Dryer does not heat; washer stops during cycle
I have a Frigidaire Electrolux GLET1031CS0 stackable washer/dryer. My problem with the dryer is intermittent. Sometimes the coil heats up, but most of the time it does not. So, the dryer never gets hot. But now, the washer stops midway through the cycle as well. I had an appliance guy come out and he looked at my vents on top of my house and said they were clear and heat was coming through it just fine. So, both my washer and dryer have issues - the dryer still doesn't heat up and the washer stops in the middle of a cycle. It all started when I replaced the start switch for my dryer. Doing this wouldn't have much affect on these 2 issues, would it?
  • 247 Answers
SOURCE: Dryer still not heating
It's always worth tracing the wiring from power supply through programmer and timer, up to and between the various components on the heater duct, and from there back to the power supply terminals. It's not often that something unplugs itself, but it costs nothing to check and could save a lot of frustration. Have you got access to a multimeter? If not, suggest you get yourself a cheap one (never bought one in the States, but I expect you can get one from Home Depot for $10-15). With everything switched off and unplugged, measure the resistance across the terminals of the element. Expect to see about 20 ohms, give or take quite a lot. If you're seeing hundreds or thousands of ohms, you need a new element. Make a similar measurement across the thermostat and thermal cutout. Each of these should read very nearly zero ohms. If either reads much more than an ohm or two, it needs replacing (or resetting!). It's also possible that you're looking at a controller/timer problem - but eliminate the other things first. Good luck. A.
Posted on Feb 04, 2007
  • 2651 Answers
SOURCE: Model 417.94802301 stackable with electrical haywire?
you got a problem with your power supply for sure. check and make sure both your breakers are on inside the fuse box. turn them completely off and them back on(there should be 2 linked together for this unit. if that ok try to gt behind the unit and check the incoming power source(make sure wiring on rear of dryer is in tact. def sounds like inadequate power supplied to unit
Posted on Mar 10, 2008
SOURCE: Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Posted on Jul 11, 2008
  • 943 Answers
SOURCE: Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Posted on Sep 15, 2008
  • 8220 Answers
SOURCE: Electric dryer intermittently doesn't heat
If your dryer has a timer with quick connects which easily plug into it then you can possibly fix this problem. Yank both connects off the timer and remove the timer. Take the 2 motor screws off and remove the plate carefully. Clean the contacts on each leaf switch with a file. Put it back and retry. Sounds difficult but it isn't. Remember only the timer with the 2 quick connects.
Posted on Dec 22, 2008
Frigidarie Stackable Washer and Dryer leak
Check the Drain Tube, Check the Screen. When it gets to the FIRST Spin Cycle, Check the Water Level inside the Drum and see if it is Completely Draining... There is a Water Level Switch that should not be allowing it to Overflow so you may have an issue there... But first check for a Blockage
Aug 07, 2014 | Frigidaire FEX831CS Top Load Stacked...
Grinding noise before spin cycle
Good Morning John,
I see that you are hearing a grinding noise before the spin cycle in your Frigidaire washer, model# GLET1031CS0. A certain amount of "grinding" or gear sounds are normal in a heavy-duty washer. If you notice that the grinding sound appears to be getting louder, I suggest contacting either the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
Mar 16, 2014 | Frigidaire Washing Machines
Frigidaire stackable glet1031cs0 spin cycle spinning AND filling with water at the SAME time...!?
ok unplug the machine and take the back off locate the the water pump and check that its not blocked with any debris and also look for a small pipe 5mm going upwards, take it off and blow gently into it you should hear a click and one when you let the air out again, if so then unblock the place where you took it from with a pipe cleaner or metal rod, replace the pipe and try to run the machine again eric
Jan 13, 2018 | Washing Machines
Have a frigidaire "gallery" series stackable washer/dryer, the heating element initially turns on when the dryer starts. you can see the element light up and feel heat but after a minute of run time the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
Aug 22, 2010 | Frigidaire Dryers
Excessive spin
I had this issue when I first purchased my stackable washer.. Because it was still under warranty, I had someone check it out. Apparently when it was installed they forgot to take out the security clamp that secures the unit during delivery.. duh!!
Jul 20, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
Dryer Doesn't Dry Well: Take two full drying cycles.
if at all possible disconnect vent from behind machine and run a cycle with wet clothes( lint and moisture will be fllying around whih is why i said if possible) if it works then you know there a restriction in vent line leaving the home. Most problems relate to poor/ innadequate venting!!!!!!
Mar 02, 2008 | Frigidaire FLEB8200DS Top Load Stacked...
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
