Question about Kenmore 27032
Kenmore Model 27032 lid problems
I just got my new top loading washer, and when I hit start the "lid" light comes on and the washer won't start. I don't know if I'm missing a part on the lid because its like the lid just lays there nothing actually will lock or catch.
  • fisherman424 Sep 12, 2007
    I'm not sure what you mean by lid switch but there is a locking thing on the front side of the washer. I looked at a new one at Sears today and I don't think I'm missing any parts. They told me that the lid just sits on top of the opening and then it locks.
  • 641 Answers
Look for the lid switch and press on it manually. Let me know if it will operate the machine.
Posted on Sep 12, 2007
SOURCE:
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
The contact button (part where you put the door down to make the washer start to agitate) something came apart....washer is filled with water and now won't go. The part came out.
you broke the lid switch,send the full model number located under the lid,lift the lid up,follow the lid to the bottom and look right under it and you'll see the model number,it will start with like 110.
Aug 30, 2011 | Kenmore 22422 Top Load Washer
Kenmore washing machine does not click into rinse or spin cyle, only aggetates
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jul 14, 2010 | Kenmore 27032
Washer won't start unless you hit the lid with
Somewhere the connections is loose OR the lid is not closing properly
Nov 16, 2009 | Kenmore 23812 Top Load Washer
Kenmore elite will not start
the lid or door must close to start the washer.. check the lock and the striker on the door... hope it helps..
Sep 18, 2009 | Kenmore Elite 45986 Front Load Washer
Washer fills with water, then stops
OBVIOUS REPL LID SWITCH AND SHOULD SOLVE YOURE PROBLEM 100 % MAYBE INSTALLED IN CORRECTLY,, TAKE A LOOK AT YOUR LID MAKE SURE BUMBER IS ON AND NOT TWIKED
Nov 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer won't come on
HI sorry the chat just quit on me i was not done. i would check the lid switch. the little piece thats on the lid goes into the top and hits the lid switch. look at that
Oct 13, 2008 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Kenmore 27032 Logo
329 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Paula Hamilton
