Question about Palm Tungsten E2 (Multilingual) Handheld
Doesn't turn on
Device doesn't turn on at all, even reset button doesn't work even though is charging etc. Perhaps battery got too low? Could that cause a problem?
  • kahood2000 Nov 27, 2007
    I have the same problem. I used my E2 for a year and it wokred fine. Then, I did not use it for about 6 months and when I went to charge it up again, it did not charge or turn on. I think there is a light in the on/off button that is supposed to come on when it is charging, but it does not. Tried reset . . . nothing.
  • 4 Answers
Hi Giia: Have you fixed this problem yet? Most likely it is not your fault. There is a very small bug on E2 Palms which causes this to occur. (very rare). Else yes it could be battery problem.
Posted on Oct 02, 2007
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
How do i reset tablet if tablet is not turning on
Since you didn't mention the brand name, etc, I'm going to give you some basic instructions that hopefully will reset your tablet to at least get it turned on so that you can do a more in-depth troubleshoot.
You're going to have to drain the battery battery first of all, and even though you cannot turn the device on, just leave it be with the battery inserted for 24 to 48 hours. After that, you'll need to plug the tablet into a charger and allow it to charge for a full, normal cycle (4 to 8 hours, depending on your tablet.) After that, try turning the tablet on again.
If that doesn't work, remove the battery from your device for about 10 minutes and while the battery is removed, hold the power button down for 10 seconds. Replace the battery and try to turn the device on.
If the steps above don't work, then the best idea is to take it to a qualified repairperson for diagnosing the issue.
Mar 03, 2016 | Tablets & eReaders
Camera said battery exhausted when i went to take pic so I plugged it in to charge. light blinking but even though it looks like it is charging I cant turn it on to close lens
Normaly the lens would go in, as soon as the battery runs low.
Perhaps you should wait till you unpluged the camera.
Try to charge the battery in the external charger. Then after replacing the battery everything should work fine.
Nov 01, 2013 | Nikon Coolpix 5200 Digital Camera
My Nexus asus will not turn on even though it be charged over night Had it since Nov 25 2012
You could try to do a hard reset. Press and hold the power button and the volume up button simultaneously for 10-30 seconds and see if the device will then turn on.
Hope that helps!
Aug 05, 2013 | Universal Google Nexus7 7"" Capacitive...
My phone doesn't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 10, 2012 | Cell Phones
My w1 cherry mobile doesn't turned on even the battery is full
5.Wait 10 seconds.
Step
Thanks
Nov 12, 2012 | Cell Phones
Huawey g6600 doesn't turn
5.Wait 10 seconds.
Step
Thanks
Sep 29, 2012 | Other Huawei Passport G6600D Unlocked Dual...
Where is the reset button?
Sorry, there is no reset button. If the battery is charged and there's music loaded on it, but it won't play, it's probably wrecked. Perhaps try reformatting it as a drive -- it may solve the problem or it may brick it.
I previously had an even cheaper device that used the same chipset, and it just died one day. The battery is still good, and it works as a flash drive, but it refuses to play music. Perhaps your device died in the same way(?)
Aug 15, 2010 | Sylvania SMP2012SL 2GB MP3 Player
I have a similar problem.
Actually it sounds like the phone is merely off. Perhaps the battery actually died. If so and then the phone is off. When you plug in the phone with while it is off it will show the logo then it will say please wait and the the battery icon and say charging. If the phone is charged it goes dark.
Just hold down the "end call" key for a minute and see.
This actually happened to me once. I thought my phone was broken. Just as I was about to call AT&T I decided to try turning it off which is done the same way as you turn it on. Imagine my surprise when it started right up!!!
Aug 10, 2009 | LG Vu CU920 Cellular Phone
Can you do a hard restart on a Katana II?
You can do a hard reset on the phone which will erase everything but you have to know the Master Subsidy Lock code on your device. If you can't turn the device on that will not work though because you have to access the Erase Tool from the menu while the phone is on. Have you every exposed it to any kind of liquid or extreme physical damage? If the device will not charge the battery, it sounds like you have a loose charging port. Take it to the Sprint Service Center and see if they can issue a brand new battery and check to see if there is physical damage to the port.
Dec 18, 2008 | Sanyo Cell Phones
Palm Tungsten E2 (Multilingual) Handheld Logo
55 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
