Question about Breadman TR2200C Ultimate Bread Maker
Loaf Pan Cracked
I need to locate a new loaf pan for my breadmaker and can not locate one. Help!!
  • 1 more comment
  • Anonymous Nov 29, 2007
    Same problem, but the part number suggested wasn't quite right for our machine. The part shown has 3 rivets, while ours has 4. Our machine is a TR2200C, as suggested here.
  • Anonymous May 29, 2008
    Non-stick surface is gone.
  • Anonymous Jun 14, 2008
    My Breadman TR220C loaf pan has developed a serious leak that I have not been able to fix.  It leaks around the drive shaft and one of the mounting rivets.  Hof can I find a replacement?
    New Friend:
Just called Call Phone number: 800-231-9786 and they say the 4 rivet baking pan is no longer available anywhere
Posted on Feb 10, 2010
  • 24 Answers
The replacement loaf pan for the TR2200Cis available from : https://www.esalton.com/
The part number is: 22399.
Type this number in the search window at the top right of the homepage.
Click on the search button.
This brings up a parts list. At the bottom left of the list is a button marked next. Click on in.
You should now see the part number 22399 at the end of this list.
Enter the quantity you require, if one, just click on the add button.
Back at the top of the page just under the search window, select shopping cart and click on it.
From there you will complete your transaction and the part will be sent to you.
Sometimes their site is finicky, so if it doesn’t do as it should, short of paying for the item you need twice, do it again.
Just as a side note, the breadpan does not come with the kneading blade. That is part number: 22400.
You order it following the same procedure as above, but obviously you will need to use the correct part number. It can be added to your order before checking out with the breadpan if you need both.
Good luck with your replacement breadpan.
36YearVet
Posted on Nov 27, 2007
Here is what you can do:
Call Phone number: 800-231-9786 (Monday-Friday, 8:30 AM to 11:00 PM and Saturday-Sunday, 9:00 AM to 5:30 PM, Eastern Time).
Have your model number and 4 digit stamped on date (mine was warn off).
You can ask for the following part numbers:
Bread Pan 22399
Paddle: 22400
Also Mar-Beck's carries the paddles on line: http://www.marbeck.com/
You have to call to see if they can get ahold of a pan and the cost.
Posted on May 05, 2008
Website doesn't exist
Posted on Feb 10, 2008
I have 2 if you still need! use contact us on www.islandwoodcraft.ca
Posted on May 12, 2008
SOURCE:
Is it a one or one and a half pound breadmaker?
Here is how you determine that:
Bread pan Capacities
Here is how you determine the size of loaf you can bake in your machine. You need to determine the capacity of your pan. Fill your pan with water and measure the cups added so you know how many cups of water are in the pan when it is full to the very top. Here are the conversions:
1)If your pan holds less than 10 cups of water you can make: a 1 pound loaf
2)If your pan holds 10 cups of water you can make: a 1 pound loaf and a 1.5 pound loaf
3)If your pan holds 12 cups you can make: a 1 pound, 1.5 pound, and a 2.0 pound loaf
____________________________________________________________________
This is rare, but if you pan holds 14 cups or more you can make all the above plus a 2.5 pound loaf
Feb 14, 2015 | Breadman Trillium Tr500
What is the loaf size for a Williams-Sonoma WS1094 bread machine
Jul 20, 2011 | Williams-Sonoma Brushed Stainless Steel...
Recipes for b&d breadmaker model 2300
Knowing your breadmaker's loaf capacity will enable you to find recipes of any variety on the Internet for free.
It will also keep you from adding too much ingredients which could cause dough to over-rise and spill onto the heating element.
Remove your bread pan from your breadmaker. Using a one-cup 8-fluid-ounce liquid measure, fill your bread pan with water. As you do, count the number of cups it takes to fill your bread pan to the very rim.
Generally speaking...
If your bread pan holds 7 & 10 cups to the rim then you have a 1.0 lb or 500 g loaf pan
10 & 11 cups to fill = 1.5 lb (700 g) loaf pan
11 & 13 cups to fill = 2.0 lb (900 g) loaf pan
13 & 15 cups to fill = 2.5 lb (1250 g) loaf pan
15 & 17 cups to fill = 3.0 lb (1350 g) loaf pan
A bread recipe for use in a 1.0 lb (500 g) breadmaker should never exceed 2-1/4 total cups of flour.
1.5 lb (700 g) = 3-1/4 c
2.0 lb (900 g) = 4-1/4 c
2.5 lb (1250 g) = 5-1/4 c
3.0 lb (1300 g) = 6-1/4 c
Warning: When testing a new bread recipe it is always best that you not leave your breadmaker unattended. Stay close by to monitor its progress from time to time.
Did this answer help? I hope so. Please rate it as soon as you can. Thank you.
Jun 26, 2011 | Black & Decker B2300 Bread Machine
Hi, I need to know what size loaf of bread my bread maker makes so I can figure out the recipes it will make. It doesn't say anywhere on it what size loaf pan it has. The model # is: WS0598 Thanks!
Apr 13, 2011 | Williams-Sonoma Kitchen Appliances -...
I have a breadmaker No. 41063 and would like to know if it is a 1lb 1/2 machine., I have lost my manual.
If you still need a manual I have them available...thanks!.....email me at [email protected]
Feb 21, 2011 | West Bend 41062 Bread & Dough Maker
Bread size
Jan 30, 2011 | Oster 5838 ExpressBake Bread Maker
How do i know if it is a 1 or a 11/2 pound machine?
Jan 01, 2011 | Kitchen Appliances - Others
How many pounds does the trillium tr-500 bread baker make? 1 or 1 1/2 lbs?
Nov 27, 2010 | Breadman TR500 Bread Maker
I'd like to know the loaf size/weight for a Welbilt ABM-100-3 bread machine - 1 lb or 1.5 lb
Nov 25, 2010 | Kenmore KTR2300 Bread Maker
I have a Toastmaster Automatic Breadmaker. Model 1196. I need to know if it is 1 pound or 2 pound breadmaker. THanks
Nov 25, 2010 | Kitchen Appliances - Others
Breadman TR2200C Ultimate Bread Maker Logo
1,742 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
Steve Allison
Steve Allison
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
