The HP 4060 series printer is hooked up to a switch box to two computers. One computer prints fine. The other one gives an error code (22 parallerl I/O buffer overflow) I have tried removing and re installing the printer but it doesn't work. What can I try to correct it. Thanks Roy S. Lilley
  • etcllc Apr 13, 2009
    I uninstalled the printer and reinstalled it. The printer works after you push the Go button but gives the sme error message and just prints out a page of gibberish.
    I check all of the cables and they are okay.
    How can I download the drivers without the install disk?
  • 523 Answers
If you have windows xp; open control panel and press on printers and faxes, look to the right hand and click add printer choose local since you have local network and keep automatic dectect slected so it can find your conncted printers , then choose the port type, if u use parallel cable, or usb, but if its Ethernet cable you have to select create new port and select tcp ip. then afer that you can look for ur printr under the brands but if its not there u can press have disk and browse to your disk and choose the print driver and next next till it finish.
let me know wat happen after.
Posted on Apr 14, 2009
  • 19,396 Answers
Reasons why you can get error 22 on network printer:
1. I/O configuration for the computer or printer is incorrect.
2. Wrong or damaged ethernet cable.
3. Computer is powered off.
4. Damaged printer I/O port.
5. The printer's EIO card in slot X has overflowed its I/O buffer during a busy state.
6. This error can occur if the driver you are using is not IEEE-1284 compliant.
7. Indicates the parallel buffer has overflowed.
8. Firewall issues
If the printer prints fine on one computer you can limit to :
8. Firewall issues
Try replacing the ethernet cable from computer to network.
Try reinstalling the printer driver on the computer that is not working. To do this
unplug printer usb.
delete the printer from installed printers.
Install network printer again using driver disk or driver download.
Posted on Apr 13, 2009
  • Ginko
    Ginko Apr 13, 2009
    If it prints out a page of gibberish, then it is either printer cable or bad printer driver.
    The ethernet cable can be tested using a cable tester, however is uncommon, since the computer is working on the network and it is not slow.
    I think that the printer drivers installed on one of the two computer is not working.
    Also try inverting computer connections to the switch, if printer does the same on other computer replace the switch, this is the same if switch is ethernet switch or usb/parallel switch.
    If it is not that , as said ,
    • unplug printer cable..
    • go to control panel.
    • find installed printer.
    • Remove all versions of this printer.
    • Reinstall drivers using printer disk.
    • If you are using printer on ethernet (local network) switch configure printer as network printer.
    • If you are using USB/Parallel switch connect printer directly to computer when asked by setup program.
How to fix Error 60.02 for hp 4345
Easy steps to fix Error Code Clr20r3 occur in HP Computer/Laptop/PC on Windows OS by dialing HP Customer Support Phone Number 1-844-355-5111 (toll-free) with the help of customer support services.
HP Customer Support Phone Number 1 844 355 5111 HP Help
Sep 08, 2015 | HP Office Equipment & Supplies
I disconnected the hp officejet all-in-one from my computer and later reconnected it. Now it thinks its a fax machine, and won't print from the computer.
it (Hp officejet 4315v series FAX) must be set to default that's why it would not print.The default printer should be the Hp officejet 4315v series,the one without the word fax in the end.
Here's how you do it:
for windows XP operating system
  1. click on the start button on your computer.
  2. click on printers and faxes.If it is not on the start-up list you can click on control panel ,click on printers and faxes or printers and other hardware.
  3. in printers and faxes,it will display all the printers installed on your computer
  4. look for officejet 4315v series or officejet 4300v series then right-click on it's printer icon then left- click on set as default.
  5. try printing from the computer.
for windows vista operating system
  1. click on the start button on the computer
  2. in the search box,type in printers,hit enter key on the keyboard.
  3. in printers,it will display all the printers installed on your computer
If it does not print download the print diagnostic utility from the hp website.It is a helpful tool in diagnosing printing problems.I will provide you the link.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-91793-1&lc=en&dlc=en&cc=us&os=228&product=1138346&sw_lang=
Jul 09, 2011 | HP Officejet 4315v All-In-One InkJet...
I have a mfc-7340 and a Blekin 4x4 peripheral switch. I have 2 computers hooked up to the switch. The switch recognizes both computers and the printer. However, I can only print from the first computer in...
reinstall driver again in seconds computer from where you can't aboe to give print.
Also check ping command
"ping (printer ip addreses.)
If you get reply from printer ip addrees with ping command then yourt printer is in network with your computer otherwise you have to correct your computer ip adreeess as your network settings .
Aug 23, 2009 | Brother MFC-7340 All-In-One Laser Printer
Print cartridge prob [tri-color] refer to ... doc to troubleshoot
HP Officejt J4680 - All in one Printer from HP, whcih will have Printing, Fax, Scanner and Copier facilities.
