Question about Brother XL-5130 Mechanical Sewing Machine
Brother XL-5130 Sewing Machine
I am having a difficult time trying to thread the bobbin for my Brother XL-5130 sewing machine. I have moved the silver bar to the right and placed an empty bobbin on it. The problem I am having is I cannot figure out how to attach the thread to the bobbin. The bobbin has 2 holes and I have tried it every which way and it threads above it or below it. Help please! How do I start to thread the bobbin
Make sure that when you insert the thread *top hole bottom to top* that you turn the bobbin itself until you hear a click *that is the spring sliding into the ****.
Posted on May 02, 2009
  • 37 Answers
Http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_5130_5232_5340_EN_208.PDF
Feed the thread thru one of the holes (the hole that will be on top) going from the middle of the bobbin thru to top. pull up about 2 inches, push the bobbin over to start winding and before pressing the foot, hold the 2inch piece sticking up. HOLD TIGHT. after the thread is wound about 25 times, stop winding and snip the 2inch piece level with the top of the bobbin. Finish winding.
Posted on Apr 15, 2009
2 Suggested Answers
SOURCE: Brother XL-5130 Sewing Machine
Put the thread through one of the holes. Then put the bobbin on the spindle. Pull about 3 or 4 inches out of the hole and hold on to it. Start winding the bobbin. After about ten turns, or when the winding thread is secure, you can stop the machine and cut off this 3 or 4 inch tail. To insure that the thread winds up and down the bobbin and not off the top or bottom, there is probably a metal bobbin tension disk that the thread must pass around before it goes to the bobbin. It is probably on the left of the machine and may or may not be part of a thread guide. The thread must pass around this disk on its way to the bobbin in order to put tension on the thread so it will wind properly. If you can't find the disk, which is a small metal button or screw with some type of somewhat moveable spring cap, you can just get the thread to pass through your thumb and forefinger. Hold your hand 6 or 8 inches to the left of the bobbin and pass the thread between your thumb and forefinger so that it makes the thread go in a direct straight line to the bobbin. Pinch the thread only enough to keep it taught but not tight and let it flow through your finger to the bobbin. The thread should go up and down evenly on the bobbin. If not, move your hand up or down to position it so the thread will wind up and down smoothly. It will not be necessary to move your hand once you find the correct position needed for winding.
Posted on Jul 20, 2007
Thread keeps knotting up under the fabric (bobbin area)
Could be what is called thread nesting or bird nesting.
The first thing to try is installing a brand new needle in your machine. Then try the following suggestions:
sewing machine birdnesting
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
3 Common Sewing Machine Problems and How to Fix Them
Nov 29, 2015 | Brother XL-5130 Mechanical Sewing Machine
My sewing machine won't hold a stitch.
you need to make sure your bobbin is still feeding when you are sewing this model has a issue with dropping (ripping) the bobbin thread and then the stitch doesn't hold. you may also need to adjust the thread tightness it may be to tight or to loose
May 04, 2011 | Brother XL-5130 Mechanical Sewing Machine
The machine won' tsew as if the tension is too tight any ideas?
try rethreading the machine top thread & bobbin
try a tension of 3 or 4
make sure the thread move smoothly around the tension disks
make sure before threading the needle that the thread pulls smoothly
Nov 17, 2010 | Brother XL-5130 Mechanical Sewing Machine
How do I thread my bobbin to my brother xl-5130
Here you are....download the manual for free.
http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=XL5130
Mar 24, 2010 | Brother XL-5130 Mechanical Sewing Machine
How do you thread the bobbin
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000062/xl513052325340ug01enesfr.pdf
this is the manual for your machine, in PDF click "index" then bobbin and it shows you how to to thread the bobbin. Good luck!
Mar 26, 2009 | Brother XL-5130 Mechanical Sewing Machine
Will not pick up bobbin thread
I am having the same problem with my embroidery machine. I am waiting to hear if it is the timeing. And if i can fix it myself. joanne_1937@cox.net
Jan 26, 2009 | Brother XL-5130 Mechanical Sewing Machine
Jul 19, 2007 | Brother XL-3510 Mechanical Sewing Machine
Brother XL-5130 Mechanical Sewing Machine Logo
429 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
