No power to USB ports, no video output
I just built a computer using the foxconn digitalife a76a-s motherboard, and am having issues with the USB ports and the video out. My USB mouse isn't getting any power and my monitor is receiving no input from the video card. Everything else seems to be working fine; the fans, the graphics card fan, the LEDs, etc. Can you help? Thanks, Kyle
  • 15 Answers
Make sure you have connected the USB's on right spot on the motherboard.
It's few places where it fits, so just try it out.
Posted on Apr 13, 2009
Gateway dx4300
One of two possibilities; the Motherboard or power supply. In my case it was the Motherboard. Those cheap capacitors tend to go bad over time without being used. I purchased a replacement motherboard(Foxconn RS 780 "bengal") from a place in WI. Skyline on Ebay. I would do a search on Ebay for Gateway Foxconn Bengal RS780 Motherboard. Then get the number and call. You can use the old processor, ram, and maybe the graphics card, but I'd run the onboard graphics first(if you do happen to have replaced the motherboard) to make sure the graphics card isn't causing an issue. You will need to do some research and reading on the net about installing new motherboards and hardware. If the motherboard is the same, Windows should still work with it. Do your homework first as this is only a suggestion as to your problem. It is what happened to my Gateway DX4300-03. Check all power supply related, graphics card and wire connections first before you consider the motherboard thing.
Oct 12, 2012 | Gateway DX4300 Acer Foxconn Bengal RS780...
When trying to load fresh xp pro it terminates after loadig basic start files
time to upgrade your pc had the same issue now i got a foxconn digitalife ela
Feb 07, 2010 | Foxconn WinFast K7S741MG Motherboard for...
USB keyboard and mouse not working on startup. Dualboot with xp and vista.
The usb ports might me malfunctioning . Try to use different ports. If that doesnt solve it then there might be a power issue on the board.
Apr 26, 2009 | Abit IC7-MAX3 Motherboard
Power surge on hub port a usb device has exceeded the power limits of its hub port there is nothing connected to my computer
I don't know how old your system might be or how many USB controllers it has on the motherboard, but understand this...
Theoretically, one USB port can support up to 999 "daisy chained" devices.
With that said...the way a USB port is implemented on a motherboard, manufacturers enable two or four ports to be working off of one USB interface. Those ports you see on the front of your computer are most likely connected to just one USB interface on the actual motherboard and that's why you always see computers with USB ports located together in pairs.
With that in mind, you're USB ports are connected to what is referred to as a "hub"(that motherboard interface), which only outputs so much power. If one device or many devices attached to this "hub" exceed the power output of this "hub" then it will either back down to USB 1.1 speeds or it won't function at all. That is why some USB accessories require their own wall adapter, because the USB can't supply all the necessary power for it.
So one of two things has happened, either your USB port is fried or you introduced a new USB item to the "hub" that surpasses the power requirements of what your USB hub can output once you plug in your mp3 player.
You can troubleshoot by unplugging all un-necessary USB equipment and try only that port again. My assumption is that the USB hub is fine but the actual usb port you use might be damaged.
Good luck.
Mar 12, 2009 | Acer Aspire One PC Notebook
Foxconn K7S741GXMG-6L Integrated Input/Output Port Activation
i have same problem on my motherboard and it is due to damage, check and see if your RJ45 (lan) is disabled in the system bios.then see if you are not drawing more than 500ma on the usb. good luck!
Jul 28, 2008 | Foxconn K7S741GXMG-6L Motherboard
Power to mouse/keyboard when off
Check your BIOS settings, sounds like it may be an issue there. If nothing there, could be a problem with the MB.
Apr 29, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Video output
April fools?
make sure the power is on, cables connected, all components are working and installed correctly?
Apr 01, 2008 | Foxconn K7S741MG-6L Motherboard
Foxconn 925xe motherboard
first check wheather power cable is join correcly at the monitor
then check video card placed correcly in agp card
or see the monitor cable join correctly at pc
Dec 07, 2007 | Computers & Internet
Foxconn K7S741GXMG-6L Sound issues
maybe the problem isn't in the sound cards or buil-in sound cards, i'm sure it's the speaker your are using, it may have some power leakage or something of that sort... check your electric "ground" connection too.
Jan 26, 2007 | Foxconn K7S741GXMG-6L Motherboard
Computers & Internet Logo
266 people viewed this question
David Payne
David Payne
