Question about Rockford Fosgate P3001 Car Audio Amplifier
Im having trouble i keep blowing fuses on my amp?
I have a 780watt pioneer bridged to 2 15inch rockferd fosgate p2s with a ma audio powercap 8 gauge wire why would it keep blowing the fuse on my amp?i have two 30 amp fuses in the amp and they will blow after about 5 min of pounding?
  • 4 more comments
  • garyww Apr 16, 2009
    i figured it out i installed a new power cap and now it works perfect thanks though
    single 4 ohm
    well i was blowing fuses and im not sure exactly why but i havent blown a fuse in 2 days and yesterday i played it all day so i dont know before i put the capacitor in it was blowing all the time. this is the layout im running 8 gauge wire pos. & neg. i got a 80 amp fuse at the battery then i got a ma audio 1 farret power cap about 8 in.off my amp which is a 760 pioneer bridged into my subs which are wired into one wire from the box and they are 4 ohm single coil speakers. my amp gets a lil hot any suggestions?
  • blueextc3221
    blueextc3221 May 11, 2010
    A capacitor would not cause an amplifier to blow fuses.
    You have just bandaided the situation instead of fix the problem.
    It will certainly begin to happen again soon.
  • blueextc3221
    and what is the Pioneer's model # ?
  • blueextc3221
    your p2s are dual or single 4ohm voicecoils?
  • 91 Answers
You have you gain and freq knobs turned up too far, try turning them down and turn down subb level from deck
Posted on May 06, 2009
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
I have a rockford fosgate p10002 amp when i give it power it blows a fuse like the power and ground are touching
make sure youre positive and negative wires aint touching maybe you have a tear i a gauge wire and its shortning out to save youre amp check all youre work if you installed it yourself...
Feb 22, 2010 | Rockford Fosgate P10002 Car Audio...
Can i bridge a sony xm-1600gsd amp???
try connecting power to one terminal and the negative to the other terminal this will bridge the amp
Jan 29, 2010 | Sony Car Audio & Video
Not a problem just a question
  • 100 watts RMS x 2 at 4 ohms
  • 200 watts RMS x 2 at 2 ohms
  • 400 watts RMS x 1 at 4 ohms in bridged mode
  • stereo or bridged mono output
  • 4-ohm stable in bridged mode
  • Tri-Way capable
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • 50-250 Hz high-pass/low-pass (12 dB/octave) crossovers
  • wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
  • MOSFET power supply and output devices
  • MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
  • TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
  • Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
  • NOMAD — advanced protection circuitry for "intelligent" shutdown protection
  • speaker- and preamp-level inputs
  • 11-1/8"W x 2-3/8"H x 9-7/8"D
  • Wire your sub in bridged mode (4 ohm mono)
    + to + on amplifier
    - to - on amplifier
    (using bridging terminals)
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Apr 25, 2009 | Rockford Fosgate Punch 401S Car Audio...
    Prsx720
    The specs I read on the Pioneer site say the amp is not 1 ohm stable, so keep that in mind.
    It partially depends on the impedance of each voice coil on the DVC subs. If they are dual 4 ohm, and you connect the DVCs in parallel ("+"s together, "-"s together), you could run a sub on each channel of the amp(s). This would put about 200W on each sub.
    The other option is to still tie the dual 4 ohm voice coils in parallel, tie 2 subs in series (one "+" to the other "-"), and bridge the two channels of the amp (aka put them in parallel). But this, also, would be about 200W on each sub.
    Things get different if the subs have dual 2 ohm, 3 ohm, or 8 ohm voice coils.
    Mar 15, 2008 | Pioneer PRS-X720 Car Audio Amplifier
    Rockford amp cut out
    Disconnect all speaker wires from the speaker terminals of the amp and disconnect the RCAs. Replace the 30 amp fuse with a 15 amp fuse. If you turn it on and it blows the fuse, it's likely that it has shorted output transistors. If that's the case, you need to have the amp repaired.
    Dec 22, 2007 | Rockford Fosgate p-450.4 Car Audio...
    Im not get any loud base, even with the gain at full turn
    an orion 2500d requiers 2 4 gauge power and ground wires to work properly.
    Aug 22, 2007 | Orion 2500D Car Audio Amplifier
    Amp heats up and goes into protect mode
    Hi Saint108. You're describing it well, and i know what the problem is already. The MA audio amp, can't hold with a 2 ohm load. It's too low for that amp, that's for sure. Those are budget amps and they are not well built enough to handle low ohm setups like that. It's overheating and there's no ways around it.. Other than wiring your subs differently ! Just wire your sub directly (not in parallel) in a 4 ohm load, you will notice it will stop overheating that much. Do it quick, you'll most likely fry your amp giving it such hard work !! The HUM you're hearing could be related to it also. Try that, and keep me posted on the status. Thanks ! Cheebster.
    Jul 02, 2007 | MA Audio Hard Kore HK-898 Car Audio...
    Head unit
    If the display goes out then it is possible the flex cable is broken. Return it to Rockford for repairs.
    Jun 19, 2007 | Rockford Fosgate RAV DVD1 Car DVD Player
    Rockford Fosgate P3001 Car Audio Amplifier Logo
    512 people viewed this question
    Top Rockford Fosgate Car Audio & Video Experts
    Tygh Duval
    Tygh Duval
    Professor_V
    Professor_V
    Robert Rankin
    Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
