Question about Intel D945GCL Motherboard
How to connect 2 PC's on a single ADSL2+ connection so that both can connect to net simultaneously
  • AliTech110
    AliTech110 Apr 13, 2009
    OK, i'll give it a try. Thanks
    President:
  • 948 Answers
Use a router for that. Connect your DSL modem to the router's WAN port, then connect your computers to the router's LAN ports.
Posted on Apr 13, 2009
How do I ix my adsl2 comtrend modem when the internet light will not come on
If internet light is off, its not connected to the net. Check all connections. If OK try pressing and holding the rest button for 30 seconds.
Jan 25, 2015 | Comtrend Adsl2 Ethernet Router Model:...
Problem connecting to internet while pc and ps3 are hooked simultaneously
I think the broadband connection you are using is not enabled for NAT ( Network Address Translation).
This is required to give internet access to more than one system through a single internet connection.
If NAT is not enabled or supported by your broadband router then you cant access internet through more than one system simultaneously.
Jan 07, 2011 | NetGear FS605 (FS605SE) Networking Switch
I am using dlink wireless router. How can i restrict unauthorised users accessing net through my connection?ADSL2+router
By using your wifi security.
Log on to the router and turn on WPA2 security, choose a password, and you should be ok
Sep 23, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
My ADSL 2+ works fine with wireless, but not with a local area connection. My PC uses this. I,ve switched cables, tried a cable with the laptop, and reset the router. No change. Any ideas? Steve
If the wireless connection is working fine it show that your internet security is fine and you can access net without problem
there could be a connection issues a within the cables
1) Connect the Ethernet cable to the Laptop and connect the other end to router E1.
2) Open the command windows (DOS ) by typing cmd or command on the Run option ..
START- RUN- type command then hit Enter
3) In the black command windows - Type IPCONFIG
c:\> IPCONFIG hit enter
it will provide with the correct IP ADDRESS and Gate Way Address
Check the gateway address - shout strat with 192.168.X.X
If it is not there is some problem -
4) Check the Device manager and check the Ethernet Adapter whether the adapter is enabled or Disables or Drivers are installed or not
Aug 10, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Not recognize my pc but not laptop
I have yet to see a single DSL modem that will allow USB and Ethernet connections simultaneously (and actually work properly). You should install a DSL router instead.
May 08, 2009 | AT&T High Speed DSL Modem
Win xp sharing connecion
For Windows XP Professional, the maximum number of other computers that are permitted to simultaneously connect over the network is ten. This limit includes all transports and resource sharing protocols combined. For Windows XP Home Edition, the maximum number of other computers that are permitted to simultaneously connect over the network is five. This limit is the number of simultaneous sessions from other computers the system is permitted to host. This limit does not apply to the use of administrative tools that attach from a remote computer.
Feb 01, 2009 | Microsoft Windows XP Professional With...
Internet connection
yes one can connect to you wireless network if it is unsecured to connect to the internet....
its possible.....
but it is illegal and one shouldnot do that.....
Jan 22, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Internet connection
1. Change channel used by Access Point
2. Try to set up router to different security, this problems may happens for WPA authentication.
Mar 25, 2008 | D-Link Wireless
How to configure paradign modem adsl2 6211-A3-304 in bridge mode for BSNL Dataone Broadband connection
I belive with this modem you will:
1.Access the interface, generally http://192.168.1.1/
2. Go to Advanced on the left.
3. Select WAN.
4. Now you may see several rows of info, look for the one that says PPPoE, and then click edit to the far right.
5. Select Next one time.
6. Here select "BRIDIGING".
7. Click next all the way to the end.
8. Reboot, after you clicked save of course.
This is how you bridge 98% of PPPoE providers with a similar paradign modem.
Of course the next device in line will have to provide your username and password for your DSL connection.
Hope this helps!
Feb 08, 2008 | Paradyne (6211-A2-200) Router
Intel D945GCL Motherboard Logo
193 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
