posted by GRACIE11967 on Sep 12, 2007
My magnavox 42' LCD tv was delivered on 9/6/07. The next day it was installed w/the proper HDMI connections using our cable providers HD cable box. Two days later on 9/10 two fine blue/green lines have now appeared down the middle of the screen from top to bottom. I was told by a tech support rep. to unplug tv and cable box for a brief period of time to reset the signal and was told there maybe a sofware problem w/the tv. The two lines also appear when playing dvd,s and when the tv menu screen is on. It appears there maybe a hardware failure somewhere.
Solution #1
posted on Oct 14, 2007
call philips to get this srviced under warranty. this repair might take a few weeks because the failure could essentially be any one of several parts. first thing to try is the ssb, then the logic board and lvds cable. if none of these work then you need a new panel
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Philips Magnavox 42MF521D/37
Email this problem
Email this problem
Can you Help with these Flat Panel Televisions problems?
Philips Magnavox 42MF521D/37 Television
picture not centered
everything is fine ,picture... Answer This...
Magnavox 42MF230A/37
We bought the tv about 1.5... Answer This...
Philips Magnavox
Philips Magnavox
are parts compatible with each... Answer This...
Philips Magnavox tv with no...
Hi. I have a Philips television... Answer This...
Menu keeps popping up...
I found your listing and I am... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
