Question about Acer Aspire 3000 Notebook
I wand to install internetcontroller driver because i can't install local area network connection
  • Acer Master
  • 4,338 Answers
Find them here, select notebook in your product line box and Aspire3000 in the on the right.
Then look down the list for the Lan driver
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3394#results
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Apr 13, 2009
Hi di i wand driver for pcoket pc xv6700
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
http://download.cnet.com/dm9601-usb-to-fast/3000-2112_4-72413.html
hope it helps
Apr 12, 2012 | Genica USB to RJ45 Ethernet Adapter...
No wired network connection
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
hope this helps
Nov 27, 2011 | HEWLETT-PACKARD Pavilion p6674y...
I got a wrt54gh router just less than a year now. it is connected to our desktop being used by my son & grandson in our living room, while i'm using my laptop in my room. it just happened that i...
If you have Windows XP then try this, for Windows 7 and Vista also the procedure is similar. If you have Vista or 7 then tell me I'll post the tutorial for that also.
  1. In Windows XP, click the Start button and select Control Panel.
  2. Click the Network and Internet Connections category.
  3. Note: If you are using Classic View, you will see the control panel icons instead of categories. Double-click the Network Connections icon.
  4. Click the Network Connections control panel icon.
  5. Double-click Local Area Connection, listed under LAN or High-Speed Internet.
  6. When the Local Area Connection Status window is displayed, click the Properties button.
  7. In the Local Area Connection Properties window, do the following:
    • Verify that the Internet Protocol (TCP/IP) box is checked.
    • Note: If your Ethernet adapter is not listed in the Connect using box, you need to install your adapter.
    • Click Internet Protocol (TCP/IP) once to highlight it and then click the Properties button.
  8. In the Internet Protocol (TCP/IP) Properties window, do the following:
    • Click Obtain an IP address automatically.
    • Click Obtain DNS server address automatically.
Apr 11, 2011 | Linksys Wireless-G WRT54G Router
My internet isnt c0onnecting... i just installed vista.. and its saying there is no network hardware installed or configured... i dont know whats wrong plz help ... thanks
  1. Click Start , and type Recovery Manager in the Search field. Click Recovery Manager when it appears in the menu options.
  2. Click Advanced options .
  3. Select Hardware program re-installation and click Next .
  4. On the Welcome window, click Next .
  5. When prompted to recover a hardware driver shipped with the computer, select Yes and click Next .
  6. From the list of drivers, select the proper driver, and click Next .
  7. Allow the PC to re-install the driver, and when prompted to restart the computer, select Finish
  8. For a PC with Vista
    1. Click Start , enter Network and Sharing in the search field, and then select Network and Sharing Center from the list.
    2. Select Manage network connections in the left panel of the Network and Sharing Center window. The Network connections window appears.
    3. If the status of your Local Area Connection is disabled , right-click the Local Area Connection icon and select Enable .
    4. Right-click the Local Area Connection and select Properties .
    5. On the Networking tab, select the IP Protocol (TCP/IP) connection and click Properties .
    6. On the General tab, verify that both the Obtain an IP address automatically , and the Obtain DNS server address automatically options are selected, and then click OK to accept the values.
    7. Restart the computer.
Feb 04, 2010 | Intel D101GGC Motherboard
Need to find network driver
Solution:
i) Click on  Start button ---->Select option Control Panel------>Select Network Connections----->
   a new window appears showing the "internet connections icon " Such as:
   Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1:   Local Area Connection 1 or 2 or 3
       Network Cable Unplugged, Firewalled
       VIA compatible Fast Ethernet
   in this case u can download VIA network drivers....from internet..
       or
  eg2:  Local Area Connection 1 or 2 or 3
          Realtek RTL8139 Family Fast Ethernet NIC
   in this u can download "Realtek RTL8139" network  drivers.... from internet(which is showing model    no: RTL8139 through google search engine )
                                                          (OR)
ii) Click Start button ---->Select RUN option ----> type in the text box    devmgmt.msc  --->Select Network Adapters....
but this will show wheter ur network adapter or NIC is VIA or Realtek or......but does show the correct Model NO: of VIA or Realtek....
so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Dec 27, 2008 | E-Machines eMachines Refurbished EMA...
Create a local area network
you can get a HP x175 printserver. (not expensive.) and connected it between the printer and the router. that way you don't have to have the desktop on all the time.
Dec 02, 2008 | Computers & Internet
How do i build a local area network in windows xp?
On the machine that the printer is connected to go to Start>Control Panel>Printer and Faxes>Right click the Printer that you want to Network and Left Click Sharing> Select the Option to Share the printer and Name it something that you wil remeber. On the Laptop go to printers and Faxes select add new printer and select Network Printer. And Choose the second option Put the Name of the Computer that the printer is connected to and then printer name. Example \\Desktop\HpPhotoSmart 8100. Also you will need to check to make sure that both machines are on the same Domain\Work Group. Go to Start>Control Panel >System>Computer Name Tab ( Here verify the Machines Name)> Join or Change Domain>Put the machines on the same Workgroup if they are not, Do the same on the laptop. To test this, on the laptop go to Start>run and type \\Desktop Name and you should see what is able to be shared. Walk thru the steps above to install the printer on the laptop and have the intall cd in the laptop to install the drivers and you should be good to go. I hope this is understandable. If not feel free to email me at smichael@phoenixschool.net and I will see if I can clarify this for you. Happy networking!
Although the internet connects on my PC my laptop won't connect via the router
check that your router is working that lan cable is working, and right click on network places in your laptop screen go to the properties and check there local area conection is enable if disable enable it and check your ip, if there is no local area conection you have to install the network adapter driver
Sep 27, 2008 | Computers & Internet
Hiii sir
some softer drivers are included under windows, some are not, like for example your network drivers arent. u will have to install them manually from the CD that came with the motherboard.
Hope it helps
Z33m
Dec 10, 2007 | Mercury P4VM800M7 Motherboard
Acer Aspire 3000 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
