Question about Planar VitalScreen D6015TM (White) 15 in. Flat Panel LCD Monitor
Power supply pings distributions planar d6015tm
I need to know the distribution of the ping in the conector of the power supply for adapter a new power supply to my monitor because the new power supplys are to much expensive the power is like a s-video out put 4 pings conectend inside of the board in the monitor by couples 2 and 2 + the ground and all the power supplys that i found have the regulars plugs i have an idea wich are the positive and the negative in the board but i want to be shure if some bary have the power supply for this monito i buy it but no so expensive please!!!
  • Odin  Rios
    Odin Rios Jun 12, 2009
    hi thanks i found on line the ping distribution , and you are rigth this is the medical monitor. thanks for your time, best regards italocub
  • Odin  Rios
The information comes on the same manual of the planar monitor d5015TM (see as medical monitor)
Posted on Jan 19, 2008
Device says it's working with a 100% connection but still no Internet. Totally mystified about who to call for help, let alone what to do.
Looks like your connected to the network fine but not receiving the internet signal. Maybe your modem or router is not pushing it out. Try power cycling the modem and router for about 5 minutes (unplugging power). Try connecting to a different network if possible to rule out that its not the wireless adapter having the issue. Hope this will give you help.
Mar 08, 2011 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
I'm not sure what's wrong with my laptop, my HP tx1000. My computer is just not recognizing the adapter in the device manager.
See if you can ping your NIC.
Start -> Run
Type in cmd
In the command box type:
ping 127.0.0.1
If these pings fail try turning off your computer, unplugging it, removing the battery, and holding down the power button for 20 seconds. This should make your computer recognize your NIC.
If this solves your problem please leave feedback.
Jan 24, 2010 | Broadcom Computers & Internet
I cant chat on my facebook page
you can chat in facebook page by clicking the chat icon located in the right hand side bottom corner and the icon is notified by a chat symbol when you get the mouse near it
Dec 01, 2009 | Dell Dimension 3100 PC Desktop
Washer shows UE even with nothing in it and makes a metalic pinging sound bell like when trying to spin
Imbalance error (UE)
One of the following has occurred. Try correcting one or more of these issues below.
* The load is too small
* The appliance is tilted
* Laundry is gathered to one side
* Non-distributed things are put into the drum
Aug 12, 2009 | LG WM1812C Front Load Washer
Knocking/pinging sound when stepping on the gas for power.
you will distroy the engine if you continue to let this noise happen.
the timing must be retarded to get the ping out if its that bad.
most of the time if its just a little bit though filling the tank with super unleaded will take out the noise.
the distributer must be loosend and turned in the correct way to ****** the timing and the idle must be put back up to compensate.
the distributer is the ignition timing.
the other thing that could have happend is the timing may have jumped time on the timing belt itself.this is a complely different timing.
this timing is valve timing.
the distributer is ignition timing.
when the distributer is turned you are changing the ignition timing .
you say in your text and i quote .
The service tech only adjusted the distributor fas far as he could to lower the idle.
a tech should never be turning the distributer to lower the idle nor should this be explained in any way to the customer.
if a tech says he dosent understand something stop them rightaway and get your car out of there or get someone else to talk to .
10 times out of 10 if the tech dosnet get it the car wont get it either.
have a competent service tech test and conferm the timing belt or chain timing .
keep me posted
joelmitchell1@hotmail.com
thank you
jm
Jul 29, 2009 | 1995 Nissan Pathfinder
Octane Ping and running lean
change the mass air flow meter.
Jul 24, 2009 | 1995 Ford Ranger Supercab
No power up hills and pinging noises come from TBI little back fire.
Sounds like the knock sensor has failed. It's on the passenger side at the bottom of the engine block, in front of the starter. One wire going to it. Have you checked the timing lately, maybe it has moved?
Apr 15, 2009 | Chevrolet Suburban 1500 Cars & Trucks
Rattling only when accelerating
the Timing Belt could be a tooth or 2 off or the distributor could be off in angle, you probably will have to have the timing set with a timing light, that will cause pinging and lack of power. most times its juts needing the timing set correctly, it could be just a few degrees out.
Mar 31, 2009 | 1993 Honda Accord
84 Z31 Turbo - Rough idle and poor slow accelleration
I would suggest a few things ... first and the most important... check that you have the wires in the proper order on the distributer. next have the timing checked.
Robert
Dec 27, 2008 | 1984 Nissan 300ZX
ADSL modem, firewalls
What did you have her ping an IP Address or a domain name?
Was she attempting to ping the gateway address on the lan side of this adsl device? In that case either DHCP is not supplying a dynamic IP address or the static IP address, subnet mask, default gateway address configuration in her adapter is incorrect.
If she pinged an IP Address and it is not the prior issue I would favor that the modem side of the device are not set properly for her internet service provider. The ISP's support/help website may help in determining the correct values here.
If she pinged a domain name like www.google.com then it could be the same as either of the above or it could be a lack of DNS addresses in the router or her local adapter configuration whereever they are preferred in her environment?
Dec 25, 2007 | Computers & Internet
Planar VitalScreen D6015TM (White) 15 in. Flat Panel LCD Monitor Logo
147 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jay Plesset
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
