Question about GE WJSR2070B Top Load Washer
Old GE Washer WNSR2100T8WW will not pump out water nor spin
I have this old GE washer that will not pump out the water or spin cycle.This happened all of a sudden one day when I was washing clothes and came back and found water still in the tank. It agitates but will not run the spin/pump cycle. I was told to replace the timer switch, which I did, and it does the same thing. I had replaced the pump about 2 years ago. Can someone give me some advice.
  • Lindah8 Jul 21, 2008
    Our Kenmore washer is not draining and won't start the spin cycle. I took off the cabinet and looked at the pump and hoses, but they look clear. Perhaps it is an electrical problem? Any suggestions would be greatly appreciated!
    New Friend:
Well, if your timer switch is good than check the pump for obstructions like piece of clothes or just random garbage, Check this web site also it has all videos on how to fix your washer.http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/GE-washers.html
good luck!
Posted on Feb 26, 2011
    President:
  • 1,294 Answers
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Posted on Sep 12, 2007
SOURCE:
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
Won't advance to spin cycle from drain cycle
install new timer....thumbs up...
VE6GAR 73 88 99
Aug 10, 2009 | Washing Machines
GE washer will NOT spin, but does all other functions.
You need to have the fan belt checked. It must have been loose or broken.
Jul 22, 2009 | GE WSXH208A Front Load Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Chugging like noise during certain cycles
your clutch need to be replaced as does the tub shaft bearings i;m sorry this is not a do-it-yourself job, try to make a deal to trade in your washer
Apr 22, 2009 | GE Washing Machines
GE WCSR2080B4WW - After wash cycle the washer does not spin and..
your washer must drain to spin.you may have a blocked or failed pump.you get to it thru the frount.use a putty knife between the lid and the frount ,push the springs.top comes up take frount off.pump has two hose .pumps white or tan smaller.God bless,tom
Jan 01, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
GE toploader Washing Machine pumping problems
Sounds like the water is syphoning away due to the drain outlet hose being too low..Raise the hose higher, and this should solve the poroblem.
Oct 31, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
GE Top Load Washer 10 yrs. old, used for 3 years, stored after that
the water must drain out of the tank b4 it can spin make sure the pump is working ok
Nov 17, 2007 | GE WBSR3140DW Top Load Washer
GE WJSR2070B Top Load Washer Logo
621 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
