Question about Beverage-Air 44.9 cu. ft. / 1271 liter Commercial Freezer KF48
Freezer problem kf 48
Freezer wont stay cold ,compressor runs a lot ,evaporator frosts up,is it freon, thermostat or something else? please advise.
  • 1 more comment
  • bobalix Apr 15, 2009
    The evaporator fans are running .
    is running steady and does not make temp.
  • Dennis Boxerman May 11, 2010
    Frosting up on evap can be several things. A door not sealing. No defrost cycle or malfunctioning defrost cycle. Improper refrigerant level. Dirty condenser. Intermittened problem with evap fan (stops and starts). Some evap fans are controlled by door switches and they may not always function correctly.
    Check a few of these and we can continue to resolve this issue.
    By the way, the t'stat cycles the unit off and on based on temp of the conditioned space. If the space does not make temp, it should be running, so t'stat is probably not the issue at this time.
    Is the evap fan running? Does it ever make temp?
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 24, 2010
Freezer runs but will not freeze
Check for low freon first, You need an expert who has testers as well.
Jun 29, 2015 | Whirlpool EV250NXT Upright Freezer
Why
if the compressor is running but not cooling most likely you have a freon leak in the sealed system,you can tell by looking at the evaporator coil,the coil should have an even frost pattern covering it,if frost is just on top you have a freon leak,also if you have a defrost problem and the coil is covered with ice this also will keep it from getting cold,look at the coil to see.good luck
Aug 26, 2014 | Kenmore 4.6 Cu. Ft. Compact Refrigerator...
My true gdm-43f freezer keeps running won
Not sure exactly what the situation is I'm going to give you a detailed overview on how the system works that way you'll be able to isolate the problem. Your machine is a single compressor unit, meaning that even though there are two seperate sides, the freezer and the refridgerator, they do not operate independantly. The sealed system, which is what cools the machine, has two parts, a high side and a low side. The high side is located under the machine and consist of a condensor, for which freon is pressurized back into a liquid and passed throug the compresoor to be released as a gas into the evaperator, the low side. This is where the freon is at a cold state. Ok, now that you have the bare basics of a sealed system, we move forward. The Evaporator is located in the freezer side, behind the freezer wall. As freon goes through the evaporator, a fan, called the evaporator fan, is located above it and circulates air throughout the freezer compartment. Also, an airway connects the freezer to the refridgerator, usually top right of freezer, or top left refridgerator on side by sides and through the freezer floor on top mount models. This means the freezer cools the refridgerator side. ****First check point**** Is the fan running in the freezer? This would cause the freezer not to cool as well but also a rise in the refrigeration side would be noticed. As freon goes throught the evaporator, which is made of aluminum, the temperature levels are well below the freezing point, so frost and ice will form on the coils. Over time, this kind of build up would form a blockage, not letting air be drawn from the bottom of the coils by the fan to circulate the cold air. To prevent this from happening the a defrost heater is installed to thaw the ice away and comes on every 6-8 hours. This is initiated by the defrost timer, or in some machines an adaptive defrost control. The heater will be located at the bottom of the evaporator because hot air rises, getting maximum effect. A third part to the defrost system, the first two being the timer and heater, is a bi-metal,or terminating thermost. Its called this because when the thermostat is cold, the metal inside it constricts making a pathway for electricity to flow through to the defrost heaters so it can get hot, and as the heat rises and the ice melts away, the terminating thermostat will warm up, and the metal will expand causing the path of electricity to be broken, turing the heaters off. This is to prevent any high temperature situation from happening, like melting plastic or even a fire. If any of these parts fail, the machine will nit defrost. ***Checkpoint two***** Do you see any ice build up on the freezer wall. This ice will be completely across the back wall. Most signs of defrost problems are noticed first by a rise in temperature on the refrigerator side first. The above can be assessed with a quick look and listen. If no frost is present and the fan is running you can rule out the above. ****Please not that ice build up on just a small section, for example, upper left or right corner only is not a defrost situation but a sealed system issue, caused from low freon or a restriction in the lines and a EPA certified technician should be called.****** The last thing you should check you'll need to pull the machine away from the wall and remove the lower panel to gain access to the compressor area. What you are checking here is to see if the condensor fan motor is running and that the coils are somewhat clean enough for air to flow across them. The fan draws air from across the compressor and through the coils helping to keep the compressor temperature down and also to evaporate the water that is drain when the machine goes into defrost. Rule of thumb is if the compressor is on the fan should be. If the fan isn't runnning the heat from the compressor will be transferred to the machine and notice first on the freezer more so than the refrigerator. ****checkpoint three**** IS the condensor fan running? Are the coils clean, and can you feel the air from the fan with your hand placed on the opposite side of the coils?