Normal catridges recommened by HP are given below :
01. HP 901 - Black which will print 200 Pages.
02. HP 901 - Tri Colour which will print 200 Pages.
03. HP 901 XL Black which is a bigger one that will print 900 pages regulary.
This printer is most rugged one used by Home as well as in offices.
The follwoing message regarding this Printer taken from HP Website which gives information about the printer quality.
Enjoy the convenience of wireless connectivity with our Officejet J4680 All-in-One. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with our Officejet inks, you'll get high-quality printing at a lower cost per page than with a laser printer. Reliable and versatile
  • Print, copy, scan and fax with a single machine
  • Print fast, at up to 28 pages/minute black, 22 color##
  • Fax at speeds up to 33.6kpbs
  • Streamline big tasks with the 20-page automatic document feeder and 100-sheet paper tray
  • Preserve important documents for decades without fading1
Solution:
Please use the originai catridges for this printer and there will not be any issues.
In spite of this, the problem continues, please call the local HP Authorized Printer vendor to solve this problem.
If the Printer is under warranty, you will get a replacement printer with same or the higher configuration which is available in the market.
Jul 21, 2009 | HP Officejet J4680 InkJet Printer
Error msg and printer wont print without pushing "on" button, wireless connection
need to hook up printer to computer. The software I had I threw it away. The printer model number is 4126-005. The serial number is 02320543500 2006/08.
May 24, 2009 | HP Photosmart 3310 All-In-One InkJet...
I just put in a yellow cartridge. Previously the printer was working just fine. Now it is showing an error code: 10.92.00 So I put the old yellow cartridge back in. The same error code now appears? He
Hi ron0911170:
This is your problem.
10.92.YY CARTRIDGES
NOT ENGAGED
alternates with
Open and close
front door.
The cartridges are not engaged,
poor primary transfer bias contacts,
defective high-voltage supply, or
control signal errors.
YY Description:
00 - Black print cartridge
01 - Cyan print cartridge
02 - Magenta print cartridge
03 - Yellow print cartridge
1. Open and close the front door to fully
engage the cartridges.
2. Reseat the print cartridges.
3. Check the printer primary transfer bias
contacts to the transfer unit. Clean if
dirty. If the contracts cannot be
cleaned or they are damaged, replace
the transfer unit.
4. Replace the high-voltage power supply
PCB.
5. Replace the DC controller PCB.
Hope this helps
May 24, 2009 | HP LaserJet 3600n Printer
Lexmark 1200 Series
unplug your usb cable,uninstall printer then reinstall
Nov 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
HP Printer will not print!
It is really my first time to encounter that particular message that the "directory needed is unavailable". Here are the things that i want you to check.
1. Make sure that you logon to your computer using the Administrator previlege. That way, it will allow you to install and uninstall programs or softwares without any warnings.
2. Try to open the controlpanel>>> go the Printers and faxes>>> then make sure that the HP Deskjet F300 series has a check mark and it says READY.
3. If it doesnt say ready, right click the printer icon and it will give you option "USE PRINTER ONLINE". click on that.
4. Now, try printing a document.
Note: if the issue still not resolve, please give me further informations about the operating system, when you tried to print does it stays on the printing queue?
Thank you so much
adonscott
Jul 03, 2008 | HP DeskJet F380 All-In-One Printer
Two weeks ago my computer creashed, lost everything,a technican has reprogramed most stuff,my printer does'nt print from the computer, its all hooked up,the technican gave me a Epson stylus C20 Series...
I have no clue why he would give you an Epson disc. Anyway, you can download your driver from HP's Site.
1. Unplug USB cable to printer, then from Control Panel > Printers delete any printers there.
2. Reboot
3. Install new drivers from the site above.
4. Plug USB cable back in.
Enjoy
Geno
Mar 10, 2008 | Computers & Internet
C3140 PRINTER NOT PRINTING - HELP
How long ago did you purchase the printer? Does it have the "Certified for Windows Vista" logo on the box? If not, it won't work with Vista at all. I checked Microsoft's Hardware Compatibility List and it says the HP Photosmart C3100 series is *certified* with Vista, however it does not say it *works* with Vista. http://winqual.microsoft.com/HCL/ProductDetails.aspx?m=v&g=d&cid=900&sv=&f=86p&pn=HP%20Photosmart%20C3100%20series&oid=31 Per the link, the driver may be part of the Windows Update. Give that a try, as well as HP's website. Otherwise you may need to take it back and exchange it for a Vista-certified printer. Let me know how it works out!
Jun 08, 2007 | HP PhotoSmart C3140 All-In-One InkJet...
561 people viewed this question
k24674
jasbo
jasbo
