Question about Akai MPC-4000 Plus Production Center (w/80 GB Hard Drive&Onboard Sounds)
My Akai Dr16 pro 16 track mixer won't come on.
I have an Akai Dr16 pro 16 track mixer.
It all of a sudden stopped working and we don't know why.
When I turn the power on all the lights come on and the hard drive spins up, but nothing elce happens. When it was working fine all the light would come on for a second or two and then go off. Now they just stay on.
Whats wrong?
  • 2318 Answers
SOURCE: AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Nov 27, 2008
  • 3 Answers
SOURCE: akai lct3201 power problem
I fixed my Akai LCT3201AD in about 30mins. using 3 small parts from Radio Shack. Once I got the back off, I found the power supply board (PSB), mine was part# MLT-169B rev1.2. I looked at the capacitors (caps.) first, because they are usually easy to diagnose. I noticed the caps. bubbled out on the top of the board (where all the cables connect to it). There is 3 of them in a row, positioned between the two large heatsinks. My guess is that the heatsinks are generating a LOT of heat over time, because of bad ventilation, and causing the caps. to fail.
I went to Radio Shack and found 3 caps. (only had 3 in stock). The original ones were 16V-1000uF, Radio Shack only carried 35V and 50V in the 1000uF caps., so I bought the 35V ones and headed home, I removed the old caps. from the board, and installed the new ones. The 35V caps, are a little bigger, so its a tighter fit on the board, be careful. It took longer to remove the back from the TV than it did to do the soldering. YouTube.com has excellent videos on how to de-solder caps. on PSB's.
Total money spent on repairs:
$1.59 ea for 3 Caps. (part# 272-1032) $4.77
$2.99 for new soldering iron tip + $2.99
$1.00 donation for St. Jude's + $1.00
Total including tax $9.30
So for less than $10, I did a repair that my local TV repair shop wanted $575 for. Online stores want anywhere from $100-$275 for a PSB. If I get another 2 yrs out of it that's well worth $10.
Posted on Dec 16, 2008
praky16
  • 744 Answers
SOURCE: AKAI LCD TV - power light stays red, won't turn green
hiii.....
If the power supply is supplying the main board with the correct amount of volts, your controller board or your on off switch panel is malfunctioning and needs to be replaced. If its the whole board your looking at a few hundred unless you can find the same tv with a broken screen and just swap parts.The on/off switch board is cheaper but you have to remove alot of interior parts to access and becomes a hastle.
thank u rate me!!!
Posted on Feb 12, 2009
  • 304 Answers
SOURCE: Akai KC02-E1 Remote with new batteries stopped working.
First, You cannot resync the remote, Second the IR sensor may be bad on the tv and third, the Digital bd may be bad. The IR sensor connects directly to the Digital bd which is the brains of the tv. Also, there maybe a stuck button on the remote or the buttons on the tv.
Posted on Jul 16, 2009
  • 157 Answers
SOURCE: Akai LCT3285TA Television won't turn on
the problem is in the power supply(they know about it good luck fighting them)but there is good news.you can remove the power supply and replace electrolytic caps,EC18,EC19,EC20 all of them are 1000mf at16 volt use 1000mf at25 volt.you can also go to shopjimmy.com enter model number you will see power supply part number MLT169B
it will be cheaper for you to replace the caps,the board cost about $80.00 from them
Posted on Sep 24, 2009
Testimonial: "Dale Hunter's response was completely accurate. I replaced the three capacitors that he identified. And it has been working fine since 2009. Now I have the black screen problem. Help me Dale."
One of the amp fans stopped running, and eventually lost one whole side and it was crackling on the side that was working
When a fan quits the system has failed, turn it off before things fry. I do not know the unit but it sounds llike serious problems. Unless you are expereienced in electronics take it to an appropriate repair facility.
Jun 27, 2012 | Behringer Pmp4000 Europower 1600-watt...
My sb-200 flash won't work with my d200
Go to menu then shooting and turn on ttl
Jan 17, 2012 | Nikon SB-400 Flash
Some of my channels have stopped working 4-5-6-13-14-15-16 mackie 1604 vlz pro
If you havent ground looped the chanels. Most of the time the chanels need to be cleaned.
Dec 01, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
How do we connect an m audio fast track pro to my pc and mixer (dp-01fx)?
All you have to do is to connect with 2 cables your mixer's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Anyway in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 20, 2010 | M-Audio Fast Track Pro Mobile USB...
Hi seems to be no dry signal getting into mixer sends still workin?am workin on a mix and gutted regards my mixer is a 1642vlz pro cheers
Here is where you can get the service manual:http://www.free-service-manuals.com/Mackie_1642-VLZ_Pro_Service_Manual_L15833/ Let me know if this helps.
Nov 26, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
My handmixer suddenly stopped working while i was
sounds like the beater is not all the way in or it broke a gear
Mar 12, 2009 | Braun M880 MultiMix Hand Mixer
Samsung HLN5065W freezes in black / White screen
Picture freezing that is the symtoms of depected DMD modules...
Just click below for electronics store you can order online;
Partstore.com.
Vance Baldwin Electronics
http://servicemanuals.vstore.ca/
http://www.electronix.com/catalog/
Hope this may help;
Regards,
VOTIT
Aug 21, 2008 | Samsung HLN5065W 50" Rear Projection...
How to hock up my behringer mixer to m-audio
All you have to do is to connect with 2 cables your behringer mixer's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Thanks and regards
Stelios
Aug 20, 2008 | M-Audio Fast Track Pro Mobile USB...
Akai DR8 system error 14
Did you ever figure out what the "System Error 14" was on your Akai DR8?
Was it a hard drive error?
I am getting the same error in the middle of backing up my work.
Please let me know when you have a chance.
Thanks,
Jason
Aug 14, 2008 | Audio Players & Recorders
Computers & Internet Logo
279 people viewed this question
Top Akai Computers & Internet Experts
Michael Vincent Cruz
aravind shet
aravind shet
Are you an Akai Computer and Internet Expert? Answer questions, earn points and help others
