Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Lights out inside refrigerarator and making noises
The lights are out inside the refrigerator and it makes wierd noise when you open the refrigerator. The food seems to be cold, but not sure if it keeping cold.
  • 121 Answers
Bad door switch unplug and pry out switch and replace the sound you are hearing are wires burning
Posted on Apr 13, 2009
Samsung model RS263TDBP/XAA
How to Test the Fridge Fan on Samsung Refrigerator Once you have the fan motor out put a drop of machine oil in the bearing caps. That will stop the noise.
Feb 14, 2018 | Refrigerators
Wierd beeping noise
bad seatbelt connection
Feb 05, 2018 | 1999 Dodge Caravan
Last night, the freezer door on my older GE Profile fridge got left slightly open. This morning, it was making a loud noise and some of the food inside was starting to thaw. I turned it off for awhile...
The door being left open would have caused frost to form around the evaporator fan motor and that would be the source of your noise.
If the lights are still working then it is probable in defrost, wait about 30-45 min and see if it turns back on. If not then you might have a different problem.
What is the model number for your fridge? The model number is normally in the fridge on the right hand side.
Mar 13, 2013 | Refrigerators
MY WHIRLPOOL SIDE BY SIDE IS MAKING WIERD NOISES - WHIRRING SOUND. COMPRESSOR?
A whirring sound? Can you tell whether it is coming for the inside of the freezer or underneath the unit? I would suspect one of the fans either blocked by something or starting to go out.
Jan 31, 2012 | Whirlpool ED5SHAXM Side by Side...
Hi, my refrigerator door squeals very loud when you open it. The freezer side door does not make noise. I think it might be a washer at the bottom of the door, but I don't want to spray it with a...
You can try a silcone spray, that shouldnt damage any plastics or rubber. Also check the door seal. Make sure its clean. Sometimes, cordials, coke etc spill onto the door gasket and become all sticky which causes some wierd noises when you open the door.
Jul 26, 2011 | Admiral 26 cu. ft. Side-By-Side...
Fridge freezer stopped making ice digital display has gone off at the front of appliance, when you open door lights flicker and it makes a noise.
I have seen this a few times on whirlpool refrigerators. There is likely a high voltage board mounted inside a grey or white box mounted next to the compressor. The noise is usually eminating from this box, and replacing the board will solve all of your problems most likely.
Sep 23, 2010 | Whirlpool Freezers
A very unusual 'croaking' frog like noise from the back of the freezer compartment. It stops if the freezer door is opened and starts again once closed. The freezer light switch is involved: With the...
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Jun 05, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Whirlpool gold refridgerator light not working and is making funny noise
switch of your refrigerator then try replacing the light that doesn't work then try to switch it back on. the light might be the cause of the noise. it might be grounded. replacing the light might reduce the noise then observed the noise for a week then if it still making noise that's the time for you to get a technician that could fix your refrigerator.hope it helped... send us a message for more concerns thank you...
Jun 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Black on Black 21.9 cu
I had the same problem. The light would dimly flicker and make a sort of clicking noise. It was still under warranty and the repair man had to replace a circuit board in the back. Not sure of what the cost would be if not under warranty. Hope this helps.
Oct 23, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
147 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