The refrigerator side is usually where your defrost timer, discussed earlier is located. Also on this side is where your temperature control, or controls , are located, These controls are what are called thermostats, and have a direct line to the compressor. This means when the temperature has reached the desired setting the thermostat will kill power to the compressor in the same manner the terminating thermostat does with the defrost heater. Some models have a temperature control thermostat for the freezer and the refrigeratot, but some only for the refrigerator. The most noticeable sign of a thermostat being bad is the food in the refrigerator side will freeze, usually on any setting or the machine won't come on at all, including the fans. Problems are usually noticed on the refrigeratot side first. The last thing to discuss is The freezer and the refrigerator both are rising in temperature, but the fans are running, etc. Normally in cases like this a humming sound followed by click is heard or sometimes just the click. The humming sound is the compressor trying to start but failing and the click is the relay breaking contact. On newer machines, especially ones that fall under the whirlpool umbrella, the compressor relay, also called the start device has failed and needs to be replaced, but also the compressor itself could be bad. Well, thats the basics. I know it's long winded but I wanted to put something that you could print out and use as reference. Good luck.
Jun 19, 2012 | True GDM43F Commercial Freezer
Frost on the evaporator
watch this video I made. this is subzero with low level of freon (almost out). same situation on all refrigerators and freezers. you can see ice at the begging of evaporator. if there would be a little more freon evaporator might of frost up at the top might frost half of evap other half would be not even cold.
Jan 28, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
Compressor runs bypassed thermostat with wire that turns on and off compressor,but freezer cabinet is not cold 65 degrees evaporator fan does not turn on,condensor fan on,sttill no cold
If you have just turned it on it takes awhile for the fans to come on. The evaporator coil has to get cold about (10 to 20 degrees) and make a klixion fan switch to turn the fans ON.... Is the evaporator coils getting a frost pattern on them??? If not then the system may be low of Freon.. If the coil is completely froze up and you are getting frost back to the compressor..... then you have a bad fan switch or a door switch.... If you have a wiring diagram you can trace out the wiring.... It is usually down by the compressor or control panel... hope this helps.
Mar 30, 2011 | True 23 cu. ft. / 651 liter Commercial...
Freezer does not freez food at all. the compressor motor run but no cool air or freez! Please advise any solution
Since you say the compressor is running, you should check the evaporator coil inside the cabinet. Remove the back wall screws, and the back wall, to expose the evaporator. If its fully encased in frost, like a square block of snow, you have a defrost problem, heater, t- stat or defrost control. If frost only at the top, your fan is not running. If its bare of frost, all you see is the aluminum coil, you have a sealed system leak of refrigeratnt
Oct 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
I have a stand alone freezer model MFU17F3GW8 serial # WB11907298 my problem is that it does not get cold enough. what could be the problem?
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Are the condenser coils on the back warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
evaporator coils are behind the rear cover inside the freezer at the bottom.
observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Compressor or freon problem will require a repairman.
Oct 15, 2009 | Freezers
Panel is hot and freezer does not work!
Check the condenser fan underneath the unit accessable form the back behind the cardboard cover. It should be running when the compressor runs. OR Check the evaporator behind the rear cover inside the freezer. Check for ice build up. . Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control
Sep 09, 2009 | Freezers
COMPRESSOR RUNS, AND IS HOT TO TOUCH, FREEZER WONT STAY COLD IF O
either your evaporator and condenser coils are very dirty or your low on r22 freon
Jul 31, 2009 | Freezers
Freezer Thawing Out
This will not cause a freon leak and it is possible that the door was left open, but to be certain that you don't have a defrost issue, follow the guide below to diagnose any problems. Also the warm walls are normal during compressor run times.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/0047_3.asp
If your freezer cools but doesn't get cold enough, it may have a problem in one of several areas. To better understand the proper operation of a freezer, read about freezers in the How Things Work section of our website.
In a self-defrosting freezer, poor cooling often results from a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel inside your freezer. But if you see any frost or ice build-up on the inside walls, ceiling, or floor of your freezer, it's a sure sign of frost build-up. And that's a sign of a problem with the self-defrosting system.
Freezers should self-defrost three to four times in 24 hours. But if a component in the self-defrosting system fails, the freezer continues to try to cool, instead. Eventually, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There's still some cooling because the coils are frozen. But with no air flow over the coils, the cooling is quite limited and the freezer isn't as cold as it needs to be.
An easy (though often inconvenient) test of whether the problem is with the self-defrosting system is to remove all of the perishable food from the freezer, turn the thermostat to Off, and leave the door open for 24 to 48 hours. (Keep several towels handy in case the melting frost and ice overflows the drip pan). This "manually" defrosts the freezer. When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the freezer then cools properly, it indicates a problem with one of these components in the self-defrosting system:
  • The defrost timer. To test this, manually advance to the defrost cycle. The unit should advance itself out of the defrost cycle in about 45 minutes.
  • The defrost thermostat (or bi-metal switch). This thermostat allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees (depending on its design). This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on.
  • The defrost heater. You can test this for continuity using an electrical meter.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 19, 2008 | Frigidaire Freezers
Beverage-Air 44.9 cu. ft. / 1271 liter Commercial Freezer KF48 Logo
75 people viewed this question
Top Beverage-Air Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
mike cooper
Are you a Beverage-Air Freezer Expert? Answer questions, earn points and help others
