Question about GE WPGT9350C Top Load Washer
Service mode diagnostics error after repair
Recently my washer lost all power after having a factory repair service replace my main system board and the filter ASM part # WH12X10248. I now get an erro unrelated to the previous power loss -- the startup diagnostic reports -- the following error -- the motor is not rotating properly. check and replace if neccessary. before pursuing this as a error independent of the previously mentioned power issue -- can this be main board related, or would this just be a coincidence? Also does the above error usually mean the motor has burned out? Thanks in advance, Steve
    Novelist:
    Champion:
  • 244 Answers
Can be still the board that has been replaced has some boards can have faults from new but what can be wrong is that most motors have carbon brushes which go into the motor at either side of the motor with 1wire going onto them if these are low then the motor doesnt have enough contact with them so it wont spin properly pull these out and check first but be warned if the washer is under warranty you can void the warranty by letting anyone touch it m8 let me know how you get on and if no help then ill think what else it could be m8
Posted on Sep 12, 2007
SOURCE:
EE error code on reliOn blood pressure monitor?
Corrupt memory causes this.
Just guessing on your make and model type!
1 - Unplug the washer from power for 10 minutes to attempt to CLEAR THE CORRUPTED MEMORY on the main control board.
NOTE: You can try unplugging the washer multiple times to attempt to clear the corrupt memory. Unplugging the LG washer with the EE error code may clear the error code and no other action is required. The washer memory will be cleared or reset and the EE error code is considered fixed or repaired.
2 - If the code does not clear on the washer after unplugging it multiple times, this means the main electronic control board is faulty and needs to be removed and replaced.
3 - To be sure the main control board is the problem, run a TEST MODE if you want to continue the troubleshooting process or just replace the main control board and that will fix the EE error issue.
NOTE: How to run a TEST MODE on an LG front load washer is explained below...
4 - If you have unplugged the washer for 10 minutes and have done this multiple times and the EE code DID NOT CLEAR, you can run the TEST MODE and the EE error may come up with the FIRST PRESS OF START/PAUSE BUTTON DISPLAYS EE ERROR CODE. If this is the case,then you have a bad or faulty Main Electronic Control Board and you need to replace it.
Dec 16, 2017 | Washing Machines
Lost all power, replaced the power supply board, No help.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jun 23, 2016 | Televison & Video
How do I repair a tv power board
Apr 08, 2016 | Westinghouse New Original TX42F430S Remote...
Any time I go to start the washer the lid lock button starts blinking and wont start cycle and wont open for ten minutes
Hello. This could indicate a problem with the electric lock. Unplug the washer for a few minutes to reset it and see if that clears up the problem. Have you had a power outage recently(3-4 weeks) prior to the problem? The current surge from the returning power can damage and/or corrupt the programming stored in the main board computer. If you have never experienced the technical part of a washer, please call for service--there are many problems which can cause this symptom. The washer will have to be put into a diagnostic mode to decipher the binary error codes(groups of lights will flash, telling what part of the unit is problematic). I hope I helped you!
Aug 23, 2015 | Whirlpool Washing Machines
F1 error code
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I am getting an F1 error on the washer
Jul 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Marvel refrigerator drawer, E1 error.
The E1 error is for low/high compressor amps. You can reset the unit by powering it down (turn the supply breaker off and then back on) or placing it in diagnostic mode. To place in diagnostic mode, press the warmer button four times while holding the colder button. The display will flash the firmware and software versions. Just use the same button sequence to take it out of diagnostic mode (will auto revert after no key action for 10 minutes) and it should run, If the unit does it again, you will need to contact a servicer to check the amp draw of the unit and if no problem found have them replace the user interface board. The part is included in the one year warranty and if you are close...you may be able to convince the factory to cover the repair. Call the factory at 800-223-3900 and ask for Ron or Tim in technical assistance.
Dec 09, 2009 | Refrigerators
I have a Whirlpool Cabrio Top Loading washer model WTW6400SW1. During the past month, I have been seeing the "LD" error code ("slow to drain") but not the "F1" code during middle of the wash cycle before...
Aug 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Getting error E3
3E == overcurrent detected at the motor.
Open the control panel, there you will find a tech sheet that explains how to put the machine into service mode and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes. You will also find serveral other diagnostic service notes. Read them and follow the instructions to test the motor, motor control, and main control board. Hope this helps.
Jul 16, 2009 | Maytag Neptune Washer
Whirlpool CABRIO WTW6400SW2 Washer shows F1 code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]#$%
Apr 08, 2009 | Whirlpool WTW6400SW Cabrio Washer
GE WPGT9350C Top Load Washer Logo
137 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
