20 in. LCD Television
Lost code book
i lost my book of codes for protron t.v i need a code
thaks for your info :)
Dec 12, 2008 | Universal Remote Control Hampton Bay...
Remote Control code for DVD Protron PD-800
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
https://electronicshelponline.blogspot.com/
https://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Feb 05, 2018 | Protron PD-007 DVD Player
Vertical Hold
i need the code to program my universal remote to my dvd player
Oct 24, 2007 | Protron PD-007 DVD Player
The code I used and it seems to work is 0194, but while trying to program my receiver, It changed some setting and the picture keeps looping over and over on the screen, and I can't get it to stop, I even made it worse while messing with the settings....
May 14, 2007 | Protron PD-800 DVD Player
Protron PLTV-32 Television Logo
147 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
