Question about Hitachi 53UDX10B 53" Rear Projection Television
The image of my 53sbx10b are double after few minute
When i open the tv ,image are good but after couple of minute the image become double on the top of the screen to the middle.The sound don't change at all.I try the magic focus but nothing change, trouble start one week ago and are permanent now, the image double after one or two minutes
  • Anonymous May 03, 2009
    where do i get this from my tv has double vision
    Genius:
  • Hitachi Master
  • 1,039 Answers
Replace convergence ics. Hitachi has a ki for this consisting of STK-395-110 ic and some resistors.
Posted on May 02, 2009
I own a 40" Bravia
You should open the tv and check the power supply module, this part has the ac cord connected to it. If the picture clears after a bit, you will probably find some of the electrolytic capacitors on the module have swollen tops, these are not running within 10% of tolerance and should be changed.
You will require some soldering skills to change these parts and they must be installed in the correct polarity. Pay attention to the +- symbols on the pc board whenb replaceing caps.
Jul 12, 2011 | Sony KDL40XBR7 40 in. LCD TV
I have a Tv Philips model 32PW6506/01 few minutes after that is between 10 and 20 minutes go stand by, then if I press p + start and after 10,20 minutes and goes into standby ...If anyone knows about...
Good day!
Usually that problem is cause of the failing capacitors on the power supply section.
You have to do is open the back cover of your TV and look for the actual image of the capacitor with in the power supply section if it is leak/bulged on the top.Please replaced it with the same type,ratings and value.
Thank you and good luck.
May 08, 2011 | Philips 32PW6506 32" TV
My tv is almost 6yrs old and all of a sudden the picture is blury almost showing double images. The color is also of at the top and bottom of the screen.
this is typic old projection tv, some tecnical ajust parameters have reset, so if you can adjust,this settings on service menu on tv, or ask for help on local repair store, to calibrate scren.
Nov 29, 2009 | Televison & Video
I am getting double images while watching TV;
There maybe some loose components on the circuit and that needs resoldering. Bring it to the repair shop to done.
Dec 02, 2008 | Zenith C27A24T 27" TV
Hitachi 53SBX10B Projection TV
that is a convergence fail. would need dome new parts and board rework. expect somewhere in the neighborhood of $200-$500 for repair from most tv service centers.
Feb 20, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Intermittent double images and horizontal lines
Hello mucci2k,
You have one of two problem.
(1) You have a loose connection on your LDS cable going from your signal board to your T-Con board. The T-Con board s the board that is mounted directly to the panel. Its sits near the top of the panel in the middle.
(2) You have a bad T-con board. This board cannot be repaired. It must be replaced. I can tell you where you can find it
Best regards
circuitcity
Feb 14, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung HLR6167 - picture freezes
This is very common in Samsung DLPs. The DMD board is going bad. You will need to replace it.
Jan 07, 2008 | Samsung HL-R6167W 61" HDTV
Blue and Yellow doubles
Well, fortunately the television that you purchased has an auto-convergence feature. What is happenning is that your color lamps are misaligned, did it get moved at all recently? Anyway, in your menu you should see a "Convergence" menu, and inside that menu, a section called "Perfect Focus". Run Perfect Focus in this sequence: Green --> Red --> Blue After that your picture should look great, if not try tinkering with the manual adjustments on the "Convergence" menu. Here are some URLs that you might find helpful: (just copy+paste into your browser) Your Television On Samsung's Webstire: http://www.samsung.com/Products/TV/ArchivedTelevisions_2002/HCM4216WXXAA.asp Your Television's User Manual (Download And Open With Adobe PDF Reader) (The "Convergence" Menu Is Section 3.3) http://www.usersmanualguide.com/samsung/tv__projection/hcm4216w
Apr 29, 2007 | Samsung HCM4216W 42" Rear Projection...
Hitachi 53sbx10b
Try the auto convergence feature of the TV. Press the button on the front of the tv and wait about 5 minutes....
Apr 27, 2007 | Hitachi 53SBX01B 53" Rear Projection...
Sony KP-57WS500
the unit needs the convergence ic's replaced and probably a couple of safety resistors.average repaire are about 300 from a tv shop
Mar 04, 2007 | Sony KP-57WS500 57" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
220 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
